Question about Refrigerators
Chilled water stopped .chiller frozen in bottom of fridge
After initial fault as above the fan that stops when you open fridge door started to make noise like blades hitting something. This has now stopped but ice dispenser and water outlet have both stopped working. Fridge is cold at bottom but warmer at top.
SR-32 EMB MODEL, FREEZER OK, BOTTOM NOT COOLING PROPERLY. ADVICE SETTINGS
Posted on May 28, 2008
Why is there water in the chiller drawer on a French Door Refrigerator-Samsung?
We call that condensation from the moist vegetables, etc. in the chiller, natural occurrence.
Aug 21, 2014 | Samsung RF265AA Bottom Freezer French Door...
My f&p fridge freezer E240B is not chilling in the fridge part. I can't find any manuals or help on line for the product. Help please
Andy,
I am not familiar with the frig your referring to. However, MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped.
Oct 11, 2013 | Refrigerators
My aquarium chiller has stopped working. What should I do?
If you do not have a backup, try putting a frozen water bottle in your tank as a temporary fix until you are able to buy a replacement chiller.
Aug 29, 2012 | 1topstore Fish
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Indor ice maker water tube is frozen
If it is frozen, you will have to empty the food from the freezer, open the door and leave it open at least over night. I would doubt that it is frozen. I would suspect the water valve at the back, bottom of the fridge.
Mar 02, 2010 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
Hotpiont ffm90 fridge not chilling
hi if the freezer appears to work and the fridge if warm,the problem is that the freezer is over frozen and blocking the vents which send cold air into the fridge when required,and the noise is the fan hitting the the ice build up,defrost (switch off)your applinace for at least 36 hours then switch back on,you will then find after the freezer reaches -12 the fridge will then start to go cold.
Mar 09, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Chilling Fault
You are probably frozen up which causes the fan to freeze up. Thoroughly defrost the unit...if necessary, stop it for a day or more until all the ice melts. Restart. Cut down on 'window shopping', storing uncovered liquids. Check the door gaskets, clean if necessary or replace.
Jan 03, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
Refrigerators Logo
242 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
