Question about G-Technology G-DRIVE (90801201) 250 GB Hard Drive
I just recently bought a G Drive mini. I used it for the first time today and put all of my imovie projects on it. I properly ejected it and plugged it back in to make sure everything i needed was on it. Now it won't show up on my desktop. I looked in the utilities folder and it's not there either. My computer (macbook pro) seems to not recognize it at all. The drive is turned on and is connected using firewire, and the light on the drive it on.
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Connection Problem
I wonder if it is foramtted to Mac or is it ready formatted for PC Can you tell? What does the documentation say?
Posted on Jul 06, 2007
  • 158 Answers
SOURCE: G Drive
which program are you using to render with and which drive are you asving to if you are saving out to the external drive this will be slow as the usb is about 1.4 mbs - 2 mbs I would sugest that you move all none essential files to external drive and create a floder in the main c drive called my movies or divx avi if you are converting to divx file format and have your capture files in a folder called Capture on c: drive I do large files myself raging to full dvd form and vcd and the converting time is long but I use pinnacle studio I've been using this software for 3 - 4 years now and no problems on time going to main c: drive. make sure you have at least 5-6 gig spare on c: drive for cache disable any non needed progrems and use a good program to cache your hard drive for editing program. the g drive is proberley shutting down or your usb drivers need re-installing. good luck on problem
Posted on Aug 14, 2007
  • 82 Answers
SOURCE: imac suddenly won't recognize 1 TB G-Drive
Hi there mu names Mark.
Lets see what I can do to help you.
Firstly some really obvious things
1 Is the light on the external drive
2 Is the USB/Firewaire cable connected at the Mac and the disk
3 If so reseat it by pulling it out of both ends and replacing
4 Have you tried another USB or Firewire port
something to be getting on with try those and re-post if no fix
regards from England
Mark
Posted on Aug 17, 2009
  • 224 Answers
SOURCE: I have not had my
Run software diagnostics on the drive to see if it is failing.
http://hddscan.com/
If you need data recovery this guy does it remotely and just asks for a donation.
http://FreeDataRecovery.us
Posted on May 25, 2011
I need help with opening a rcproject in IMovie. I have lost all of my projects in my project library. I can find the project in the Movie folder and it is saved as a rcproject. How can I open it in...
The rcproject just contains the xmlfile that remembers where the edits, cute, timing and other data about the post production. Put it in the iMovie projects folder and relaunch the app
Mar 13, 2013 | Apple iMovie
I bought a DV/Firewire cable, in order to plug the Canon MV800i camcorder, but once it is plug, how can I get the datas from my many tapes, onto my Apple Computer in order to save the tapes onto...
Connect the camera to the Mac with the firewire cable.
Open iMovie and capture the required footage.
Send the iMovie project to iDVD and burn a disc.
Apr 02, 2011 | Canon MV800i Mini DV Digital Camcorder
My book disk eject error using Mac mini with OS 10.6.2 Error states disk not ejected properly Exclamation in red hexigone The next time you connect the disk Mac os x will attempt to repair any damages on...
You may need a new Hard Drive. It sounds as if you have the old Mac. Mini. If so? look on line for Mac Mini 4,1 "Core 2 Duo" 2.4 (Mid-2010) you can find good deals on one, that would cost as much to repair your unit. eBay is one place to look
Dec 03, 2017 | Western Digital My Book Essential Edition...
Does the sony DCR-HC20 supports Macintosh computers? i have this camcorder and i recently got a new mac, can i find drivers for this camera and drivers that are for mac??
You shouldn't need drivers for this, just start iMovie and plug in via a 4pin to 6pin FireWire cable, then power up the camera
iMovie will offer basic control of the camera to import the footage as QuickTime files.
Jan 28, 2010 | Sony Handycam DCR-HC20 Mini DV Digital...
IMovie and Canon ZR500 no image
I have a slightly different but related model of Canon camera. I have found that if you erroneously power it on in "camera" mode instead of "playback" mode, you get the symptoms you describe: you can control the camera with iMovie, but you can't get any video out of it. Make sure you have the power switch in "playback" position -- it's an easy mistake to make.
Nov 12, 2009 | Apple Power Mac G5 Desktop
No sound
Check that if your mac work with headphone and look to input sound, look if there's a red light on!
If above signs exist, you should plugged the cable of your headphone or cable of speaker in input sound, put it there and put out, do this loop till the light going to off and then you'll get the sound
Feb 12, 2009 | Apple Mac OS X 10.4
My Iomega Rev drive keeps ejecting the disks I put into it. It has been backing up reliably for a few years now and recently it started ejecting every disk I put into it.
FWIW, I had the same problem...here's what I did.
I would insert a disk and it would get ejected immediately...didn't even look like the light in the eject button would flash. Rebooting the drive and computer didn't work.
I inserted a disk.
Before it could be ejected, I pulled the plug on the Rev Drive.
I waited several seconds
Re-plugged in the rev drive.
It seemed to read my disk and I was able to use my Rev drive. (So far so good...knock on my wooden head.)
Luck
- J
Jan 03, 2009 | Iomega REV ATAPI HDR B/U KIT CA 6 REV...
Copy handycam mini disc to normal dvd disc using apple mac
most recent apples will not take small discs, use a firewire lead and import on to iMovie then export to iDVD (you can edit simply in iMovie) and burn as many dvds as you want
Dec 17, 2008 | JVC VDW14DU Single Unit 2x DVD-RW Storage...
G-Technology G-DRIVE (90801201) 250 GB Hard Drive Logo
122 people viewed this question
Top G-Technology Computers & Internet Experts
Piyal Perera
Piyal Perera
dbgreenfield
Level 1 Expert
Julie Clark
Julie Clark
Are you a G-Technology Computer and Internet Expert? Answer questions, earn points and help others
