Question about Fisher and Paykel Washing Machines
We have a very 'stale' smell that eminates from our washer. It seems as though there is standing water under the tub, too.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.You mentioned in your posting that you have water under the bowl,Is this correct?Can you see the water or hear it when you rock the machine?Where is your machine draining to,is in the laundry sink or some where else?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Oct 06, 2010
Obnoxious smell from washer
I use "Affresh" every couple of weeks to keep the washer smelling good. Here is the product to order.
Nov 23, 2012 | Equator EZ 3600 CEE Front Load Washer /...
GE Washer Mod# wcsr2090d5ww
It's normal for some water to stand in bottom of outer tub. It shouldn't be visible in the inner tub though.
Oct 31, 2017 | Washing Machines
The washer smells funny. Like mildew or something. No water standing. Seems to drain.
Probably has some standing water in the pump hoses as well as the drain hoses If you do not use the machine often, then some water is left in the drain hoses and upon evaporation it may do what you smell. Pour some bleach in the tub, with water and let stand for 15 min. put it on rinse and let drain and do the smell test again.
Jan 09, 2011 | Whirlpool WTW5300SQ Top Load Washer
Musty smell
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically. My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Aug 11, 2010 | Kenmore Elite 45986 Front Load Washer
Stale odor within tub
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Dec 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bad smell coming from washing machine
It probably is related to your drain outlet, depending on the set-up, I would suggest you remove drain hose and clean the place where the drain hose enters the drain system, if possible, clean all associated pipework
Please rate my solution.
Thanks.
Sep 17, 2009 | Hotpoint First Edition FEW10P Front Load...
I have a Maytag MAH3000AWW Washer. It will start
That is a common issue that is caused by the control board of the machine. You may need to request service to fix this issue. Usually it may be caused by a resistor. Replacing the resistor may make the machine to work for a while but the repair will not last longer. I believe that the machine control board next to be replaced. Something else may be causing the control board to go bad.
Perhaps you were able to feel a burning smell from the washer machine in previous days.
Standing water may be caused by the control board failure because the pump will not operate properly.
Aug 29, 2009 | Maytag Washing Machines
Stale water smell
washer is under warrenty so called a repair man
May 18, 2009 | Roper RAS8244LQ Washer
Front loader smells like stale cigarettes during cycle
Make sure that you are using high efficiency (he) detergent. Pour 2 cups of vinegar in the tub and fill the detergent tray with vinegar. Run it on the hottest, longest cycle. You can also use a Front load cleaner such as Afresh, made by Whirpool. I think that Tide makes one too. Vinegar is usually readily available. At the end of washing for the day, leave the door to the washer slightly open so that fresh air can get in and dry it out keeping moldy, milduey smell down. If it mildews, use a rag and bleach water to clean the boot seal. Hope this helps.
Apr 02, 2009 | Kenmore HE2 Plus Front Load Washer
Moldy smell
Turn it off, unplug it. Remove filter and check if filter and/or filter and pump housing are clogged with something "smelly". When you're at it check the drain pipe for too.
May 08, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
