Question about Pasquini Livietta Espresso Machine
I need a new water reservoir part for my machine where do I find one?
You can order on line or call them. I get parts here all the time. Great service too.
K
http://www.pasquini.com/
Posted on Feb 02, 2011
Need a descaler
instractions are from manual HD7810/00
Use the correct descaling agent
Only citric acid-based descalers are suitable for descaling the SENSEO
machine. This
type of descaler descales the machine without damaging it. For the correct amount,
see under 'Descaling procedure' below. Each descaling mixture can be used only once.
After use, the descaling mixture is no longer active.
We advise you to use the special SENSEO
Descaler (HD7012/HD7011/HD7006).
Read the instructions on the package of the descaling agent.
Never use a descaling agent based on mineral acids such as sulphuric acid,
hydrochloric acid, sulphamic acid and acetic acid (e.g. vinegar). These descaling
agents may damage your SENSEO
coffee machine.
Descaling procedure
1 Mix 50 grams of citric acid with 1 litre of water in a measuring jug. Stir until
the powder is completely dissolved.
2 Fill the water reservoir up to the MAX indication with the descaler mixture.
Then put the water reservoir back into the coffee machine. (Fig. 3)
Note: Not all SENSEO
machine types have a water reservoir with a capacity of
1 litre. If you have a SENSEO
machine with a smaller water reservoir, repeat steps
2 to 6 with the remainder of the mixture without filling the water reservoir up to
the MAX indication.
3 Press on/off button 3. (Fig. 10)
The machine is ready for use when the indicator light lights up continuously.
4 Place the 1-cup holder h with a used coffee pod in it in the coffee machine.
Close the lid and make sure it is properly locked.
Note: Always put a used coffee pod in the pod holder when you descale the
machine. This pod serves as a 'filter' to prevent the sieve or hole in the pod holder
from getting clogged with scale residue.
5 Put a bowl with a capacity of at least 1500ml under the spout to collect the
descaling mixture (Fig. 8).
6 Press the 2-cup button hhand let the machine operate. Repeat this until
the water reservoir is empty. (Fig. 25)
Never interrupt the descaling process!
7 Repeat steps 1 to 6. Replace the used pod with another used pod to filter out
the scale residue.
Note: To descale properly, you have to use 2 litres of descaling mixture.
Never descale the SENSEO
coffee machine with the lid open. Make sure the lid is
properly locked.
8 Rinse the water reservoir with tap water. Fill the water reservoir up to the
MAX indication with tap water and repeat steps 3 to 6.
Note: Do not refill the water reservoir with used hot water or the used descaling
mixture.
9 Fill the water reservoir with fresh tap water up to the MAX indication again
and repeat steps 3 to 6 once more.
Note: Always rinse the machine by letting it empty two full water reservoirs.
10 Remove the used pad and clean the pod holder after descaling to prevent the
sieve or hole in the centre from getting clogged.
Mar 30, 2014 | Philips Senseo HD-7810 Coffee Maker
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
Hi, My Solis master 5000 digital is having a problem. When we turn it on it says water tank is empty even when the tank is full. Thank you!
Check the water reservoir, if there is a float in the corner. Then that piece is not getting in contact with the reed switch in the machine. Try sliding the reservoir down the back of the machine so that it is always in contact with the back, or if the float is not rising when the reservoir is filled with water then the reed switch cannot detect the magnet in there. You might need a new float assembly.
Oct 20, 2011 | Solis Master 5000 Espresso Machine
Pasquini service in washington dc
Hi
If they are blinking slowly check this. Check the wire on the water reservoir to make sure that it is connected. You can try grounding this wire and see if the machine responds.
Water level may be low in the reservoir. Are you using distilled water or reverse osmosis water. Don’t. The computer can’t tell if have water in the reservoir, because it need’s minerals to conduct the small current for the computer. If they are blinking fast you may need a new computer.
Jul 04, 2010 | Abernook Pasquini Livia 90 Semi Automatic
I want an espresso and it's not working...
Most of the time, you just have to reposition the water reservoir - simply pull it up and then put it back in its proper place. If the water tank is even a centimeter off, the suction tube doesn't properly grab it, so it can't take in water.
If you reposition the water tank, and the EM-100 is still not sucking any water out of the tank, there may be a problem with the water reservoir tank itself. Call Cuisinart - I can't remember the Canadian number off-hand (The EM-100C is a Canadian model, so I'm assuming you're in Canada) - and have them send you a new water tank.
Good luck! Let me know if you need any more help with this machine - I am a huge raving fan.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 19, 2009 | Cuisinart EM-200 Espresso Machine
Need a new water container
I bought a Solis replacement water reservoir from Green Beanery in Canada a few years ago. They sell replacement Solis parts, but I'm not sure if they still carry the water reservoir. I had a hard time finding online merchants who sold Solis reservoirs.
Dec 31, 2008 | Solis Crema SL-70 Espresso Machine
Saeco Vienna Coffee Machine water leak
I have had the same problem with my Saeco Digital & Saeco Superautomica machines. After much work and somewhat expense I have finally found a simple fix. All you need to do is replace the gasket which is located just under the water reservoir.
(1) Take the water reservoir off
(2) Pop the round plastic piece located in the middle off (don't worry you won't break it as is it pretty tough)
(3) Take the black rubber gasket out and either:
(a) cover the present gasket with the brew group lube or
(b) replace the gasket with a new one.
which will give it a air tight fit and prevent any further water leakage from the reservoir.
You can get a new gasket for $5!!! :) I got mine at: http://cerinicoffee.com/item.asp?cID=0&PID=90
I also put some Brew Group lube ( http://cerinicoffee.com/Lube_brew_group_saeco.asp ) around the gasket as a temp fix until I completely replaced to gasket. Apparently, what happens is that the original gasket gets old, dry rots or whatever allowing the water to leak out of the reservoir. And then all over your work surface. The Saeco machines are quite intricate but are
Hope this helps.
-Dave
Nov 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
Senseo 7818
My husband found in ours that the little float was stuck over the sensor (the little patch) down in the reservoir. The float could not rise with the water, thus, the machine did not know that there was enough water available and it would not stop blinking. He took the dry reservoir out, turned it upside down and shook it! This worked for him, as it unstuck the float. He said that if that doesn't work, the thing is really stuck and you might as well return it.
Jan 13, 2008 | Philips Senseo HD-7810 Coffee Maker
Espresso Machine
Possibly, if it is leaking from the bottom only, and if you have a Domus Due model, you might just need a new water reservoir as the water reservoirs are a different system than all of the other briel machines and a new reservoir will usually fix the problem of leaking on the bottom in the Domus Due machines. Something with the seal on the reservoir.
You can order just a water reservoir by contacting the service center at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
ph 201-439-1700
info@electra-craft.com
www.electra-craft.com
If your machine is leaking over the filter handle, brew head etc, that could be the coffee oils have built up in the Brew Head Screen and/or filter basket itself. For that, remove the Brew Head Screen and soak along with the Filter Basket in a coffee oil remover (not descaler) you can get the Cafiza powder at www.urnex.com or any other brand and then use a brush to clean it after soaking. If you have the Briel filter basket with a screw in the middle, please remove the screw and clean in there as it tends to get clogged. Then just be sure not to screw it too tight again as this can cause leaking.
I hope the info was helpful.
Apr 16, 2007 | Briel Domus Due Espresso Machine & Coffee...
Pasquini Livietta Espresso Machine Logo
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
De Brewerz
De Brewerz
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
