Question about Panasonic DP190 All-In-One Laser Printer
I have an error code of (E04-02) on a model Workio dp3520
  • Anonymous May 18, 2009
    no, i would like to repair the machine myself...are the proper manuals top secret?
  • 3 Answers
E4-02 is a fuser exit sensor jam. open the left cover (when u face the machine). then there is a metal gate, flip it open, and it will be the sensor in the middle of the path. You can try pressing it to see if it moves freely. You will also need to reset the fuser code
function, original size (ledger), '3' <--press and hold in sequence
then press 9, set, "ram initialize" -> LBP fuser reset, and wait until the left upper corner tells u to reset the power.
Posted on Feb 03, 2009
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
The Panasonic web site is, for some reason, particularly devoid of support information for this printer. Unfortunately, you haven't indicated what exactly is occurring when you get this error number, and the site has taken several hours to locate relevant information. Unfortunately, to make a long story short, it appears that service is required, assuming that you have verified all of the obvious general troubleshooting steps (as indicated below).
If you have your manual, that is most often the best place to start to locate the meaning of a particular error. General troubleshooting would lead to suggest that you turn off and remove the power source for several minutes before restarting, see if the machine resets, and if not, follow up as below after checking all obvious error conditions (supplies, communications lines if any, paper jams, etc.) If you do not have your manual, there are a number of manuals relative to this model at:
http://service.us.panasonic.com/operman/findmanual.aspx?model=DP3520. However, the difficulty of locating information at the site would suggest to keep record of this location, as it has taken me nearly 2 hours to find it!
If you look at page 11 of the Copy manual located at http://service.us.panasonic.com/OPERMANPDF/DP3520_COPY.PDF
you will see that it is indicated that, for any error code beginning with E, contact Service.
I have listed below all other such information as I could locate in regard to this printer. However, there is little to no available information regarding operation and/or errors in any of the generally expected and/or accessible areas.
The best bet may be to submit an online request for support directly from Panasonic. Complete the form at http://www.panasonic.com/business/office/support-contact-us-form.asp and they should get back to you. All other references (other than below) refer us to dealers to get support for printers...
I was able to find a contact and number (Paul Wharton 201-392-6561). However, this was on a page re accessibility. Still, it is a Panasonic contact, and hopefully this person could direct you further. Other than that, please see below.
The main pages for this printer are at http://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?storeId=11201&catalogId=13051&itemId=66764&catGroupId=13843&surfModel=DP-3520&displayTab=O
AND
http://www.panasonic.com/office/templates/PDIC_HyperDoc.asp?Category=1029&ModelNo=DP-3520
The following is from http://panasonic.co.jp/pcc/products/en/mfp/download/
WORKiO DP-3520, 4520, 6020
Panafax Desktop Software Manual is at
http://panasonic.co.jp/pcc/products/en/mfp/download/dp-c322/pdms/Manual/ENG/Panafax%20Desktop%20OI.pdf
Hope that some of this information is helpful. Please post back, if you need further assistance, with additional detail regarding exactly what is occurring with the machine (aside from the error code). However, based on the manual, it is likely not something that can be solved without service.
Thank you for using FixYa, and if you feel this information has provided excellent information regarding your problem, please rate this solution at a FixYa!
Posted on May 28, 2008
I have a Panasonic Workio DP3030 showing error code J93 paper misfeed in ADF. I have followed the manual and there is no paper jammed but I can't get rid of the error message.
Generally a paper misfeed is not a paper jam. The rubber pickyp rollers probably need a clean but turning the printer off for 10 minutes and turning back on should eliminate the message.
Nov 03, 2013 | Panasonic Workio DP-3030 Printer
Error code 410 in panasonic copier DP4510
just press on this link and there is multi solution for the code error okay man===> http://www.manualslib.com/manual/360974/Panasonic-Workio-Dp-2310.html?page=209
Feb 06, 2013 | Panasonic DP4510 Workio Upper Fuser Picker...
What does e0122 error code on panasonic workio dp 150 copier mean?
Hello :
polygon motor synchronization error. possible causes are :
1: engine pcb
2:laser unit
3: lvps
4: sc pcb
reseat all the connectors before starting to replace boards
please rate !
Apr 13, 2010 | Panasonic Workio DP-150PA Copier
Machine keeps jamming and pulling up a code E01-31. Also, the doc feeder will not work. Is there anyway to do some type of reset and see if it's just an internal computer error,etc?
This is due to feeder roller or paper out roller may having issues due to which paper got jammed frequently. Check all the rollers with help of expert engineer or from service center.
Revert back for more assistance.
Jan 26, 2010 | Panasonic Workio DP-3520 Copier
Error code 634 panasonic dp 190
is that a fax error code?
well here is the description for error 634:
Redial count over with no
response, or busy tone was not
detected.
Note:
U.S.A., and Canadian models
will redial only once if a busy
tone is not detected.
this happens when you send fax on an autofax destination.
you may also check your setting for your redial count
that's it :)
Dec 19, 2009 | Panasonic Workio DP-190 Multifunction...
Panasonic workio DP-3530 error code E01-20
e1-20 means " laser unit horizontal problem" its ether your lsu is not connected or defection or you spc board is not connected or defective.
good luck
Nov 19, 2008 | Panasonic Workio DP-3530 Copier
Workio Dp3520
if your talking about error E03-40 its a problem with your copy density sensor, either a bad or dirty sensor . or a bad SC board
Aug 28, 2008 | Panasonic Workio DP-3520 Copier
Panasonic DP190 All-In-One Laser Printer Logo
386 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
