Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9100LQ A late model unit about 8 years trouble free will not start after a normal use. Control is on no error codes, flashes on all selection and hold to start does not activate the machine in any way. Wife is yelling Help!!!!
  • Cheryl1027 Jun 02, 2008
    My washer won't start either. All the indicator lights are functioning, but the time just flashes and "hold to start" doesn't start it and "cancel" doesn't clear it.
After reading your posted comments regarding all the different problems with the front loader. I located the problem with the door latch activator similar to your car door light switch. As it ages/wears down it just disappears to the inside of the mount leaving no indication it is even there. As suggested in the comment on your forum you can place a small object inside the plastic switch to simulate the missing knob or possibly run a bypass electrically.
The part is only $56 and is readily available at dealers. My problem was I ordered it online and am still waiting for this to arrive even after they assured me from the order desk it was in shipping mode! Hmmmmm!!!!
Thank you
Posted on May 31, 2008
What does E6 error code mean
here is basic error codes for your dryer (and how to get them out)
READING ERROR CODES
1. Rotate cycle selector knob to the 3 O'clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O'clock position. The four indicator lights of Drying, Cool Down, Wrinkle Rid
(Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator
light will flash the number of times for the second digit. Take separate counts of each indicator light, then repeat to
confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times
the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light
will flash four times indicating the 4. The four indicator lights and the START indicator light start flashing at the same
time. The control will pause for 2 seconds, then repeat the code.
NOTE: A letter appearing in the code stands for a number higher than nine. A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. The four indicator lights would blink four
times and the START indicator light would blink ten times. Troubleshoot the problem by using the chart below.
To move on to the next code, press the OPTIONS button.
To clear code, press the Select button. Code will be cleared when mode is exited.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
Error Code Label Description Solution
E10 General EEPROM
Fault
Problem with communication
between EEPROM and the
microprocessor.
Clear code, exit mode and start dryer. If problem persists, replace electronic
control.
E11 Checksum Error Problem with communications or
memory did not check, one has
become corrupted.
control.
E12 Non fatal R/W
error
Problem reading or writing to the
memory or input/output.
control.
E24 Control NTC Short
Circuit
Control thermistor or its wiring is
shorted.
Remove wires from control thermistor. Measure resistance of thermistor. If
reading is not 50 K (± 10%), replace thermistor. If reading is within 50 K (±
10%), check wiring between thermistor and electronic control. If good,
replace electronic control.
E25 Control NTC Open
Circuit
open.
E4A Program Timeout
Fault
The drying time has exceeded
program time for that cycle.
Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes.
Position cycle selector to NORMAL, temperature selector to HIGH HEAT
and touch START. Check for anything that would extend dry times such as:
no heat, restricted vent, blower fan blade broken or loose, dryer installed in
closet with solid door, or bad connection in moisture sensor bar circuit or
dirty bars. If dryer operates normally but code returns, replace electronic
control.
E5B Heater Fault (no
heating)
Temperature reading of control
thermistor has not changed in a
certain amount of time.
and touch START. Measure voltage across terminals on relay RL2 (heater
relay) on electronic control. If meter reads 240V on electric models and
120V on gas models, replace electronic control. If meter reads zero, remove
power from dryer. Disconnect wire going to NO terminal on the relay RL2.
Reconnect power and measure voltage drop between terminal COM on
relay RL2 and neutral. If meter reads zero, wire between incoming line and
relay RL2 is open. If meter reads 120V, check the rest of the heater circuit.
E68 Key (button) Struck
Fault
One of the keys (buttons) is stuck
closed (active).
Enter function test mode and perform key (button) test to determine which
button is at fault. Carefully free the and perform the test again. If button is
free but the key struck code still exists, replace electronic control.
E8C Too many trips in a
period of time.
The safety (high limit) thermostat
has tripped too many times within
a certain period of program time.
Check for blocked lint filter, blocked exhaust, air leaks around air duct,
broken blower fan blades, worn or loose drum seals, dryer installed in closet
with solid doors or door seal not correctly seated.
EAF Watch Dog Reset Microcontroller has been reset by
internal Watchdog timer.
Jun 04, 2014 | Frigidaire Dryers
WHY DOES MY DRYER KEEP SHUTTING OFF WITH BLINKING LIGHTS
sure is heres how to get the fault codes
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
May 09, 2014 | Frigidaire Dryers
Kenmore Elite Smartwash Quietpak 9 HE 4t - Model 11045991400. Have been getting FH code on and off for past two years. Clean filters on top and bottom. Sometimes I would unplug and reset ckt breaker and...
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip, the valves will
be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
-Verify inlet valve operation.
If there is water in the unit:
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
8. Verify CCU operation by running a Diagnostic test or any cycle.
Your tech sheet is behind the service panel How to Access it.
Dec 15, 2010 | Washing Machines
Kenmore h2 error code
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore 46462 Front Load Washer
Whirlpool Duet Washer will not start
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Oct 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Rheem Pronto model#RTG-74PNV-1 has powered off for some reason unknown, I turned the unit back on and it supplied hot water for approx. 10 minutes before it started flashing a code [C7]on the remote...
Remove power source from the unit. If remote control2.gif is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support2.gif.
If this helps, please indicate so.
Mike//jzklipper@aol.com
Oct 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Front loading he3t, won't start cycle when loaded. light just flashes. Loaded up washer after a load just finished. close door and select normal wash or any other selection and the red light in the...
Jun 24, 2009 | Kenmore Washing Machines
Kenmore elite he3t model 4596640 year 2005 f33 code
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
May 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore He3 washing machine model #1105862 401 will not start.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!!!!!1
Mar 19, 2009 | Kenmore HE2 Plus Front Load Washer
Advantium readout flashing
I would say it is a sign of trouble.
Not to say that it's catastrophic, but on these models part can be pretty expensive.
We regularly repair such control units for customers nationwide by mail for in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
Whirlpool Duet GHW9150P Front Load Washer Logo
211 people viewed this question
Dan Webster
Dan Webster
Sal De
