Question about Olympus Camedia C-740 Ultra Zoom Digital Camera
Card error I get "Card error" when I insert the card. I bought a new one and get the same message. I tried cleaning the contacts . no luck. What is next?
  • Anonymous Feb 05, 2009
    1. I have the C-720 UZ and uploaded photos to pc using the card reader,inserted card back in camera and got 132F card error,bought new card and got the same thing.
  • 579 Answers
This is using the xD card? M or H? These cards may not be compatible as they use newer technology. Get the firmware upgrade and follow instructions to the T. Here is the instructions:
http://dl01.olympus-imaging.com/ww/pb/amend/fwup_c740c750e.pdf
and here is the firmware link, go down to C-740 UZ and select english.
http://www.olympus.co.jp/en/support/imsg/digicamera/download/software/firm/pictbridge/fwupdate_asia.cfm
Posted on May 28, 2008
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
Sony Cyber Shot DSC-H9
The camera may display a MEMORY STICK ERROR or C:13:xx message (xx can be any random number) on the LCD screen for the following reasons:
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Remove and re-insert the Memory Stick® media several times.
  2. The inserted Memory Stick media is not compatible with the camera. Check your instruction manual for information regarding Memory Stick media compatibility.
  3. The inserted Memory Stick media is not formatted. Format the Memory Stick media using the FORMAT option in the camera menu. WARNING: There is a risk of data loss. Formatting will erase all stored data, images, movies, etc., from the Memory Stick media.
  4. The terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
  5. The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
Thanks
Proton
Oct 02, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Try to take pictures and camera says "clean card." I clean card with dry cloth and get same message?
There may be an issue with the card that is being understood by the camera as "dirty" contacts. Try using the camera with a different (or new) card to see if the problem persists. If it does not - it is a problem with that *particular* card. Before discarding, you may be able to get the existing data off the "bad" card by inserting it into a separate card reader ($15 - $50 depending on how many formats it understands) connected to the computer via USB.
If the the same error is displayed on every card you put into the camera, it means it is an issue with camera. It may be dirt build up on the contacts inside the camera - or worse. Either way, it means the camera should be sent out for repair - or be replaced.
I hope this was very helpful - good luck!
Jun 22, 2010 | Olympus Cameras
I keep getting error 99. I've cleaned the sensors with a new eraser; I've changed the battery and changed the memory card. If I take out the battery and put it back in, I can take a picture. If I pause for...
Hello:
Here is what Canon said :
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
I hope this will help
please don't forget to rate !
Mar 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon ZR200 memory card say ''card error'' when inserted. Card is not locked. I have formatted it. Have used 3 different sizes of cards. Sometimes it will say ''card error'' then start working a couple of...
Sounds like the contacts for the cards are dirty. Turn off the camera and remove the batteries before doing the following.
Try taking a piece of card stock (or a manilla folder) and cut it to the size (width only) of your memory card. Fold it to make it thicker. Wet the creased end with rubbing alcohol. Now gently insert the creased end into the memory card slot and move it in and out to clean the contacts. Remove and blow out with a can of compressed air to dry. Let sit a few minutes and then your cards again. You might want to clean their contacts as well with a clean rubber type eraser by gently rubbing the contacts on the cards.
Feb 01, 2010 | Cameras
Canon rebel xt error messages
error 99 can most times be remedied by taking a standard pencil eraser and carefully cleaning the gold contacts at the back of the lens and the gold maching contacts in the lens opening of the camera... BE CAREFUL not to let eraser crumbs into your camera... keep it clean... reset the battery and give it a whirl.... did it solve the 99 issue?
for the CF it refers to the cf card... here's what I've found on this:
Canon reports that this error code may appear on your digital camera’s LCD (liquid-crystal display) when there is an error reading from or writing to the inserted CF (CompactFlash) card. This error code occurs most often after a user has tried to eject a CF card before the camera has finished writing data to the card.Solution:
Canon suggests that you first try to use a different CF card. If you do not see the error message when you use the new CF card, the first card is probably damaged.
Before you take the next step, drag the files from the CF card to a location on your hard drive to back up the files. Next, you can use Windows’ ScanDisk utility to check the CF card for errors. If you use a Mac, you can use Disk Utility (in Applications\Utilities\) in OS X.
If ScanDisk or Disk Utility fails to resolve the CF card problem, insert the CF card in your camera again. Then format the CF card. On most Canon cameras, you can do this by pressing the Menu button, selecting the Format tab, highlighting Format, selecting Format, and choosing Yes. Make sure you have backed up the data on the card before you do this. Formatting the card will delete the images from the card. After you format the card in your camera, use ScanDisk or Disk Utility to check the CF card again. If you still encounter errors while using ScanDisk or Disk Utility, you should discard the CF card because it is damaged.
If the error still occurs after following the steps above, your camera may need repair. Contact Canon’s technical support for further assistance.
hope this solves your issues....
let me know
K
May 29, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Camera says "card error"
Either you have pulled it out of the computer without disconnecting the hardware with the little green Icon ( at the right hand side of the computer ).
Or if you just brought it inserted it into a camera and it said " Card Error " then the contact points need cleaning , if you need help respond and I am more than happy to help
Thanks
A Kid
May 18, 2009 | Norcent Technologies Xias DCS-760 Digital...
Memeory card error
The problem seem to be the card reader in the camera have contact problem, first thing is to ensure is there anything inside the hole where you insert your mem card, second ,try to use contact cleaner to clean up the card reader .hope it help.
Aug 20, 2007 | Canon PowerShot A430 Digital Camera
Olympus C-750 Trouble formatting card
have u tried to format the card on the computer??? try to format in a card reader.... and after on the camera. if that doesn´t work... could be the kind of card, there are diferent kinds of xD cards. good luck
Apr 02, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Olympus Camedia C-740 Ultra Zoom Digital Camera Logo
300 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
