Dru concerto fire pilot lights and stays on light fire ok for a minute or two clicks fire and pilot goes out
  • 37 Answers
SOURCE: the pilot light will not
I assume this is a gas log? If so, you have dust in your pilot assembly. Turn everything off and let it cool. Note the opening where the pilot flames burns. Use the wand from your vacuum cleaner and place it over the opening for the pilot flame. Gently tap the side of the pilot assembly while holdign the vacuum above the opening. This will lift the minute dust particles out and allow the flame to burn nice and blue again. These logs have Oxygen Depletion Valves on them. The pilots are very sensitive to dust.
Posted on Jan 18, 2011
  • 49 Answers
SOURCE: pilot light will not stay lit
The flame must satisfy the thermocouple. Then the thermocouple must satisfy the valve. If you have a great flame on the thermocouple, it is possible that you have a bad gas valve, if no other saftey switches has you shut down to not allow the valve to open.
Posted on Nov 20, 2007
SOURCE: Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Posted on Dec 06, 2007
hotuna
  • 288 Answers
SOURCE: cozy wall heater lights fine then goes out after 3 or 4 minutes
Make sure all the wire connections are good and tight. Next lift off the cover and look for a little thermal disc mounted up by top of the heat exchanger. Most have a re-set button but not all. If you have this ,by-pass it ,see if that solves the problem, if so it may be defective, or doing its job and you have a venting problem. If you don't have this and have changed the thermocouple (was it a copper tube with a fitting that screwed into the gas valve, or did it have 2 wires, that is a pilot generator, kind of same thing) make sure the probe is set correct, with the pilot flame heating the top 1/3rd of the probe. The only thing left is the gas valve.
Posted on Dec 25, 2007
SOURCE: Pilot light won't stay lit
Wrong voltage thermocouple? must have 400mv, residential uses 25-40mv.
Posted on Feb 13, 2008
My jotul 200 direct vent gas stove pilot light won't stay lit. The pilot lights normally, and fires when the thermostat calls for heat. But when it turns off the pilot goes out as well. We cleaned ou
There's a little screw that adjusts the pilot light. It is usually on the block with all the other valves. Follow the pilot lite supply line to where the screw probably is located.
Nov 22, 2013 | Stoves Heating & Cooling
Have winrich perfecta ventfree lp model 6380. Very hard to start. Ignition switch never worked correctly. Pilot and ods showing corrosion. Doesn't stay lit very long. Can I replace the pilot/ods a
First clean out pilot light with can of air , or blow down it with a tude.
Then brush electrode clean with a clean paint brush ,chech to see if electrode is in the right postion to light the gas not too far away and the spark is strong , Clean thermopile head if fitted, then check thermocuople /thermopile connections are tight . see if this helps .
Oct 28, 2012 | Heating & Cooling
When I press down and turn the know the pilot lights but as soon as you let up on the knob to turn it there is a click and the pilot light goes out.. This is on my Mr. Heater Big Buddy
When the pilot lights continue holding the button down for a full minute and then release. It should stay lit then to allow you to turn it to the on position. If the pilot will not stay lit after holding it for the full minute, then the thermocouple will need to be replaced.
Hope this helps.
Sep 16, 2011 | Mr. Heater Big Buddy Heater
The pilot light will not stay on for more than 5min. If I light the fire when its on,it just goes out. The fire is a Fusion 2/7
Jan 18, 2011 | Heating & Cooling
Fire often closes down. pilot light goes out first with loud click followed by main burner
i would stay the pilot needs cleaning and check thermocouple the pilot is blocked or the flame is flopey
Aug 07, 2010 | Stoves Heating & Cooling
Pilots lites , holds ok for minutes,but once move
Hello KJGreen, It sounds, based on your description, as though the thermocouple is faulty and should be replaced. If the pilot light stays lit and you've left it on for several minutes before turning the knob on to light the log set, then that indicates that the thermocouple is bad.
The thermocouple is a safety device (heat sensor) designed to stop the flow of gas to the burner in the event the gas flame goes out and the pilot goes out. The sensor will only allow the gas valve to open once it has reached the preset temperature.
To confirm that the thermocouple is defective, I would light the pilot light and allow it to remain lit for up to 10 minutes before I attempted to turn on the log burner. If, after 10 minutes, the log burner still won't stay lit, then you know that the thermocouple needs to be replaced. Otherwise, the burner should light, since after 10 minutes, the sensor should be hot enough to signal the gas valve to open.
If you are going to have this replaced, please make sure you use only an approved supplier, since an incorrect replacement part could cause an unwelcome malfunction of the gas log burner. Safety should be primary when dealing with open flame burners.
Hope you find this Very Helpful and best regards!
Nov 23, 2009 | Vanguard International Infra Red - Large...
Floor furnace pilot won't stay on.
Change the flame sensor (Thermocouple) Then go ahead and fire it up. If the flame sensor is not sensing the flame you will be able to light the pilot then everything will shut off. There is a way to agjust the pilot but 99.9% of the time the adjustment is ok, Specially with a floor furnace so change the thermocouple and you will be ok. You can get one at Ace, Home Depot Lowes, or a local appliance store
Feb 19, 2009 | Fisher and Paykel GWL11 Top Load Washer
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
195 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
