Question about GE Caf? 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Stainless-Steel
We have a ge model GSS25tgm side by side refridgerator that recently the fridge side has been freezing things, we turned the temp down to a 4 setting and still things freezing. We do have dogs so we pulled it out and cleaned all the dog hair out from behind the panel. Still temp too cold. Any suggestions
the dr
  • 447 Answers
SOURCE: Refrigerator and freezer are warm (Kenmore model 59676509500)
if there is frost on the back wall of the freezer than its iced over (the automatic defrost cycle has failed) turn off the fridge for 18-24 hrs with freezer door open and the ice will melt and it will begin to cool again. It takes a long time for the ice behind the back wall to thouruoghly melt, if it isnt all the way defrosted you will end up with soild ice insead of frost and that will take even longer to thaw Dont forget to rate my solution as solved if I accurately answered your question...Thanks!!
Posted on Oct 01, 2007
Bgillespie
  • 89 Answers
SOURCE: GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Posted on Dec 17, 2007
SOURCE: ge side by side not cold enough in fridge or freezer
the fan behind the freezer panel inside
Posted on May 31, 2008
aborcass
  • 2651 Answers
SOURCE: Cleaning the coils under under side by side kitchen aid fridge
you can purchase a refrigeration coil brush ( looks like a baby bottle brush only 2-3 feet long, for about 10 bucks at the local hardware store. this will fit inbetween the coils
Posted on Mar 28, 2009
  • 2006 Answers
SOURCE: MY GE TFX30PRY still cools but doesn't get
Since you say that it still cools, you need to start out with a thorough cleaning of the condenser grill. If it the air flow is blocked or the condenser grill is extremely dirty or clogged with pet hair, then the unit won't be able to dispel the heat buildup cause by the coolant running through the compressor.
I have found that if you use an air compressor blowing from the rear and a vacuum from the front works pretty good.
Posted on Oct 07, 2011
Side by side refridgerator is freezing things
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Check the air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this will help in solving the problem....
Jun 16, 2011 | GE Refrigerators
Have a GE side-by-side profile 25.4. The fridge side is too cold and freezing items in back of top shelf and items in the veggie draw. Settings are 4 for freezer and 2 for fridge and things still are...
there is a air damper that lets the air in frome the freezer side,, it should be in the back top left corner on the fridge side turn the controls to off and listen you should hear a faint sound like a flap closing,, if not it is either stuck wide open, or the little motor has went out,,,( for a temp fix you can tape some of the opening off until you get the parts replaced
Jan 19, 2011 | GE Profile 25.5 Cu. Ft. Side-by-Side...
My GE profile side by side refrigerator's temperature is not staying where I put it. It keeps popping to 31 degrees when I set it for 37 degrees. My food is freezing !!
It may need to defrost. Shut it off for 4-5 hours to let any accumulated ice to defrost and see what happens.
There also is a control that directs more cooling to the refridgerator or the freezer compartment. It may need to be readjusted. It will take 24 hours to stabilize.
Oct 20, 2009 | Refrigerators
GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Ge refridgerator model gsl25jfpe bs
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Jul 19, 2008 | Refrigerators
GE Caf? 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice and Water - Stainless-Steel Logo
70 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
