Question about D-Link AirPlus DI-524 Wireless Router
How do I reconfigure my router once I have hit the reset button
  • 2,260 Answers
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on Oct 05, 2010
I want to reset my stc internet connection password
Hello elmer_mid347,
These are instructions:
To Reset and Restore the "Router Password."
The first thing you want to do is to "Reset" the Router's configurations.
To factory defaults settings.
First, hold the reset button on the router for 30 seconds.
Once your router resets, you will need to Login and reconfigure it again.
To reconfigure your "Router!
"Connect the Computer to one of the Ethernet Ports.
Next, type in your Web Browser: http://192.168.1.1
You will be asks you to enter: "Username and Password, to log-in, to your router."
You can also, use the Router's ("Default Password"), which is; admin.
"You should be able to reconfigure the "Router."
Next, go to the Management (Tab) to change the Administrator's password.
Next, you will need setup the Security for the Router.
"Select to ("Enable") the "Security Codes," example: WEP..."
"This should change, and 'reset' the password!
If you need help with anything else?
Write a 'comment'; I'll be here to assist you!
"Best Regards"
Aug 05, 2011 | Computers & Internet
Tip
How to Configure your Linksys router with wireless security
Launch your Internet Explorer, Netscape or your Mozilla.
On the Address, Search or URL, type: http://192.168.1.1, then hit Enter/Return. A login screen will appear. Type admin for the password and leave the username blank or empty then hit “OK”.
Note: If it doesn’t take admin as the password you might have changed it when you have ran the RUN ME FIRST CD that came with the router so try other passwords.
If you cannot remember the password, I regret to tell you but, you have to reset the router and, reconfigure it again. Next time, remember the password to avoid unnecessary reset and reconfiguration.
To reset the router to factory default
1] Press and hold the reset button for 30 sec., after that
2] Unplug the power keep holding down the reset button for another 30 sec.
3] Then, plug back the power keep holding down the reset button for 30sec., after that
4] Release the reset button.
Note: Configuring WEP in the router varies depending on the model number and firmware version of your Linksys Router.
Cisco Interface (If your Setup page has a Cisco Logo)
Go to Wireless Tab > Wireless Security > Click the drop down arrow then select WEP:
Regular Linksys Router Interface (If your Setup page has a no Cisco Logo)
Under Setup > Click WEP Key Settings or Edit WEP Key Settings
Using passphrase 64bit
Encryption LEVEL 64bit > type a passphrase > click Generate > copy key1 on a piece of paper (10hex character). Then hit Apply or Save Settings.
For manual key entry of 64bit encryption:
Encryption LEVEL: 64bit > Under Key 1 type a 10 digit character from A-F and 0-9.
(e.g.: A0B3F58C9E, 0123456789, ABCDEFABCD). Then hit Apply or Save Settings.
Using passphrase 128bit
Encryption LEVEL128bit > type a passphrase > click Generate > copy key1 on a piece of paper (26hex character). Then hit Apply or Save Settings.
For manual key entry of 128bit encryption:
Encryption LEVEL: 128bit > Under Key 1 type a 26 digit character from A-F and 0-9.
(e.g.:0123456789ABCDEF9874561230, 012345678901234567890123456, ABCDEFABCDABCDEFABCDABCDEF).
If you want better security for Vista computers, you may want to select WPA personal (WPA-PSK) under security > set the Algorithm to TKIP and type your personal security code (any code you want, any characters)
on Jan 06, 2010 | Computers & Internet
I lost my password to my dir-601 router and need it for an Ipod to run of my wireless net. How can I find it? I have the security code. Thanks
You have several options. However, I'm unsure if you have lost the username/password to access your D-Link router's setup/configuration page or if you have lost your wireless access code (used to access your wireless internet).
If you have lost your username/password to your routers setup/configuration page first try the factory default combination.
