Question about Gigabyte GA-8VM533 Motherboard
Cpu fan operates but that is all! Has a 2.8g celeron cpu and 256 meg of ddr ram. please help if poss.
  • Gigabyte Master
  • 27,725 Answers
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
while your at it
clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making VERY sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
hope this helps
Posted on Oct 05, 2010
Dc5100 processor upgrade
NO!
Two Netburst based Processor cores on the SAME chipset?
Get outta' here!
When did they come up with that?
OH, I'M JUS KIDDIN'!
http://h18000.www1.hp.com/products/quickspecs/12145_na/12145_na.HTML
The HP Compaq dc5100 Desktop PC uses an Intel 915GV motherboard chipset.
Since we know that the Northbridge chip, of the motherboard chipset; handles the Faster capabilities of a computer;
i.e., Processor, Ram Memory, and HIGH-speed graphics; let's look at the Intel 915GV chipset,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_chipsets
No sir/ma'am.
The Intel 915GV motherboard chipset only handles Single Core processors;
Intel Pentium 4,
and,
Intel Celeron,
and,
Intel Celeron D.
(With a 533MegaHertz Front Side Bus, or an 800MHz FSB)
The Celeron D is NOT a dual core processor,
http://en.wikipedia.org/wiki/Celeron#Prescott-256
"The D suffix actually has no official designation, and does not indicate that these models are dual-core. It is used simply to distinguish this line of Celeron from the previous, lower performing Northwood and Willamette series, and also from the mobile series, the Celeron M (which also uses 3xx model numbers) Unlike the Pentium D, the Celeron D is Not a dual core processor."
Yeah, I know. I'm just a 'Ray of Sunshine'.
You know you can pick up a motherboard pretty cheap nowadays, that WILL support the lowly Pentium D, for not much money.
Problem is you will need to replace Ram Memory also.
By the time you get a motherboard chipset that supports dual core Processors (CPU), you are going to be using DDR2 Sdram ram memory, instead of the DDR Sdram ram memory you are using now.
OK, Motherboard, CPU, and Ram Memory.
Oh, the Power Supply. Won't do either.
240 Watt unit, or 300 Watt unit?
Sure.............OK.
Back in the day those Power Supply's were made, Power Supply manufacturer's were 'fudging' the actual maximum rated Wattage.
True Wattage was more like 60 to 70 percent of what was stated.
Why?
SOLD more Power Supply's.
240 Watts?
Simply divide by 10. = 24.
For 60 percent, take 60 times 24. = 144 Watts
70 percent? 168 Watts.
300 Watts?
60 percent is 180 Watts.
70 percent is 210 Watts.
I wouldn't try to run a Barbie doll with that low a Wattage, of Power Supply. (Barbie doll? What?)
Need at least a decent 350 Watt power supply, from today's manufacturers.
80 percent constant duty cycle, for most good units; or higher.
So...............
Max out the Intel Pentium 4 CPU.
4GB's of 533MHz DDR Sdram ram memory.
(PC4200, or PC4300. Depends on the manufacturer as to how they name it)
By the time you spend that much money, you may as well buy another Motherboard, Processor, Ram Memory, and Power Supply.
Yes, may as well buy a better computer.
I know. Quit trying to cheer you up.
Around here we have Craigslist, and Ebay, for two places.
Could pick up a better computer, for around the same money, as you would pay for all the upgrade parts above.
Which is better? Upgrade the Processor, or upgrade the Ram Memory/
For the better 'Bang for the Buck', upgrade the Ram Memory.
The CPU (Processor) has a built-in cache.
L1 cache, and L2 cache. (Newer CPU's have an L3 cache)
The Cache is a small memory area for the CPU.
It is the FIRST memory area the Processor (CPU) reads.
This is because it operates at the same frequency rate, as the CPU does.
(Frequency rate = 'Speed'. Operates at the same 'Speed')
Next inline is the Ram Memory.
Ram Memory -> typically, operates at half of the Processor's Front Side Bus. (FSB)
This is why upgrading Ram Memory is a good idea.
It isn't so much of getting Ram Memory, that operates at a higher frequency rate ('Speed'), as it is to have MORE ram memory.
