I have a GE washer machine wwse5240g1ww, need to replace the belt so i ordered a replacement. wh01x10353 belt. the package says wh01x10353 but on the belt it says 175d5131p003 and it is too small wont evan fit around the drum pulley let alone trying to get it around the drum pulley and the motor pulley.
3 Suggested Answers
Controlfrk
  • 304 Answers
SOURCE: Having trouble installing WH01X10353 GE
Use belt INSTALLER TOOL WX05X10102
Posted on Aug 23, 2009
KevinWhite
  • 1902 Answers
SOURCE: I have a broken belt
Hello & Welcome to FixYa
You can view this video for replacing the belt in your GE washer:
Please get back to me if you have any other questions.
Kevin
Posted on May 12, 2011
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
I have a GE washer (WBB4500G2WW) - wont aggitate or spin
The BELT... Part number wh01x10302
30% of the time is the issue here:
http://www.appliancepartspros.com/ge-belt-wh01x10302-ap3968432.html
Have a look at appliance-parts-pros (video guide)
http://www.appliancepartspros.com/repair-help/general-electric-washer-wbb4500g2ww-repair/wbb4500g2ww-pumps-but-will-not-spin.html
May require a specialty tool to mount the belt
(depicted in VIDEO... Sold on site): view here:
http://www.appliancepartspros.com/ge-service-kit-belt-wx05x20641-ap5957260.html
((not entirely convinced the tool is critical but the
Also check prices on eBay (top seller, free shipping
WH01X10302 AP3968432 1264395 PS1482278 WH01X10353 Washer Drive Belt eBay
Hope this holds off trashing your three year old washer...
Carnac the Magnificent
Jan 15, 2018 | Whirlpool Washing Machines
During washing phase, the rotator is not moving - but you can hear the motor trying to move
your problem may be the drive belt. check that first. part# WH01X10353 you can find it at sears website or service center for about 15.00 plus tax and shipping.
good luck to you.
Feb 19, 2011 | GE Profile WPRE6100G Top Load Washer
No spinning and no draining and i get code e20
  • Get the washer laying on it's side and using the access hole on the bottom carefully remove the screw clamp holding the large hole of the rubber housing to the tub drain (it will be obvious all other clips are green compression clips).
  • Carefully work the strainer out of this flexible rubber drain housing through the large hole.Clean it out and replace you will be good to go. Also remove all the hoses and check for a buildup of gunk. Hope this will fix your problem.
Thank you!!
May 19, 2010 | Frigidaire ATF6000ES Front Load Washer
Ge whdvh626 washer fills and drains. drun does not
I took off back plate and noticed belt was off. I also noticed that pulley was very loose. I ordered new pulley and belt and replaced myself. Thanks.
Dec 16, 2009 | GE WSXH208A Front Load Washer
Need to get replacement belt for washer. where to
If the model number you have this question listed under is correct, the part number for a replacement belt is WH08X10024. You can find it listed at appliancepartspros.com for about $37.
If you have never replaced a belt on this type of washer before, the following link explains how:
http://www.fixya.com/support/r3059652-drive_belt_installation_whirlpool_duet
The link is for Kenmore Elite and Whirlpool Duet, but the GE model listed is identical in design.
If you have any questions, please let me know. I hope this helps you.
Oct 15, 2009 | GE Energy Star WCVH6260F Front Load Washer
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Ge washer motor
You ;listed it as an Amana, but said it is a GE. I will give you direcions for a GE. If its not, let me know. First, be sure the unit is unplugged and water line is off. Underneith the motor, down right above the belt, you will see 4 nuts that hold the motor to the mounting plate. Remove these nuts, then slide the belt off. Lift the motor slightly, then aim the top of the motor back towards the middle of the unit. Keep tilting and moving the motor backwards until the clutch clears the mounting plate. Slide the motor now towards you and remove. Replace motor following any new instructions that come in the package. Good luck, and let me know if you need further instructions.
Feb 12, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Replacing belt on GE front loader wsxh208a1ww
Ron, be sure the wheel the belt goes around is not loose. The belt will come off if it is loose.
Jan 09, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
256 people viewed this question
Top Washing Machines Experts
