Question about Skull Candy Skullcrushers Headset
The plug is broken. how do i fix that? - Skull Candy Skullcrushers Headset
  • 667 Answers
Yes sir
Posted on Oct 08, 2010
Dodge 1999 neon headlight broken something is broken
dont tack it back cause they will say that you broke it and you fixed it. just try and replace the light housing and your plug
Jan 18, 2014 | 1999 Dodge Neon
I broke a spark plug clean off on my yamaha 2004 1100 fix. How can I get it out please help
You may be able to use a screw extractor or easy-out to remove the broken plug. It can be tricky to get it started but should work. Here is a pic to give you a better idea.764a103c-68d3-4911-ba92-3403344a12d4.jpg
Oct 16, 2013 | Motorcycles
Electrical plug is broken
Electrical plug that is broken can be fixed however it is no longer safe to use..Electrical current may leak while holding the plug that might cause electrical shock.It is better to replace it with a new one.If the plug can be remove using a screw or if it just fixed using a bolt then you can just buy a new socket or plug.That helps you lessen your expenses.Hope this helps..
Jun 20, 2011 | Dualit Kitchen Appliances - Others
No sound coming from left ear initially, now no sound at all.
Sorry, it's probably not fixable. The wires are either broken internally or have become detached from the solder fixings and the headphones are not designed to be repaired, nor are spare parts available.
The only exception is if the plug on the end is broken or has broken wires. Wiggle the wire at the plug end only whilst wearing the cans. If you get sound, then identify where the wire has broken and cut the plug off at that point. Strip the wires, correctly identify the left and right conductors and fit a replacement plug using soldered connections. Ensure that the screening sheath is correctly soldered to the casing (it's the earth connection for both conductors) and close the new plug casing.
In practice, it's fiddly, and only to be done if you're confident with a soldering iron. If not, just do as Philips intended and bin your old cans and buy new: it's not as if the SBCHP430/00 was an expensive model to start with.
Feb 16, 2011 | Philips SBCHP43000 Headphones
Broken power button jack/plug on apple mini mac (post 2009 intel)
Not sure about schematics but here are a couple links to disassembly guides:
<http://www.applefritter.com/Mac_Mini_Take_Apart_Guide>
<http://www.r3uk.com/index.php/tech-tips/34-disassembly-guides/4-apple-mac-mini-model-a1170-disassembly-guide>
Also,
Check this site out <http://www.123macmini.com/news/story/316.html>
Good luck.
K.
Dec 20, 2009 | Apple Mac mini
The low input plug on my logic soundlab cpx1820 is broken.
Hello lucky33irish,
If it is just the plug that is broken, it's a rather easy fix. Just solder on a new plug. Look closely at the old one to make sure that you match up the wires correctly. You can get replacement plugs at Radio Shack or try this web site. I like the Switchcraft 3502. It's very durable and easy to work with.
http://www.mcmelectronics.com/
A better fix would be to replace the cables with a new set of RCA's.
If the pin from the old plug is broken off inside the jack, you'll need to remove it. I usually start with a scratch awl and gently pry the old pin backwards until I can get ahold of it with a pair of needle nose pliers. Just be careful that you don't push it in deeper.
Anyway, hope this helps.
Apr 02, 2009 | Logic Soundlab CPX1820 Car Audio Amplifier
Spark Plug Cap is Broken
Hi freedom
Use a pair of pliers to crimp the plug wire terminal so it fits snugly on the sparkplug.
best regards savunihai71
Dec 20, 2008 | Electrical Supplies
Plastic part broke off my super nintendo where you plug the power cord in the back.
This is a common problem with the original version of the SNES console.
Unfortunately the fix is not an easy one. I fix these in my shop but I have done dozens of them. It requires soldering. There are two ways to fix it. You can replace the broken part which is soldered to the motherboard or you can solder on wires for a new receptacle.
To get the replacement part you would need to buy a broken SNES off eBay or somewhere and disassemble it to remove the needed part. If you find a busted SNES with a working motherboard you MIGHT be able to just swap it. I say might because I have found at least three versions of motherboards in these things and the mounting points inside the case are different for each of them.
To bypass the plug altogether you would need to find a new plug at Radio Shack and wire it up to the motherboard and attach it to the case so that the plug can be hooked up. You could also cut the plug off of the AC adapter and solder the adapter wires directly to the motherboard.
Like I said it is not an easy fix. It also has a high probability of not working if you do not know what you are doing. It might be best to just buy a working console from a reputable seller and sell yours as broken.
Good Luck.
Mar 02, 2008 | Nintendo Super NES Console
Flash drivers
it depends how it is broken. you might be able to replace the USB connector and have it fixed again.
Sep 05, 2007 | Imation (01946) External Floppy Drive
Skull Candy Skullcrushers Headset Logo
162 people viewed this question
Top Skull Candy Radio Communications Experts
 Grubhead
Grubhead
woodzowl307
Michael Harrier
Are you a Skull Candy Radio Communication Expert? Answer questions, earn points and help others
