Question about Vizio VP322 32 in. Plasma TV
My 32" vizio plasma tv will not power on - Vizio VP322 32 in. Plasma TV
    Novelist:
  • 131 Answers
Hello; I am John at J D Electronics in Poland, Maine. I have now repaired 4 of this same model in my shop. The set may be dead always or work intermittently. There are 2 versions of this piece of junk, but I have only seen this one. They all have 2 capacitors that fail on the power supply board just above that red chopper transformer. The are labeled C233 and C234. These are 3300 ufd at 10 volts and 105 C temp rating. You can buy these for about $1 each from Digi-Key Electronics. Make sure they have the Panasonic brand. There are some cautions worth mentioning. Make sure the set has been unplugged for a day or more before starting the disassembling. It is VERY important to keep the set face down on a soft surface when doing ANY work on the set. This crappy designed set has a glass faceplate that will fall down if you don't have it face down when all the back screws are removed and it is very hard to put it back into position if it falls. The bottom plastic speaker strip has a million screws to remove both from the bottom edge and the back. then take out all the screws for the metal back and unplug the speakers. The connector wires to the speakers will not just pull off without you pressing on a side release pin for each of the 4 wire- Stupid design again!. Good Luck! John
Posted on Oct 12, 2010
  • 4 Answers
SOURCE: plasma tv has no picture but green led is on
Try unplugging the TV for a few minutes (discharges the ballast/ps) then plug in and attempt to power on. I have the 42P Vizio over two years old and ran into the same problem a few times. First thought was a power supply issue, but the unplugging trick worked. Good luck.
Posted on Apr 17, 2009
  • 3 Answers
SOURCE: the component side of my vizio 32 plasma is not
Mine is gone out too, amazing they last a year and then go.
Posted on Jul 27, 2009
gripfitter
  • 557 Answers
SOURCE: vizio 32" plasma 1st clicked off & on 4-5 times
Power supply board. Some times you can find bad caps on the board, if not have to replace board.
Posted on Sep 27, 2009
  • 8457 Answers
SOURCE: my vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Posted on Jan 08, 2010
  • 53 Answers
SOURCE: Hey guys, got 32
If you feel good about it, take off the back and examine the capacitors on your power supply. It should be located near the center of your set. In the event you can't find it, locate where you plug in your power cord and follow the path of wires until you find the circuit board where they plug in.
That's your power supply. The capacitors are the cylindrical objects on the board. They range in size and can be very small, to quite large. Look at the tops of them. They should be flat. If you see any that are raised in the center, those capacitors are no good.
That cycle you are describing is reminiscent of other sets having a similar problem. In those cases, it is the capacitors on the power supply that cause the issue. You can replace them with higher rated capacitors, if you prefer, or you may replace the power supply.
Hope that helps.
Posted on Jan 22, 2010
I have a 32" vizio plasma that wont turn on
hello,
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.If otherwise, Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem......
Jul 06, 2011 | Vizio VP322 32 in. Plasma TV
When I hit the power button on my 32" Vizio Plasma
You have a TV with a failing power supply board. There are parts in the power supply called capacitors that start failing and this causes the power supply to not be able to properly filter the voltages. When you keep turning it on and off the capacitors will finally hold a charge correctly so the voltages will stabilize and the TV turns on ok until the next time you turn it off. As time goes by the capacitors will degrade more until the TV will not work any more. If you can solder then you should be able to repair the TV yourself. We have a page on our web site http://www.ccl-la.com/blog/index.php/capacitors/
That explains what capacitors are and how to determine the bad ones that have failed. If you replace the failed capacitors in the power supply then you should have a working TV again.
BuddyMc
Corporate Computer
Dec 15, 2010 | Vizio VP322 32 in. Plasma TV
My vizio tv will not come on with remote or manal
Try a new power outlet. If you have no power, there is no troublshooting you can do. You will have to get repaired.
Aug 10, 2010 | Vizio VP322 32 in. Plasma TV
Vizio 32 in plasma
its bad capacitors
check my tutorial
http://www.fixya.com/support/r5000889-repairing_tv_just_clicks_over_over
they will give many symptoms but this tv had some defective ones
let me know if i can be of further assistance.
Jun 06, 2010 | Vizio L32 32 in. LCD HDTV
I plug the tv in and there is no power
Go to MENU at the Tv turn on the logo light option on.
May 08, 2010 | Vizio VP322 32 in. Plasma TV
How much would it cost to repair my 32" flat screen vizio tv? Was bought in 08 and died completely on me today
Power supply board is dead.If want to try to replaced it ur self.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.It will cost u about half the price of a new tv.It should cost $250 or $300 max more than that u got cheated.
Mar 08, 2010 | Vizio VP322 32 in. Plasma TV
When I turn my 32" one year old Vizio on either by the remote or by the side of the TV, it turns on and off about 15x before showing any picture and staying on.
U know how to solders?Power supply board have problems with dead capacitors,like bulge up or pop open .Replaced these capacitors well solved the power problems.Or u can buy reburbish power suppply board for the replacement at Shopjimmy.com,Ebay.com.
Feb 21, 2010 | Vizio VP322 32 in. Plasma TV
Power turned on & off by itself then power died completely
Had the same thing. Bad capacitors in power module.
Jan 25, 2010 | Vizio VP322 32 in. Plasma TV
Vizio 32 vp322
Power board is dead.Must be replaced,to get power back.Tries Shopjimmy.com,Ebay.com for the power board part.
Jan 23, 2010 | Vizio VP322 32 in. Plasma TV
My vizio 50 inch plasma tv will not turn on. what
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio VP322 32 in. Plasma TV Logo
632 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
