I have a Randall RB75 Combo Bass amp. All of a sudden it stopped working - the green light in the on/off switch comes whenever the amp is plugged in no matter if the switch is on or off. I get no no noise coming through the amp. One minute is was fine hen I came back 20 minutes later and it didn't work no more. Please help.
  • 26 Answers
SOURCE: Power light switches to red.
This a common problem with NAD amplifiers.
The caps dry up.Look on the protect pcb, this mounted verticaly near the rear of the main pcb, it has a metal frame around it.
Check the 4 x 10000uf smoothing caps, if the tops are not flat, they will need to be replace with 100volt ones.
Also on the right side of the main pcb around a couple of heat sinks there are other caps which dry out.
You have to remove both output modules to remove the main pcb as there is limited access from underneath.
Best of luck
John
Posted on Nov 09, 2007
  • 10 Answers
SOURCE: I have an Intex Saltwater System, model 8110. It
I had very similar symptoms with my 8110, however the Green LED would come on for approx. 1 or 2 seconds before the whole unit would appear to be dead. If yours is actually turning on for minutes you may have a different problem or perhaps your connection is intermittent. Part of the circuit monitors the electrolytic plates. If it detects a malfunction it shuts down. On my 8110 I found the following. Perhaps you have a similar issue.
On the circuit board there are two connections that go from the terminal strip to the electrolytic plates. The leads on the terminal strip are quite large and it appears when they originally soldered the terminal strip to the circuit board they did not apply enough heat. Over time the solder connection deteriorated and the connection became very resistive and generated enough heat at the solder joint that it finally failed. I cleaned the terminal strip lead and the corresponding pad on the circuit board and re-soldered the connection. While I was at it I went ahead and re-soldered all of the terminal strip leads.
Posted on Jul 06, 2009
  • 286 Answers
SOURCE: My ViewsonicVP930b Monitor Suddenly Turns Off
This is a classic VP930 problem.
It is caused by bad capacitors in the power supply circuit.
Open the monitor, and look at the power board. There are six capacitors. Replace the 220uF @ 25V and the 1000uF @ 16V capacitors. I would recommend replacing them with 35V and 25V capacitors respectively.
If the serial number on your monitor starts with Q8H you could also have a bad IC on the main board. Q8 on the main board is an FET in an IC package. If this problem persists solder a wire from the right side to the left side. There is one pin that turns the IC on and off. All the other pins (per side) are soldered together. Do not solder the pin on the left side that is by itself. Just leave it. Solder ALL the other pins on the left to ALL the other pins on the right.
Remember, do this ONLY if the problem persists after replacing the capacitors AND if your serial number starts with Q8H.
Posted on Sep 15, 2009
ladywinn
  • 5138 Answers
SOURCE: Screen keeps going black, green light blinks, then screen returns
Lamp- Mats has them 1-800-628-1118
Posted on May 29, 2010
hvac1960
  • 2133 Answers
SOURCE: Split system turns off after
Out door compressor getting over heated. Check freon pressure. May be short of gas. If fan motor less rpm, replace capacitor. If condenser dust blocked,m clean it.
Posted on Jan 19, 2011
Can I plug bass into this amp without frying it?
It has a full range speaker in it, so it won't sound real good. It's only a modeling amp, so it won't be a good choice for performing.
Dec 06, 2016 | Bass Music
Mtx tna251 amp has bass remote that has a light glowing but turn knob up and down and no difference like simply not working no difference in bass? Posible causes,
It is actually in the controller, if you turn the remote all the way down and press on the controller until the bass goes off, you will be able to turn the bass up and down with the remote, mine worked but stopped after a month, I tried adjusting the amp but then I noticed that if I wiggled the knob on the remote that it would work, I mashed mine until it worked again and velcroed it to my console sonibcan get it on and off easily.
