Question about Maytag Atlantis MDE7400AY Electric Dryer
My Maytag Atlantis dryer MDE6400AYW timer knob broke off. I got the knob and skirt but I need to know what part to replace to get a new shaft to attatch the knob on to.
catriver
  • 878 Answers
SOURCE: Maytag Atlantis Electric Dryer
Fly, sounds like you blew the thermal fuse. This is located on the front blower. You will need to remove door by removing the two screws and lifting up on the hinge. Remove the 2 spacers on the other side of the door. Now the panel will pull out and the blower will be exposed. The fuse will look like the one on the right of the attached picture....Catriver..post back.
Posted on Jan 27, 2007
SOURCE: Removing Timer Knob on Maytag MDE7400AYW dryer
I was having the same problem until I figured out that you can remove the front part of the knob by gently prying the silver/gray cover away from the rubber ring part of the knob. Once you remove the front part the rest of the knob can be removed.
Posted on Jun 03, 2008
  • 4 Answers
SOURCE: maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Posted on Nov 01, 2008
  • 16 Answers
SOURCE: Dryer won't start when knob is pulled.
If you push the knob to the left and it makes a good contact and starts the machine, then replace the timer switch. Write down the Name and Model Number of the machine (usually on or below the door)
take it to a local appliance shop and order a new part. When you recieve the new part UNPLUG the machine and remove the three screws from of the top of the electrical compartment and gently pull o the front open, there is only one plug attached to the switch, remove it and dislodge the old switch, then snap the new switch in place and replace the plug, close the compartment and replace the three screws, plug in the dryer, and try it.
Posted on Apr 11, 2009
SOURCE: Maytag Atlantis Dryer pull-knob won't start dryer
sad!! To Say!! It's a bad Timer!!
Maytag went cheap on there Timers!!!!!!!!!!!
I Work on them and have been in a few homes and had to replace them even less then a year old!!!!!!!!!!!!!
Posted on Sep 13, 2009
Testimonial: "Thanks for the quick feedback! I will look for a replacement timer"
Maytag Atlantis Series MDE6400AYW -- Current is good, brand new power cord, drum light comes on -- When I turn the timer, I can hear it clicking, but nothing else works.
You need a thermal fuse and check the venting heat is backing up causing the fuse to blow fuse part number 307473 located on the back remove back panel to gain access
May 30, 2015 | Maytag Dryers
Sep 13, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Dryer doesn't work,electric has been checked I
You dont need to check motor first. start from door switch. check the continuity of the switch if not making a peep sound when you press the button replace the switch button.
Apr 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My maytag MDE6400AYW was getting more and more difficult to start. I could pull the knob in different directions to start it, but now it wont start at all. I removed the starter, then the panel, then the...
no way around replacing the timer now. dont think youll get a rebuild diagram on this they come sealed form the factory, problem is they build these cheap a** timers with pull starts in them and they do have a tendency to fail.
Mar 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
MAYTAG ATLANTIS DRYER TIMER SWITCH
the key is to dismantle the font ofthe knob assy( the small plastic center of knob pulls out) it also acts as a locking ring /clip to hold unto the new timer shaft
Mar 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
How to remove control knob on maytag mde8400ayw timer
youll need to "pop" the center of the dryer knob off, the outer mos part of the knobin which oyou turn is a false front, that actually locks the knob onto the timer shaft, use a small screw driver to pry it off
Jan 25, 2009 | Maytag Atlantis MDE8400AY Electric...
Maytag atlantis dryer model # mde6400ayw
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Dryer won't run
Aug 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Mar 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
191 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
