Question about Roper Dryers
DRYER NOT GETTING HOT - Roper Dryers
  • Roper Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 06, 2010
Why is dryer is not getting hot enough
not getting hot or hot enough? if not hot at all it's probably the thermal fuse is blown, if not hot enough you could have a blockage in the blower vent system, which could be from the blower wheel in the dryer to where it vents out of your house. if no blockage then it's probably one of 2 cycling thermostats
Feb 13, 2016 | Crosley CEDC392JQ Electric Portable Dryer
Dryer not getting hot
If your dryer is not getting hot then it is probably your heating element inside the dryer that has gone bad. They are not hard to replace if you are mechanically inclined. If not, it will need to be serviced by someone who knows how to replace it.
Dec 02, 2011 | Fisher and Paykel Dryers
My dryer is turning but it isn't getting hot? What
dryer element not getting hot .possibly only 110 volts instead of the needed 220volts ...maybe a bad breaker in fuse box
Nov 29, 2011 | Kenmore Dryers
Dryer is getting too hot
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 10, 2011 | Whirlpool WED5300S Electric Dryer
Maytag dryer is getting hot,but taking a long time to dry clothes.
Check your dryer vent see if air is coming out if dryer is getting real hot its dangerous have dryer vent cleaned
Dec 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not getting hot enough
the heat sensor or spark ignitor is at fault
Feb 28, 2010 | Whirlpool LER4634J Electric Dryer
Our kenmore eliite HE4 gas dryer keeps shutting off after a few minutes of running no mattter what heat setting we put it on. On air dry mode it works. Is this a high heat sensor problem? The unit is 4...
You didn't mention if the dryer is getting hot.
If is getting hot, then shutting off, I agree with you.
If it is NOT getting hot, I would suspect the IGNITER ASSY
Dec 13, 2009 | Kenmore Elite HE4 Electric Dryer
I have to run the clothes through several cycles before they are dry
It sounds like you have a plugged dryer vent. Clean the vent from the dryer all the way to the outside of the house.
Aug 11, 2009 | Roper RES7646KQ Electric Dryer
Dryer is running fine just not getting hot
It sounds like the thermal fuse or heating element are defective. Both components are easily checked with an ohm meter or multimeter. The fuse is usually inside the back of the dryer by the exhaust duct. Both components should have continuity, if not they need to be replaced. Sure hope this helped.
Jul 20, 2009 | Roper REX4634KQ Electric Dryer
My Whirlpool LGN2000PGO not getting HOT
Have you checked the gas valve to make sure that it is functioning correctly?
Feb 13, 2009 | Dryers
Dryers Logo
59 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