Mar 03, 2015 | MTX Car Audio & Video
I have a Peavey MAX 112 Bass Combo amp. When I turn on the amp and have it plugged into the cord and bass, it immediately begins emitting a "whump whump" sound similar to the sound a beating...
The amp is doing what is called "motorboating". This is usually caused when the voltages to sensitive preamp stages are inadequately filtered or regulated and the sudden load of the output stages cause a dip in the voltages sent to the preamps which in turn vary the input to the output stages starting the cycle over. This will require electronic troubleshooting and if your not skilled in that, then it is NOT a DIY fix. What you are seeing is NOT normal, there is a defect.
Apr 22, 2011 | Peavey Electronics Peavey Max 112 Bass...
Would a bad Flasher relay cause the brake lights not to work?
The flasher does not stop the brake lights from working. Check # 18 fuse in fusebox under lower left side of dash. if it's ok, the brake light switch, on the brake pedal arm is next. light green wire with red stripe is hot if fuse 18 is ok. Depress brake pedal, light green with no stripe should have power. if not, replace brake light switch. If light green wire has power with pedal depressed, combination switch under the steering is next. Remove the cover from around the combo switch {under the steering wheel}. depress brake pedal, light green wire should have power. If it does, pedal still depressed, orange with light blue wire & wire with light green & orange should have power. Those 2 wires are brake & rear turn signal wires. { The turn signal switch should be in the middle, not right position or left. while checking for power in the last 2 wires. Good Luck drvolt.
Feb 06, 2011 | 2004 Ford F250
My humidifier all of a sudden just stopped working. Can you tell me of any common issues and their remedies for this humidifier ?
From the troubleshooting section of the manual (http://www.crane-usa.com/manuals/HumidifierManual2008.pdf):
Problem Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Solution Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float ? If humidifier does not work at all: ? Ensure it is properly plugged into a power outlet. ? Check that the switch is in the ON position. ? If Power On indicator light does not come on, bring to authorized service station.
Nov 01, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
I have a 500 mono. it al of a sudden is shutting off when the bass hits. the green light will flikker and go out but then come back on untill the bass hits again. thoughts?
Yes. It sounds like overmodulation, but you did not specify the volume at which the issue appears. usually loud. Check the speaker for correct ohms resistance, if not correct yoru amp will overload and thermally break the circuit, then reset...
Oct 11, 2010 | Rockford Fosgate Car Audio & Video
Let's find out before i get rear ended @ 70mph
Does the CHMSL ( Center High Mount Stop Lamp ) work ?
If this does not work, check the BPP ( Brake Pedal Position ) Switch, mounted on the brake pedal lever. There should be 4 wires to it, 2 are for the shift interlock, the other 2 are the brake lamp switch.
The brake lamp switch feeds direct the CHMSL and the MFS for the Stop/Turn combo lamps.
Without a CHMSL, I would suspect the BPP switch.
The wire colors on the F-150 are Light Green & Light Green w/ Red stripe for the stop lamp circuit. If you have this color combo, unplug the connector, and try jumpering the 2 together, to see if you have brake lamps.
Assuming the mechanic already checked the fuse for the BPP
Sep 21, 2009 | 2006 Ford F-150
Amp green then red light then nothing problem please help
It sounds like the output transistors have failed. To eliminate other possible problems, read through the following page.
Troubleshooting - Amp in Protect Mode
Let me know if you have any other questions.
Aug 05, 2008 | SPL Dynamics Z2X-1600 Car Audio Amplifier
Powers on but no sound
Check the main amp fuse under the hood, even if it looks good just change it. Often times that light on the amp can come on just from the power amp tunon wire. Try a friends subwoofer box just to make sure the connectors on your box are good, and if that doesn't work then give me some more details....year/make/model of car, what kind of sub, what types of things do you see on the side of the amp....is there a green light as well as a red light?
Aug 18, 2007 | Xtant A3001 Car Audio Amplifier
47 people viewed this question
 Grubhead
Grubhead
