Question about Poulan 25CC Gas BlowerVac
I was replacing pull cord and the tiny bar which connects the trigger to the carb fell off before I could see how it was installed. I canot figure out how it goes back. It is a Bvm 200 25cc Poulan leaf blower
  • 203 Answers
It should be pretty simple to replace. Would expect the trigger to come out, put the rod/bar on the carb then on the trigger (probably has to swivel the trigger to get the part on) the set trigger back in it's position. Hope this helps. Easier to do than explain.
Posted on Oct 05, 2010
Stihl leaf blower won't start. Good spark . Replaced plug. Attempted start, negative, removed plug, plug dry. Primed, thumb over plug hole, pull cord, thumb dry. Tiny starter fluid, negative result.
Try and see if it will start with a tiny amount of fuel poured into the block. If it fires then it could be the gaskets on the carb need replacing or it could be a blocked air filter. Check the later first.
Apr 22, 2017 | Stihl Garden
Throttle connections on poulan pro 210 chainsaw
The precision bent throttle connecting rod can only go in one way CORRECTLY.... if it has to be forced or bent, stop and figure out the puzzle before any damage is done.
I'd suggest placing the carb temporarily on the mounting studs on the side of the cylinder. Don't install the filter and nuts etc yet. Take the throttle rod and lay it in place this way and that way until it looks like it matches the trigger end AND the carb end. Usually the carb end has to be installed on the carb while it is removed from the engine as tightness of space won't allow moving it all over to poke it in the hole. Once it is on the carb and you are sure of the orientation, slide the carb once again over the studs and lay the throttle rod by the trigger.
You need about three hands to hold the trigger, trigger lock, trigger return spring and the handle together while you figure out how to snap in the top of the handle and start a screw under the handle.
Jun 20, 2014 | Poulan Garden
My NERF gun broke.
Take it back to where you bought it. It shouldnt do that, it sounds faulty to me. I am sure they will replace a faulty item.
Feb 26, 2014 | Hasbro Nerf N-strike Longstrike Cs-6 2010...
Engine stuck wide open , full throttle
It is possible your linkage arm fell off or there's junk blocking that arm from releasing - you'll need to remove the top cover and inspect the linkage arm for blockage or a missing cotter or compression pin. Remove said cover and look for the trigger linkage arm off the trigger assembly. follow to the carb, watching for blockage or missing pin(s). The natural vacuum of the carb should pull the accelerator to idle, unless the configuration ( linkage) is bent or blocked. With some saws, you may need to remove more then just the top cover, and some require the removal of the safety brake bar, which can be difficult as they usually have a hidden spring that like to fly away, taking other crucial small parts with it ( I have a saw that is now brakeless because of that mean little spring!). Depending on your level of mechanical aptitude, you may want to consider taking it to a reputable shop.
Hope this helps!!
Dec 01, 2013 | Husqvarna Partner K650, K700, K750, K950,...
Engine stall when trigger is pulled
Could be a number of things is it a 2 stroke if so sometimes the muffler gets plugged with unburnt oil and gunk. Remove muffler and use a propane torch to burn the gunk out and reinstall. Also if problem is not fixed might not be getting enough fuel take carb apart and clean with carb clean and use a piece of tag wire to clean tiny passages. hope this helps
Nov 07, 2013 | Poulan 12" Electric Twist N Edge Plus...
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
Trigger fell out
I would advise you to send the product back to the
manufacture, either for repair or refund.
Jul 19, 2010 | Toys
My Mantis Tiller 4cycle engine starts well but when I press the throttle completedly, the tines turn very slowly. This is a brand new tiller, used only twice. The engine is sitting all the way down on the...
I had same issue with my 2 year old 4cycle. Check if the carb is moving full stroke with throttle movement. I had almost no movement at carb at full throttle, found the trigger in throttle handle was cracked and bent rather than pull cable. I called mantis and they promptly sent a new handle bar ***'y with new cable, throttle ***'y Etc and that solved my problem.
BTW: If you cannot wait, I did figure out that if I pushed the carb to open with the throttle trigger fully pulled it would run at high, but when you let go.....LOL
Rich in Wethersfield, Ct
May 10, 2009 | Mantis 4-Cycle Tiller
Chainsaw will start but will not keep going.
May need to overhaul the carb. I suggest that you replace the fuel line and fuel filter too.
Apr 08, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Motorola h700 wont work...
well mine fell too,there is an inside trigger that turns on, off the headset when you unfold ,fold the boom.the trigger fell out when i dropped it.you can see the tiny hole near the boom under the headset where the trigger is or was,but is mostly viwable from the inside.so now your headset doesnt have a trigger to turn it on.i touched with a knife the metal inside button(the one tregger presses)and now its always on.sorry.
Dec 24, 2007 | Motorola Mobility H700 Wireless Headset
Poulan 25CC Gas BlowerVac Logo
297 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
