Question about Dell (S423) for Dimension 8100 (3F546) Motherboard
DELL 8100 HASENT BEEN USED IN A COUPLE OF YEARS PLUGGED IT IN AND ALL I GET IS A FLASHING YELLOW LIGHT
    President:
  • 1,768 Answers
1. check the CMOS battery and replace it
If it shows 3.5 or lower then it is in need of replacement and you board should work
if not a new mother board is needed.
2. check your power supply unit it may need replacement as well.
I hope this helps. Have a great day!
Posted on Oct 05, 2010
Dell Dimension 8100 Power On Reset Problem
Hi, Considering that this motherboard/model is a couple of years, it may be possible that: 1. Components have changed value seriously affecting performance. Predominant are capacitors near the CPU that have blisters, swollen or lost part of or completely its storage capacity. Next in line would be resistors and regulators specially those close to the memory slots. 2. If you have any USB device connected, try removing them while booting; 3. BIOS may be outdated/corrupt, flash the BIOS to the latest firmware if and when you were able to boot it up using the fdd (pls be informed of the inherent possible failure when flashing). On your other concerns: a. "...reset jumper..." - temporarily short the RTCRST pins near the battery. You may also try moving the PSWD from its default position (enabled) to disabled; b. "...pinouts on front panel ribbon cable connector..." sorry even the Dell site that I have access does not have info. It might be a bit difficult getting a replacement motherboard being a socket 423. Another item to be taken into consideration is that your motherboard still uses PC800 RDRAM 184-pin RIMM Memory. To sum, if you will replace the motherboard, chances are you will also have to replace the processor and memory. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 20, 2007 | Dell (S423) for Dimension 8100 (3F546)...
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell latitude D600 battery charge light flashing
Go to support.dell.com and download the latest bios firmware to update it. If it still does not work then most likely it is already a hardware issue so you need to contact dell support for the hardware issue.
Jun 03, 2009 | Dell Latitude D600 Notebook
Start button flashes yellow - will not turn on
I have found that if the CMOS battery is removed and the unit unpluged for 5 mins (reseting the unit to default config) It will restart. The battery should not be replaced thus to maintain your date and time settings, it shoud not be unpluged for long periods.
Apr 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
Well when I turn on my ps3 the green light turns into a yellow light some people call this the yellow light of death after it goes yellow it turns into a flashing red light I try to repaet it but it keeps...
well yes obviously the flashing red light means that if u do not turn off ur PS3 it will die. but depending on how long u have had ur PS3, it may be becuase the life span is almost over.
if u have not had for a couple years it is most likely a manufacturing error
u should send it in to sony before the warranty is up and have them take a look at it
Jul 25, 2008 | Video Game Consoles & Games
Power on/boot-up problem
Have I got a story for you? Dell inadvertently used some defective capacitors in their Optiplex motherboards and some power supplies. From what I?ve experienced and read this affects the Optiplex 270 and early 280 lines. In my case my systems had video display problems and eventually ended up not booting. The giveaway is looking at the large 150 uf capacitors; they are the larger ones usually with an ?X? inscribed on the top. If the tops of the capacitors are flat you?re out of luck but if any of them are bulging (even slightly) at the top, leaking electrolyte or split Dell will replace the motherboard for free. This program is in effect till 2008. I wouldn?t recommend pulling the power supply apart but the flashing yellow power light for me has been a failed power supply. I would check out the motherboard for bad capacitors then call Dell. It?s likely they will replace the power supply if it?s in warranty, perhaps even if its out in light of the capacitor issue. If you?ve got some rounded caps on the motherboard I would also ask them to replace that as well. Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 30, 2007 | Dell OptiPlex GX270 PC Desktop
Dell (S423) for Dimension 8100 (3F546) Motherboard Logo
107 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