Example;
PC3200 compared to PC4200.
4GB's of PC3200 is better than 2GB's of PC4200.
(DDR Sdram at 400MHz = PC3200)
Moving on............
Motherboard chipset:
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The motherboard chipset for your computer, consists of a Northbridge chip, and a Southbridge chip.
{Motherboards that support the Intel Core i technology, (Core i3, Core i5, Core i7, etc), do NOT use this motherboard chipset technology. Neither do some of the AMD CPU's }
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
As stated previously, the Northbridge chip handles the Faster capabilities of a computer;
Processor (CPU), Ram Memory, and HIGH-speed graphics.
The AGP technology, and the PCI Express technology; ARE high-speed graphics.
Using a graphics card in a PCI slot, or using Integrated Graphics; is NOT high-speed graphics.
The slower capabilities of a computer are handled by the Southbridge chip.
1) PCI Bus / Integrated Graphics.
(Another term for Integrated Graphics, is OnBoard Graphics. A term that seems to have gotten lost.
It explains better; ON the motherBOARD )
2) IDE Bus
3) SATA Bus
4) USB Bus
5) Ethernet
6) Audio (Sound)
Point?
Look to see what the Northbridge chip is, as I have shown you; and you'll get a good idea of what Processor (CPU) support is.
For additional questions please post in a Comment.
Regards,
joecoolvette
(I get tired of looking on websites, that just say NO, and do not explain why )
Mar 06, 2013 | HP Compaq dc5100 PC Desktop
Is W7 compatible with p4s800d x mobo
If you have an operating system on your computer you should download and run the "Windows 7 Upgrade Advisor" available from the microsoft website.
Feb 27, 2013 | ASUS P4S800D-X Motherboard
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Why my mother boarb ASUS P5P800S did not run for DDR 400 I want computer more faster my DDR I used now is only 256
hi, actually that 400 is not the ram speed. its the ram frequency. DDR ram comes in 3 types of frequency. one is 333hz and another is 400hz. normally people use 400hz. you should not put two kinds of RAM modules with different frequency at same time.
make sure. all the rams you are using are of same speed and same frequency. example use 256 of 400hz with 256 of 400hz. this must help. else revert back to us. thank you sweet rascal
Oct 18, 2009 | ASUS P5P800S Motherboard
What is the hidhest ram i can use on a celeron 2.6
Hi. The amount of memory that can be installed is limited by the motherboard, not the CPU. That being said, the motherboard you have listed will take the following memory:
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.
Sep 28, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
HELP with with Intel celeron d 325
Phew, k3! A ton of questions and even more confusion going on here!
Firstly (love that non-word), your Motherboard accepts DDR Ram. Unfortunately, DDR2 will not be compatible. Won't work. Sorry. It does accept up to 2gb of DDR Ram, though.
Second, for Graphic Card slots, it has 3 x PCI slots (NOT PCI-Express), which are great for G-Cards. Maximum amount of memory won;t be affected by your MB, but by your processor and ram. As long as it has a PCI slot for a PCI card, you'll be good. Just be sure to turn off integrated graphics in BIOS settings.
Thirdly, good luck. Opening up the side of your PC can be daunting at first. Ensure you either have the patience to learn before you touch or have the money to continue learning as you go. >.o
Mar 01, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
My name is Siavosh Eskandari. I have a desk top PC Compaq presario Desktop with Intel celeron processor 2.7 HHz Model SR1010NX, Prod. # DW25AA-ABA,Serial # MXK4180P8Y with 256 MB PC 2100 DDR SDRAM. The...
the model SR1010NX can take upto 1gb max of ddr 1 ram and must be done a 2x 512 ddr 1 chips
Memory Component Attributes Memory Installed 256 MB (1 x 256) Maximum allowed 1 GB (2 x 512 MB) requires the replacement of the installed 256MB DIMM Speed supported PC2700 MB/sec (messages at PC2100 Type 184 pin, DDR1-333 SDRAM DIMM slots Two
Nov 28, 2008 | HP Computers & Internet
Gigabyte GA-8VM533 Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
