Question about IBM 4232 Matrix Printer
I have a ibm 4234 with error code 89 what does that mean?
Ibm error codes
Print Band and sensor need cleaning or replacement.
Jul 25, 2014 | IBM 4234-02 4234-2 Dot Band Printer for...
IBM TS3200 Code 9F 08
The manual is online with IBM.
Chapter 8 explains the error codes and 9F (mean Error code) means Rotation range out of specification 08 9sub error code) means error during rotation initialisation, get range failed.
Then the manual says: "Isolating a library controller card versus accessor enclosure problem" on page 7-11
But I guess you better look it up yourself. If you don't have any parts, you have to contact IBM.
Look yourself? start in chapter 8, page 225 of the manual under this link.
http://publibfp.dhe.ibm.com/epubs/pdf/a320545c.pdf
Feb 16, 2014 | IBM System Storage TS3200 Tape Library...
Is there a driver for Windows XP for the IBM 4234 SCS printer?
Download a PDF file from IBM:
ftp://service.boulder.ibm.com/printers/pdf/G544-5283-08.pdf
The printer "emulates" several common printers that are supported by Windows XP.
Aug 20, 2010 | IBM 4232 Matrix Printer
I am getting an error code of 00161 and 00163 on my ibm think pad 2635
Error code 161 means your CMOS battery is dead and 163 is that system date and time are not set (which make sense as the CMOS battery is dead).
You need to replaced your CMOS motherboard battery to resolved this issue.
May 19, 2010 | IBM ThinkPad 380ED
The machine give code 066 board fail
Don't know what this error code means exactly but going off the word 'board', I would think it would mean there is an issue with the motherboard(s).
If you call the manufacturer of this printer, they will identify what error code 066 means exactly.
Feb 17, 2010 | IBM 4230 Model 102 Matrix Printer
When i swithch on the monitor is blank and there are two short beeps. Also the numbers 1 2 and 3 are lit in the tower front
The two short beeps are probably a POST (Power On Self Test) code. These have been in use since the first PC was manufactured by IBM, and other manufacturers decided to let IBM's POST codes be the standard for PC clones for several years. AMI, a BIOS chip manufacturer later came up with their own. Since then other manufacturers have strayed form the IBM fold, also.
For more info, go to <a href="http://en.wikipedia.org/wiki/Power-on_self-test">http://en.wikipedia.org/wiki/Power-on_self-test</a>.
Your 2 beeps in IBM POST code mean: POST error, see code on screen (code 123 means "system board error"). Not a lot of help!
Your 2 beeps in AMI BIOS POST code means a Base Memory Parity Error (bad memory chip in lower 64k of RAM).
The 123 display on the tower may NOT be the IBM POST error code, but something else. As reets-tech implies, you probably will only be able to get a definitive interpretation from your computer's manufacturer or one of their authorized repair facilities (if any). Good luck!
Jul 08, 2009 | Computers & Internet
4234 print wrong column
if you are seeing letter or print ghosting the printhead might need to be replaced.
Nov 20, 2008 | IBM 4232 Matrix Printer
Bar code
try changing the chacters per line, print out a config page and towards the bottom of this it will state the current settings
Jul 15, 2008 | IBM Infoprint 6500 Matrix Printer
IBM Infoprint 21- 651 HW error
Look in Printer Manual (usually in the back) for error codes.
Try cycling power including unplugging AC cord from printer for 1/2 hour.
Apr 25, 2008 | IBM Infoprint 21 Laser Printer
IBM 4232 Matrix Printer Logo
372 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
