Question about Nokia BH-503 Bluetooth Headset
Does not charge when the charger is plugged. The Red light does not turn on.
Just wait for the battery to be completely drained-I did that to mine just now.after the battery is completely drained, I charged it, and it began functioning again.
Posted on Jan 04, 2011
  • Uday Jadhav May 23, 2012
    Does it Really Works???
  • kartik meena
    kartik meena Oct 27, 2012
    how to drain the bettery fully can u plesse explain it step by step
I am facing the same problem
when i connect my charger to the bh 503 then the reed light is'nt blinking
i mean nothing heppend when i connect the charger
i think that the problem with the led so i keep charging my bh 503 for an hour but it is'nt charging
i bought it last 2 day ago
and i m facing this problem dont know what to do
and anyone plese tell me that how to drain batery
Posted on Oct 27, 2012
  • Sumit Kumar Mallik Jun 12, 2013
    same prb to mine device also....please share suggestions...
You should try charging with the ac-4,ac-5,dc-5.. And if it still not works properly den reset your headset by press and hold multifunctional key and volume up key ..till the light goes green..!! Ol d best
Posted on Jun 26, 2013
  • 652 Answers
Yes sir
Posted on Oct 08, 2010
How to charge the batterry
the charger port is located under the front of the joystick. with the charger off plug the 3 pin connector into the charger port then turn the chrger on or plug it into the wall. You should see a red and a yellow light when the yellow light turns green the batteries are charged turn off the charger and remove the plug from the joystick See my tip on charging Hope this helps you
Jun 05, 2011 | NRS Hoveround MPV 4 - Hovaround Used...
Tip
Charging your power chair or scooter the correct way can make them last
Whenever you need to charge your power chair or scooter get into the habit of charging overnight. The battery level indicator lights will tell you if your chair or scooter needs charging. Whenever the lights are down into the yellow and especially if they are in the red. If you have the off-board charger, plug the charger into the charger port in the front of your joystick and then plug the charger into the wall socket or turn the on/off switch on and let it charge overnight. When you get up in the morning the charger should have a red light(power) and a green light illuminated (indicating fully charged) Always turn the charger off or unplug it from the wall socket before you unplug it from the chair or scooter. Never have the power on to the charger when you plug or unplug it from your chair or scooter. Whenever you get new batteries always give your batteries a full charge before use and then if you use the chair daily charge it every night. If you do not use your chair or scooter daily charge it at least once a week. Never leave the charger plugged in and on for more than 24 hours. Your batteries should last you 3-4 years if you charge them correctly.
on Sep 20, 2010 | Health & Beauty
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
How do i charge the battery
Carla Under the front bottom of the joystick you will see a charger port its a three pin port that accepts the plug from the charger. Always plug the charger into this port with the charger off or not plugged into the electircal socket. Then plug the charger into the electical socket or turn it on. You should see a red light and a yellow light on the charger. When the tellow light turns green the batteries are charged. You should get into the habit of charging the batteries each night if you use the chair daily. Just plug in the charger when you go to bed and turn it off when you get up. If you only use the chair a little then always store it fully charged and then charge it once a week if it hasn't been used. Hope this helps you
Sep 12, 2010 | Quickie Wheelchairs Quickie Aspire Power...
How do I know when the chair has charged? I see one red, two green, two yellow lights on.
If you have an off-board charger that plugs into the joystick there are two lights on the charger one red(power on) and the other yellow (turns green when fully charged). Plug it into the chair and if the light is green then you have fully charged the batteries. Now if you have the on-board charger the charger meter on the rear of the chair will resd zero when fully charged. Hope this helps ya
Aug 18, 2010 | Electric Jazzy 1115 Power Wheelchair
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Nokia BH-503 Bluetooth Headset Logo
1,484 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