The default username is: admin
The default password leave blank
If you have customized the username and password during the original install you will have to reset the router to its factory default settings. To do this:
PLEASE NOT THAT BY DOING THIS YOUR ROUTER WILL BE RESET TO FACTORY DEFAULT AND WILL HAVE TO BE RECONFIGURED
Locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a
paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is: admin and leave the password box empty.
Please let me know if I can assist you further.
Regards,
KYTechnology
Feb 28, 2011 | D-Link Computers & Internet
I have LINKSYS G 2.4 GHz i can not open with 192.168.1.1 since I have not a valid code. My previous e-mail was che@bahnhof.se an present c.h.ekelof@telia.com
If the router password is not working then you will need to reset the rotuer and reconfigure the router.
Once you reset the router , you will lose all the settings of the router.
Press and hold the reset button on the router for 30 seconds. Release the button and wait for 10 seconds. Now power cycle the router.
Try to access the router using 192.168.1.1. Use admin as a password and leave the user name blank.
Now you will need to reconfigure the router.
Oct 13, 2010 | Linksys AG310 ADSL2+ Gateway with VoIP -...
I got a new computer....cant remember my password to linksy and ofcourse have had linksy so long i no longer own the disk...help
These are instruction to Reset and Restore the “Router Password.”
The first thing you want to do is to “Reset” the Router’s configurations to factory defaults settings, hold the reset button on the router for 30 seconds. jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/GlobalPhoto/Articles/2188502/adminpwd_Full.jpg'); }); Once your router resets, you will need to Login and reconfigure it again.
To reconfigure your “Router” connect the Computer to one of the Ethernet Ports. Next, type in your Web Browser, and go to URL http://192.168.1.1/. “You will be asks you to enter a “Username and Password to login to your router,” or use the router’s (“Default Password”) which is “admin.
“You should be able to reconfigure the “Router.” Next, go to the Management (Tab) to change the Administrator’s password.
Next, you will need setup the Security for the Router, by selecting to (“Enable”) the “Security Codes,” example: WEP “Rating the solution, if it helped? is appreciated, thanks”
Feb 23, 2010 | Linksys Wireless-G WRT54G Router
I dont know my user name and password, what do i do?
Hit the reset button with a small pin once and try with the default username and password as mentioned in the manual. But you may need to reconfigure the device later.
Dec 29, 2009 | D-Link DIR-625 (790069292637) Wireless...
I cant remember my login or password. how do i reset these?
on the back there should be a little hole with reset above it, Get a paper clip or pin and push it in the hole and you will feel a button click in.
Kept it hold down for about 10 seconds and you should see the lights start flashing and your router is then reset. If it doesnt reset the first time, try holding the reset button in a bit longer.
Good Luck :D
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
How do I login to my linksys
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings. To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.Once your router is hard reset, you will need to login and reconfigure it again.To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Apr 09, 2009 | Linksys Wireless-G WRT54G Router
Can see the wireless network, but can not find the password to log on.
Do you know how to access your linksys router? Do you know the password on the linksys router?
If not you will need to reset the linksys to restore the password to it's default and then reconfigure the router from scratch.
To reset the router use a ballpoint pen end press 10 seconds on the reset button in the back (ATTENTION: YOU WILL NEED TO RECONFIGURE THE ROUTER)
Once you reset it the password to access the router is admin. Connect to the router using a cat5 cable, point your browser to : http://192.168.1.1
leave the user field empty and type admin in the password field.
You can now go ahead and reconfigure it.
Jan 21, 2009 | Linksys Wireless-G WRT54G Router
Used router, so the wireless is already setup with a newtork password. is there a way to reset the network password or setup? the friend who gave me the router is no longer in the country, and so I cannot...
Most LinkSys Routers do have a master reset. It is a small recessed button normally at the rear of the unit between one of the antennas and the WAN/Internet port. For a full reset, you need to press this for more than 10 seconds. Of course doing a full hard reset reverts the unit back to factory default.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 29, 2008 | Linksys Wireless-G WRT54G Router
D-Link AirPlus DI-524 Wireless Router Logo
46 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
