Question about Scytek ASTRA 7T7 Alarm Security System w/ LCD Remote Control
I replaced the brain for my astra 777. Now when my alarm is tampered with all activity becomes inactive. The only function I have is if I get within inches of my antenna I can unarm it. I also have the LCD two way transmitter and since I put my new brain in it will only arm, remote start, and release my trunk it won't disarm or unlock my car. The regular transmitter has all functions
How do I fix a jammed battery compartment in a kidde i12060 smoke detector?
You could try to pry the door loose with a small screwdriver. To be safe, make sure the primary 110V power is turned off before trying to loosen the compartment door.
This is an inexpensive unit, less than $10, and is easily replaced if you can't get the door open.
If you do decide to replace it, you may want to look into a combination unit which monitors smoke and carbon monoxide if you don't have a carbon monoxide detector already in your home.
Aug 26, 2015 | Kidde i12060 Hardwire w/ Front Load...
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
Why do lights flash while on trailer on 2014 street glide
The bike senses movement (like someone is stealing it) and activates the "Smart Security System".
You won't have an actual alarm unless you have the optional alarm installed.
You need to put it in "Transport Mode"
In the transport mode, the Harley-Davidson Smart Security System is armed but the motion detectors are inactive.
The motorcycle can be transported on a trailer without activating the alarm while the starter and ignition remain disabled.
Here's a video how:
http://www.youtube.com/watch?v=tA35I8RWI_s
And written instructions:
With an assigned fob within range, turn the ignition switch to IGNITION.
Before the security system lamp goes out, turn the ignition switch to OFF.
Within three seconds, simultaneously press both the left and the right turn signal switches.
After the turn signals flash once, the system enters the transport mode.
With the fob removed, the motorcycle can be moved without setting off the alarm.
May 18, 2014 | Harley Davidson FLHX Street Glide...
Gardtec 370 repetitive bb tamper alarm
Yes any bell box will do. Just note your terminals.
you can link out the bellbox tamper from the control panel as a temporary measure until you replace the bellbox, assuming its faulty
Apr 12, 2014 | Home Security
LIGHTS DONT FLASH WHEN ACTIVATING THE ARLARM
I thought mine were burnt out. Turns out i had accidently set the dimmer to off on the radar.
Nov 24, 2013 | Vehicle Parts & Accessories
2005 ford escape need alarm sensor location
This is not like an aftermarket alarm. It is built into the main computer and uses both the horn and the lights to sound a warning. The keyswitch has a reader and the ignition key must match the frequency recorded in the brain of the vehicle. It also kills the power to the starter and some even kill the ignition.
A shorted Battery will trigger the alarm, so have it fully tested. The reader and the wiring to the brain could also have a break in them, triggering the system. Sometimes worn ignition switches will lose contact with the key inside the switch.
The alarm is engineered to render the car immobile if tampered with. But a Dealer can Electronically recode a new Chip key to match
Sep 02, 2012 | 2005 Ford Escape XLT
I have a MOD 600 alarm, installed about 9 years ago. Every time I pass a sensor the alarm makes three beeps. How do I stop it?
Hello. This is a normal response to the motions detector while people are active within the home.
The alarm is a semi active mode that is the motions detector will beep, if a door is open there could be active voice alarm or beeping from Central alarm within the home. The same will happen if a window is opened, beep,beep,beep.
In this mode it lets the home owner while in his/her home that the alarm is on and it will let you know when the doors, windows or floor pressure sensor is activated.
There another mode for the alarm system that is if you have pets. It can be activated that only things that are inactive is the motion and pressure sensors. They beep but will not execute the full alarm system.
The there is full alarm system activation where every sensor is operational----full Alarm On....
Now, if you don't like the beeping, then you can turn the alarm system off while you or your husband is in the home. But it will not notify you if the door, window, motion, pressure sensor are activated. I hope this help you. GB....stewbison
Aug 24, 2011 | Kitchen Ranges
I FIND TWO LAN CONNECTIONS IN MY NETWORK PANEL. THOUGH ONLY ONE IS ACTIVE AND OTHER IS NOT. WHEN I TRY TO DELETE THE OTHER INACTIVE CONNECTION IT GETS DELETED BUT REAPPEARS IN THE NEXT BOOT. I EVEN TRIED...
You cannot effectively delete ? Local Area Connection as it corresponds to a network device that is present on your computer.
It doesn't matter though, as it should not tamper with the active network connections. It you really want the inactive connection to not appear, you must deactivate the corresponding network interface in the Device Manager.
May 13, 2011 | Computers & Internet
Scurity penal temper
seems one of your tamper swicthes has been activated,you should be able to isolate which one is needing attention and mute the sounder too
It is common for the tampers to fail in very moist conditions ie outside siren boxs exposed to the elements or a rodent has chewed thru your wiring
i could be a simple as a spider sitting on the tyamper switch in side the box.
If your alarm is monitored then you will have to call an alarm company to fix this for you unless you have the right skills to trace isolate and repair this problem,
May 26, 2010 | GE Security GBC-PI-950-P5 Pir Camera...
Unlike before, now my astra 777 only unlocks the
may be a loose wire on the remote locking system, cheers
Dec 12, 2009 | Scytek Electronics ASTRA777 Car Alarm 1 Cf...
Scytek ASTRA 7T7 Alarm Security System w/ LCD Remote Control Logo
133 people viewed this question
Top Astra Vehicle Parts & Accessories Experts
xxxxxx xxx
Alan Springett
Are you an Astra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
