Question about Sloan M-101526-F Flushmate?® Complete Replacement System for 501-B Series
After flushing ---- has good burst of power then slowly fils up taking about 10-12 seconds
  • 22 Answers
Depending on your line pressure, refill time will vary. Typically, it takes about 30 to 40 seconds for the system to refill and re-pressurize.
If you're saying the bowl slowly fills up for 10 - 12 seconds after the flush, that's an indication of an obstruction in the trap, drain-line, or venting and you may need a plumber.
Jot down the serial number and phone number on the Flushmate label and call tech support or visit www.howto.flushmate.com for helpful troubleshooting videos.
Hope this helps! Good luck.
Posted on Oct 05, 2010
Dewinterize travel trailer
hook up to shore power. check voltage at fuses to make sure they are getting proper voltage. hook up water and flush out water lines, fil up hot water tank and flush. turn on a/c. check battery voltage to make sure slides will work. check with voltage meter on all outlets for proper voltage. dont know what else your looking for.
Mar 15, 2015 | Heartland 2013 Wilderness WD 1950RB
I have a CH horizontal compressor. As the saying goes, leave good enough alone.....well one day I wanted to install an auto drain, so I cut the unloader tube, as instructed. After realizing the auto...
Don't know exactly why, but you have a restriction in the air outlet. Yes, it could be the regulator...or a kinked or defective air hose. Check the regulator...if you have previously removed it for proper direction of flow. There are small cast arrows on the regulator indicating proper air flow direction. Foriegn matter, dirt, or teflon tape may inhibit the flow at the regulator or a fitting. If the unloader tube was replaced as originally done I cannot think if how that could affect the flow....as you say the regulator is reading full pressure. And full pressure is getting to your tool...it is only the flow that is restricted. Take the regulator off the system to test your air flow and confirm a restriction at the regulator, if neccesary.
Oct 16, 2012 | Air Tools & Compressors
I have a 1995, when I give it gas it doesn't want to go.
This issue indicates either a bad MAP or TPS sensor. These sensors should be tested. I don't have a manual for your car, so I cannot give you procedures for testing--sorry.
May 22, 2017 | 1995 Ford Crown Victoria
Charging the flash of a camera,what is it?
Your camera has a small flash unit that can throw a bright burst of light to help illuminate dark scenes. It takes quite a bit of electrical power to put out that burst of light, and it takes several seconds to build up a sufficient charge before it can put out another burst of light.
Mar 19, 2012 | Canon PowerShot A480 Digital Camera
My SB600 seldom firing when triggered manually on the red flash button. Only 2 or 3 times flashing after 30 attempt. Tried with new battery but same problem occured. Help.
If you are firing the flash manually it's giving full burst each time and the battery needs to pick up the charge from the bottom. So just numbers her for an example with a full set of batteries you manually flash, first burst takes 5 seconds to charge flash again it'll take 10 seconds, if you flash it again before that 10 seconds it'll now take 20 seconds and if you push that button again it might misfire because it just can't get the power up high enough to fire it. The flash isn't a studio strobe which is plugged into an outlet, you are working with battery power and each time you flash those batteries are under a huge load and each time you fire you kill them a little more I'm surprised you are getting 30 flashes from those batteries. My guess at full power you are going to start having problems after about 12 to 15 flash bursts and it's a rapid down hill drop in performance from then on. If you took those batteries out of the flash after that series of 30 flashes I'll bet they are hot. What you can do to help is set the system up with Nikon's wireless transmitter and utilize the new i-TTL system then you are taking performance.
Jan 07, 2011 | Nikon Speedlight SB-600 TTL Flash
Chainsaw difficult & sometimes impossible to start. Plug looks OK. 5 years old, just occasional use.
Yes. Whether storing your saw for a week or a month, a quality fuel stabilizer adds life to your saw. It can also keep it running with the type of problem your having. Double the recommended strength in your mixing fuel can and replace the fuel in your saw. Remove the spark plug and shoot a 2 second burst of lubricated starting fluid into the cylinder. Replace Spark plug and start your saw. Let it run for at least 2 minutes with the choke on then slowly increase the rpms as you push the choke in. If your saw stalls inside of that 2 minute window, do this procedure when it begins to stall out. If it still will not run, then your jets ( located inside the carb) are plugged up with varnish and you may need to rebuild the carb or replace it - it would be cheaper to rebuild and this is not a difficult job. If you choose to rebuild, get some starting fluid without lubrication to soak the jets in as you clean all the other parts. The starting fluid has a high level of Ether which will break down stubborn Varnish deposits.. Rinse all the parts in your fresh fuel mix ( oil, gas, and stabilizer). Re - assemble carb and flush your fuel tank as well. Put it together and then shoot a 2 second burst of lubricated starting into the cylinder through the spark plug hole. Install spark plug and follow starting procedure, foregoing the primer bulb. Your saw should now be running smoothly unless your carb is defective.
Good luck!!
Nov 19, 2010 | Makita Garden
I have a Jacuzzi Perfecta toilet (bought Aug. 21, 2008) at Lowe's. I have the sales ticket. The toilet works fine. The tank fills very slowly (2 minutes) before it shuts off. It also makes a whistling...
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Jun 10, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Sanibest toilet is LOUD when flushed
Shut down the power and pull the pump from the unit and give it a exam. There might be something as simple as a item that was flushed down the toilet (pencil, pens, combs, etc.) or just a hair clump. Check that the float is free to track fully up and down. Good Luck!
May 17, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Toilet pumps bursts of water
either your fill valve needs replaced or your flush valve needs replaced
May 13, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
RE: POWER ON PROBLEM
when I press power on button on my camera it brings 3 beeps and then turn off it self within seconds
Jan 31, 2008 | Samsung Digimax A400 Digital Camera
Sloan M-101526-F Flushmate?® Complete Replacement System for 501-B Series Logo
138 people viewed this question
Top Sloan Home Experts
richochet
ray gallant
Ted Maxwell
Are you a Sloan Home Expert? Answer questions, earn points and help others
