Question about Canon PIXMA MP240 All-In-One InkJet Printer
Hello, my name is Kyle. My printer keeps eating paper when going to print. I checked the inside of the tray and found a pen lodged inside, but it still jams. An error message E2 comes up.
  • 4 Answers
There will still be something jammed in the path. You may need to lift up the paper guides to see it - even to the trained eye it can take a few minutes to spot.
Posted on Oct 06, 2010
Hp 2515 no paper on tray but indicating fake paper jam
May i know the printer model # / name ( full ) to assist you better. ?
Mar 24, 2014 | HP Officejet Pro L7680 All-In-One Printer
The paper in the rear tray is getting pulled in crooked, therefore the paper sometimes rips on the side and the image is not straight. I tried running all the printers tests, and I even found many posts...
Had the same problem myself , ONCE. You have to make sure that the paper is completley straight in the feeder. And make sure that the sheet holders are at the right size, ie, Close to the paper, well not close but touching.
You may also have something else in the sheet feeder. Took me a week to sort my problem found out that a pen had got slipped into sheet feeder.
Hope this helps..
Apr 07, 2011 | Canon PIXMA MX330 Office All In One...
On the top of the hp 2015 there is what looks like an 8 with like a sideways N next to it that keeps lighting up on my printer and inhibiting it from printing-- I don't have a manual to tell me what means.
Hello, The printer is indicating a Paper Jam.
Check the tray for proper paper loading, length and width. Check the rear exit, any paper back there? Check under the toner cartridge for loose papers.
1) Turn the printer off 2) Remove the main paper tray 3) look inside the hole in the printer from where the tray came out. You should see black rubber roller. paper dust can build up on this roller and cause the paper to slip. You can wipe this roller down with a water dampened lint free cloth, 4) Re-insert the tray, with paper in the tray. 6) Turn the power on to the printer. 7) Does the printer come ready? Print a test page.
For further information GOHERE
Feb 03, 2011 | HP LaserJet P2015 Printer
Printer will not feed. Using plain paper, as I have for a long time. Turned off printer and tried again, nothing. Makes the feeding noise. Ink is full.
Check and see if a pen or pencil has fallen down into the paper tray. That's what happened to me, and my paper wouldn't feed. The pen had rolled way down inside and was hard to see and hard to get it out of there. I actually found it by feeling around and then I felt something that felt oddly like a pen cap! I could barely see it in there, so check it good.
Jan 29, 2010 | Canon i9100 InkJet Photo Printer
Canon MP830: Error Code 6A00
Sir,
I think there is a piece of torn paper lodged inside due to carriage is stuck, try to do manually moving the carriage and also blow some compressed air around hoping to clear any foreign objects. Opened top manually. Moved print heads to left. About one inch from the right wall on the floor of printer are two soft spongy rectangular pads sitting in two abutting small trays. With the end of a ballpoint pen, pulled the right tray toward the front of the printer and the whole assembly snapped into place.
Thanks Good Luck
Sep 14, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Trouble photo printing
hello.. try to unplug the power cord and usb cord and replug again and also chick the inside part of your printer maybe have a paper jump or ashes due to saying of of paper or try to remove the printer driver software how to remove? go to control panel and click the name (ad and remove program )and you can see the currently install files find your printer driver bellow the currently install files and remove it and install again..........thank you hope i can help you.. have a good day
Jul 06, 2009 | HP Photosmart C6280 Printer
Keeps reseting to Tray 1
Printer Defaults button? what magical land is that found in?
Here is the real solution:
In Printers and Faxes, right-click the printer
Click Printing Preferences
In Paper Source drop down, select Tray 2.
Peace!!
d(-_-)b
May 14, 2009 | HP Office Equipment & Supplies
I have an MP210 Canon printer.  It is saying E 3.  The alarm light is on.  When I try to print, it says there's a paper jam; there isn't.  Help?
i had this problem, i was convinced that there was no paper stuck in it, and in my frustration i ended up tilting it backwards and banging it on the table. i found a pen was lodged in the paper feeder. I was so relieved, until the error code was still flashing. then i stuck my hand down the paper feeder (take the paper out first) and found the smallest piece of paper stuck in it. try this.
i am so relieved.
Dec 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Cannot print
If this is a 2200dtn, have you checked the duplex turn around tray under the printer? You can access this by removing tray 2, inside on the front left you should see a small green tab which will release a drop down tray. Many times a sheet or even just a piece of paper can get lodged in the sensor causing a paper jam condition.
Nov 21, 2008 | HP LaserJet 2200dtn Printer
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Canon PIXMA MP240 All-In-One InkJet Printer Logo
274 people viewed this question
old marine
old marine
