Question about Philips Televison & Video
HOW DO I CONNECT MY PHILIPS 50'' PLASMA TO A BLUE-RAY PLAYER WHEN I HAVE ONLY ONE DVI SOCKET, WHICH IS ALREADY BEING USED FOR MY HD SATELLITE RECEIVER? I HAVE NO HDMI CONNECTIONS ON THE TV.
  • 80 Answers
If you use the component connections (red blue green) and audio you will get 1080I - no 1080p - buts thats ok few philips are able to show 1080p
thanks
scott
Posted on May 30, 2008
I just bought a phillips blu ray and trying to hook it up to my sanyo 50" plasma through a hdmi i get video but no sound the tv says to use the dvi port and audio 3 inputs but the blu ray does not hav
Hello there, the hdmi cable is a great way to get high definition video from a bluray player to a tv, but if the bluray player is part of a surround sound system you will need to get the sound to the tv separately. There is often a red and white audio terminal in the rear of the bluray player, sometimes located next to a yellow terminal, these are known as a component connection as each component (coloured terminal) is separate and operates a separate function, but all 3 connections can be used together to create a SCART equivalent. You may need to connect an 'Audio Component to 3.5mm jack' cable from the white and red terminals to the headphone/line in socket on the tv.
alternatively, as wilth my player, there is a button on the remote which switches the audio source from component, hdmi, SCART, etc, this may be the same for you.
hope this helps.
Mar 12, 2014 | Televison & Video
I want to hook up a blue ray dvd player they told me to m=buy HDMI cable and this only goes to the tv, but doesn't have to go hooked up through the cable box
If you want to connect your blu-ray player to your tv, use the HDMI cable.
If you want to connect your cable box to your tv, I'd use component cables or get another HDMI cable.
You're right, you don't have to use your cable box to use your blu-ray player.
Mar 10, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
TV does not have aHDMI port so what audio and vdeo csbles needed to connect to a Sky HD box ?
Hello
There is a side socket connection set on your Philips TV. You can connect two audio channels Left and Right and one Video. Connect these socket with an AV cable, and connect the other end of that cable to your SKY HD boxe's respective output sockets. Then select the TV input to AV by going into its menu and surfing through it. That is all for settings. OK
Jan 16, 2011 | Philips 50PF7320A 50 in. Plasma HDTV
Just bought blue ray player I have a hitachi plasma tv model pw1 32pd5000 how can I get blue ray to work with tv theres no hd outlet at the back of tv but it is hd compatible
The TV most likely will have component and a DVI connector on it if it doesn't have a HDMI connector. If the Blu-ray player has component connectors on it use them as they will give you up to a 1080i picture which is all this model of Hitachi supports anyway. If the player doesn't have component connections then you can get a HDMI to DVI converter cable so you can connect it to your TV. You will need a cable that looks like this...
http://www.kmart.com/shc/s/p_10151_10104_25000PCM-2296-06P?vName=Computers%20&%20Electronics=&cName=HomeTheater&Audio=&sName=Accessories&psid=FROOGLE&aff=Y&sid=KAx20061023x272xTier3
Nov 11, 2009 | Hitachi P42A202 42 in. Plasma TV
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
How to connect blue ray to philips 46" hd tv with direct tv service
Connect using hdmi or component video from dvd player to tv.
Apr 24, 2009 | Televison & Video
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
