Question about Hobart Handler 125 115 Volt 30 To 125 Amp Arc Single Phase Wire Welding Package #500487
Where can i get parts for my hobart welding machine but is a old welder
  • 491 Answers
Your local welding shop supply will be able to give you advice, the guys at Lowes and farm supply shops just sell the welders
Posted on Oct 05, 2010
What chargers the battery on a Hobart 10000 watt welding machine?
I assume it is a low voltage tap off the welders generator that supplies voltage for welding.
Nov 01, 2016 | Hobart Welding Tools
Hobart 140 voltage drop when welding in all setting using 30 wire and uni mix gas will start out welding good then will not ?????
Check your input line voltage. 115 volt Mig welders / plasma cutters need stable voltage / current. Test to see if the voltage drops to below 100 volts when welding. If so, find a more stable power supply.
Mar 05, 2010 | Hobart Welders 500505 Handler 140 MIG &...
I have a Hobart handler 120/90amp wire feed welder.When i try to weld,all i get is a small spark.I turn it off,turn it on and it does it again.The wire feed works good,it just sparks,but will not keep...
I have welded countless hours with Linde & Lincoln & even a few Hobarts & the only time that I ever had the same problem was when the ground connection either to the object I was welding, or the welding cable ground wasn't good & clean & tight. Same on stick welders also. I did develop the habit of grinding not only where I was preparing to weld, but where I was placing my ground clamp & that always provided a better "frying bacon" sound as I went along the business of pushing a bead. In a welder, the only other thing than that is involved is the step-up transformer and your wire. Hope this helps.
Feb 01, 2010 | Hobart Welding Tools
My Hobart Handler 120 needs a .045 wire drive wheel. Where can one be purchased?
Locate your locale Hobart welding distributer, or contact hobart, the are nice people and will give you all the avice you need.
Dec 26, 2009 | Hobart Handler 140 Mig Welder
My 210 took a spill. Looking for new face plate, cables, & knobs. Where can I find them?
Hobart are very obliging, contact them and request a parts list for your set, or any Hobart welding suppliers.
Nov 15, 2009 | Hobart Welders IronMan 210 MIG 500304A...
Hobart handler 140 wire feeds properly, will not weld
If it is new i would not play around with the welder Just take it back to where you bought it get them to replace it under warranty
Jun 10, 2009 | Hobart Handler 140 Mig Welder
I am looking for Hobart parts I think???
you can go to any welding store(praxair,air gas)and they will be able to order the parts you request,need to get all the imfo.you can off of welder for them to be able to help you.
Jun 09, 2009 | Hobart Welders IronMan 210 MIG 500304A...
Won't idle down between welding
have you went to your local welding store? Praxair or airgas can call Hobart for the part you request,or they will call their Hobart salesman for you.
Mar 08, 2009 | Hobart Welders Champion 500433A Factory...
Hobart Handler 125 115 Volt 30 To 125 Amp Arc Single Phase Wire Welding Package #500487 Logo
238 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
oneStan
oneStan
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
