Question about HP Officejet 5610 All-In-One InkJet Printer
The carriage is continually jamming - HP Officejet 5610 All-In-One InkJet Printer
    Guru:
  • 224 Answers
Although I know I ain't going to get 4 stars for providing the resolution as this may resolved the issue since this is concerned with the hardware card of the printer but anyway .
Goto this link and follow the steps in the document
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=441125
Even after this if it doesn't work then call up HP total care at 1800-474-6836 and ask them for an upgrade option rather than getting a printer which would be around $500 in the store you would get a discount of 50/60% as well as a carepack warranty(covering hardware and tech support) for 3 years with a 70/80% discount (this is the reason I don't expect to get 4 thumbs up,as this is a hardware problem).
Posted on Oct 05, 2010
Error 01 carriage jam on avantra 44s what can i do?
MAYBE THE CARRIAGE IS FAULTY.DID U TRY A NEW ONE
Nov 19, 2013 | Panasonic Workio DP-4530 Copier
Carriage jam
cannot print, msg shows Error carriage jam, Open door, clear carriage jam, and then press o.k. to continue.
paper has been cleared , opened door and even took off back compartment
Dec 22, 2010 | HP OfficeJet 7310 All-In-One InkJet...
My printer made a weird noise and now says "Open door Clear carriage jam and then press Enter". How do I clear a carriage jam? I have opened the top cover and usually the print cartridges move to the...
Issue The error ' Open Door, Clear Carriage Jam, and then Press Enter ' displays on the product. The following symptoms might also accompany this error:
* The product will not print. * Printing stops unexpectedly. * The carriage does not move.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. Solution one: Turn the All-in-One off and on again
1. Press the Power button ( ) to turn off the product. 2. Press the Power button ( ) to turn the product on again.
* If these steps resolved the issue , you do not need to continue troubleshooting. * If the issue persists , continue to the next solution.
Solution two: Clear any paper jam A carriage jam might follow a paper jam. Follow these steps to check for and remove any jammed paper. Step one: Check for and remove any loose paper from the input tray Remove any loose paper from the input tray, the output tray, and the automatic document feeder (ADF). CAUTION: Do not remove jammed paper at this stage. Step two: Clear a paper jam from the rear access door WARNING: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the printer slowly and gently. Avoid touching the internal components of the printer.
1. Disconnect the power cord from the back of the printer. 2. Remove the back door and remove as much jammed paper as possible.
3.Replace the back door and open the carriage access door. If there is paper visible that cannot be removed through the back door, gently pull it out from the front.
4. Reconnect the power cord and close the printer.
Solution three: Make sure that the carriage moves freely
1. With the product turned on, open the cartridge access door. The carriage might try to move into the access area. If so, allow it to move to that position. 2. Without turning off the product, unplug the power cord from the back of the product. WARNING: You must disconnect the power cord to move parts by hand without the risk of an electrical shock. 3. Look in through either the cartridge access door or the output paper tray to make sure that the cartridges are secure in the carriage and not loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving. 4. Make sure the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You might have to reach through the output paper tray to access the carriage. 5. Close the cartridge access door and reconnect the power cord to the product. 6. Press the Power button ( ) to turn on the product.
Solution four: Remove and reinsert the print cartridges Incorrect installation of the print cartridges can cause the product to show a false carriage jam. Follow these steps to remove, and then reinstall the print cartridges. Step one: Remove the print cartridges
1. Press the Power button ( ) to turn off the product. 2. Open the front of the product to access the carriage. The carriage moves to the center of the product.
3. Unlatch the two print cartridge latches, and then raise the latches. 4. Remove the print cartridges.
Step two: Reinsert the print cartridges
1. One at a time, hold a print cartridge with the printed label up, and then slide the print cartridge into its slot. Repeat this step for the other print cartridge.
# NOTE: Insert the black print cartridge into the slot with the gray latch, and insert the color cartridge into the slot with the blue latch. # Grasp the end of the latch on the cartridge slot with your thumb, and then pull the end of the latch toward you. While holding the latch, press down on the top of the latch until it stops, and then release the end of the latch so that it catches under the tabs. CAUTION: To avoid damaging the product, do not force the latches into place.
3. Close the product cover. A message displays on the control panel to align the print cartridges. 4. Press the Enter button to begin the cartridge alignment. Two pages print. Follow the instructions printed on the second page to complete the alignment. 5. Try the print job again.
Jul 08, 2009 | HP PSC 2175 All-In-One InkJet Printer
Carriage jam error
The Jam error is most likely cause by one or more of the sensor flags these are the plastic usually black things hanging along the paper path. One of those are either stuck or broken. Check the path and look for those items.
Feb 13, 2009 | HP Photosmart 3210 Printer
Carriage jam
Hi joinus,
Please click on following link and follow the document. which will help you out to resolve the issue,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786043&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Regards,  raj_p5983
Jan 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error message
hi,
below is the document that i want you to follow to somehow resolve your issue.
CLICK HERE TO VIEW DOCUMENT ==>> CARRIAGE JAM
Please let me know the outcome after you perform the steps.
thank you so much.
adonscott
Jul 10, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
