Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
It worked great and then suddenly won't turn on- don't have a manual, bought it on clearance- is there something i am not doing? i emptied the dirt out of it and brushed off the filter. Does it stop running if the filter needs changed?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 22 Answers
It sounds like the reset thermal switch has to be reset. Most vacuums have a reset switch on them some were and that is usually by the motor or the very bottom of the machine. If the switch was activated you just need to push it to reset it but there might be more to your problem then you know. The switch might have to be reset because of these problems that need to be handled first or it will happen again. First is the motor might be getting hot caused to pluged air ways, bag to full, hair or something like that wrapped around the spinning brush at the bottom of the machine. You need to make sure the roller on the bottom is not tied up that would over work the machine and cause the switch to come on. Also their are on some machines small air filters for the fine dust see if those are plugged as well these could casue the problems as well. thanks
Posted on Oct 05, 2010
My Dirt Devil Bagless Upright suddenly has no suction either in the main part or the hose. I did vacuum up a ton of cat air 4 days ago, then empty the debris container. I can't afford a new vacuum.
i. get something long enough to go through the entire hose.
ii. push through hose as there may be some hairballs in there.
iii. check unit for blockages
if hose is blocked you could also flush it out with high pressure water, then allow to drip-dry.
iv. get a sphynx? :)
Our American bi-color short-hair sheds black& white.
Nov 20, 2017 | Dirt Devil Vacuums
My Dirt Devil KONE Hand Vacuum won't unscrew to empty
sounds like it may be cross threaded , or bits of grit holding it tight ,try tapping round the rim with screwdriver handle to see if it will loosen anything that's holding it ,then get someone else to help you hold one end and you hold the other end and twist..
Mar 11, 2013 | Dirt Devil KONE Hand Vacuum MO213BLU...
How do you empty the dyson dc07 dirt container. I cant get the container to open
Sorry to hear you're having difficulties emptying your DC07. The bin is designed to empty from the base when you pull the trigger under the carrying handle - you can see the correct way to do this in the user guide supplied with your cleaner. In case you don't have yours to hand, here's an online copy:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
If you're following these directions and the bin won't release, please get in touch with us directly so one of our experts can provide further assistance. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Customer Service
Aug 06, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
My bissel vacume was not picking up the dirt on the carpet. So I found that the hose was clogged. I unclogged it but the vacume still is not picking up the dirt. I also changed the filters.
I found out that if you remove the front filter holder, tip vacuum back and look down inside. Sometimes there is hair caught back in there and you won't get suction. I had to use something long, knife, very long type tweezers, to pull all the hair out. Worked great after that. About half way through vacuuming I will stop and remove the foam rubber filter and clean it. Oh yea, you will have to use a flashlight to look down inside to see all the hair caught behind the foam rubber filter cup.
Dec 14, 2009 | Bissell 6594 PowerForce Bagless Upright...
I just bought this vacuum. Is there a trick to
on mine there is a *** handle on the top of the canister pull the handle up and pull the can. out away from the vacuum
Jul 01, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Kenmore Quick Clean - how to remove dirt from cannister
this is the web site for Kenmore owners manuals
--->http://www.managemyhome.com/mmh/<---
Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Kenmore Quick Clean 30012 Vacuum
Embedded Dirt Finder green light won't come back on - stays red
The dirt sensor is a motion detector. After it gets dirty it will either stay red or stay green. You can have the vacuum serviced at your local vac shop and possibly get this fixed. Sometimes they are as good as new and sometimes they are not repairable. It will not effect anything else though.
Jun 09, 2017 | Hoover U6634-900 WindTunnel Bagless...
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
101 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
