Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5
Why does the overload keep tripping - Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5
Is it possible the unloader isnt working? That maybe the compressor is trying to start under load? or maybe a voltage loss. Having the same problem dont know where the unloader is or how to fix it. I guess this is more of a guess.
Posted on Oct 10, 2010
Taotao ate 501 breaker keeps tripping
breakers that keep tripping indicate a sever overload from a dead short ( same deal as a fuse)
It could be from a failed start/run capacitor for the compressor , vermin related problems or shorted wiring
best have a technician check it out
It is possible that the breaker is weak and tripping before the set current flow is reached ( a replacement of the same rating will prove this) Do not use a higher rated circuit breaker
Jul 31, 2015 | Heating & Cooling
Dewalt 735 planer trips overload a lot. New blades, thin cut no difference. Run it, without wood, it trips. Overload switch? Checked everthing. Turns free with chains off. Bluespook
id check the feed roller drive or feed rollers them selfs I find due to pressure there under most times they get flat spots in them from sitting makes for a hard start to planer
its best to back off tension rollers when storing these and keep them bearings lubed up well
and yes it happens to sealed bearings too
Apr 28, 2015 | Garden
My fridge keeps tripping the power
Your solution is one of two things.
First is the circuit you have plugged the refrigerator is either over its limit and the breaker is tripping because it is overloaded. In this case you will have to determine what load also share this circuit and eliminate the extra loads or move the cord to another circuit which is not overloaded. Most home circuit are wired with 14 gauge and is rated at 15 amps. When the circuit gets to 15 amp and more, the associated breaker trips to prevent overload.
Second, Your refrigerator may have a short and needs troubleshooting to find the cause. To see if it is a bad circuit try plugging into a circuit via extension cord to circuit in another room receptical. The reason I say another room, when electrical installers wire circuits, you can put several recepticles on the same circuit. If you plug your refrigerator in the same circuit you had it on before then you will get the same problem, your refrigerator tripping again. If your frig trips on a different circuit then troubleshooting the cause will normally require a tech.
Good luck and hope this helps.
Oct 28, 2014 | Refrigerators
Keeps triping on compessor overload
The start capacitor is going bad. Replace it before it ruins the motor in the compressor.
Oct 01, 2014 | Heating & Cooling
I got Bryant circuit breaker than keeps tripping I replaced it and it still trips
You likely have a short circuit or overload condition in the wiring attached to that breaker. Sounds like the breaker is doing it's job.
Jun 09, 2014 | Electrical Supplies
Tripping circuit breaker
please follow this steps and fix it. Otherwise call some electrician. God bless you
The circuit trips again. 2 issues could be causing this:
  • Overloaded circuit: Use fewer devices simultaneously or try moving certain devices or small appliances to a different area (use another outlet and circuit). Try resetting.
  • Electrical short: If your circuit is not overloaded, but the circuit keeps tripping, then this is likely the problem. The appliance or electronic device could be causing this short, or there could be faulty wiring in the walls. Consult a qualified electrician.
Oct 28, 2013 | Kitchen Appliances - Others
What could be causing my Pitco Electric Fryer pump to keep tripping the circuit breaker?
Hi there!
The filter pipes may be clogged causing the motor to trip off during operation.
You can find the nearest authorized service center when you visit www.pitco.com
Regards
Feb 02, 2013 | Kitchen Appliances - Others
Goulds pump model BGR75 won't reset. Any tips.
If the motor runs but keeps tripping the overload, the motor is bad or the motor is under a big load. Does it pump water? If not, check the impeller and see if there is anything wrong with it. If it does pump water and the motor trips overload, the only thing left to check is the overload. Check the motor's amp draw and if within specs, replace overload. If amps are too high, replace motor.
Aug 22, 2012 | Plumbing
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
Kenmore washer model # 110.24086200
The C1 code indicates the "instantaneous current limit" trip. This signifies problems with the drive motor, thermal protector, motor controller. Overloading the machine will cause high amps and trip the unit. Instantaneous current trip occurs if there is a current spike of 26 amps instantly at the motor windings in which the motor overload trips. check bearings for lubrication - or as stated above overloading the washer.
Sep 06, 2007 | Kenmore Elite 45986 Front Load Washer
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 7.5 Hp, 230 Volt 3 Phase, Model - 2475N7.5 Logo
376 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
