Question about Kenmore Oasis HE 27082 Top Load Washer
Machine shakes and bangs in spin even when tud empty
  • 54 Answers
This sounds like your feet are not leveled. the quick fix is to put your hands on the top of the machine and shake it softly trying to find the short foot. It should feel just like a table with a short leg. Once you find which two feet do not touch the ground at the same time( it should be one in front one in back on diagonal corners) lean it back and you will find that the front foot is on a screw and you just screw it out until your washer is level. It is a really simple job.
Posted on Oct 05, 2010
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
Loud noise during spin cycle
Open the cabinet top and check along the sides for a broken or out-of-position damper. Shake the mechanism in several directions to help locate. Hope this helps!
Jun 12, 2010 | Kenmore HE2 Plus Front Load Washer
Shaking washing machine
If the shaking is during the spin cycle and you are using the High setting change it to Medium. This may fix the problem and the clothes will probably come out even dryer since the drum is not banging around.
Sep 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bangs in Spin Cycle even Empty
alot of people don't level there machine properley pull out a level and level the machine what it is when the machine gets up to speed the drum is not level
Feb 12, 2009 | GE Energy Star WCVH6260F Front Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
How to balance machine during the spin cycel?
i have found that by leveling the washer all four sides turn the locking nut up on the rear legs lock them then run up both front legs about 1/8 in higher than rear also lock them it takes almost all shaking out if the 2 dampner shocks are hooked up
Jan 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
