Question about Century "Bob" Body Opponent Bag
I need a cap for the opening where you put water or sand in my century BOB striking dummy. Any help?
Trying to put pump system together. Do we remove the drain screen before adding sand?
Our terminology is not coinciding...
Follow these steps...
  • 1st - understand that a pump moves water thru your system.
  • A filter cleans your water
Sand does not go into a pump.
sand goes into the filter.
  • when adding sand into filter tank, top valve is not in place, you Need to first add water, to cover the laterals at bottom
  • Then PLACE a cap or something/anything, over the stand pipe, so NO sand goes into that pipe! IMPORTANT! Begin to add sand.
    • Do this slowly, being very careful to NOT disturb position of stand pipe! Do NOT Lift it or allow it to rise up! Keep it centered!!
  • Add required amount of sand
  • Remove stand pipe cover/cap that placed
  • Install valve onto tank
  • Complete plumbing in-out of the valve
    • Presuming you have the plumbing complete from and to pool?
    • Pool suction port to front of pump. Out of pump into 'Pump' port of filter valve
    • Out of 'Return' port to pool
GOOD LUCK
May 31, 2015 | Waterway Pool & Spa
My grandaughters baby born doll won't close his eyes when you put dummy in. you can manually close the eye so it isn't stuck. any ideas how to fix this
We had the same problem a few months ago. We even bought another dummy, but it did not help. Then we found the solution by ourselves. My daughter took her baby born to her bath and we put her into the water. Then I pressed ******* the face for water to go inside through the eyes many times. After I did it a few times with a lot of water the doll start to close and open her eyes again with her dummy. I do not know for what reason but eyes start to stick inside. I believe it may be because of the food, or dust. Maybe not. However from my observations it happen when we did not bathe her for a long time.
I hope it helps.
Aug 04, 2012 | Zapf Baby born 778166
How do you fix the bob when it has a tear in its neck. the head is starting to come off.
I had the same problem, started with inch long tear in his adams apple ,eventually more than half his head was fallin off. I took a nice sharp knife and pirced a hole an inch above and below the tear every 4 or so inches and stuck zip ties through em. Feed the end of the tie through the top hole going inward. Do all the top holes like that. Once your done with the top feed the now inside ends of the ties outside through the bottom holes. Do this all the way across, THEN feed the ends through the locks and zip em tight. i then put a scarf on his neck to hide the tie ends, or i suppose you could tape em down. I dont think striking the ties will do any damage to your hands it just looks tacky. Make sure your holes are atleast an inch away from the edge of the tear so the ties dont rip through the "skin" inbetween them.
Jun 19, 2012 | Century "Bob" Body Opponent Bag
Century bob
Cheap plastic nipples are stripped out! Moving it while Bob is still attached & kids jumping on Bob's shoulders did the same to mine... I am going to try short bolts & nuts after dipping in plasti-dip/rubber product of some sort.
Nov 21, 2011 | Century "Bob" Body Opponent Bag
I have an older Hayward pool filter. Is there a link to dowload instructions for replacing or adding sand to the filter?
Here is how I do it. Open the top. Open the drain on the bottom to allow the water out. Remove the plastic water difusser on the top. With a small can, scoop out the sand. When you get to the laterals, remove them for inspection. The sand below the laterals if fine, it does not need to be removed. Put the plug back in. Replace any laterals that may be broken (probably none) Fill the filter with water to about 6 inches above the laterals ... maybe more. The water will protect the laterals from the new sand as you fill the filter. It will also help the sand to pack in around the laterals. Continue filling until you are about 3 inches below the difusser that will go on the top. Make sure you don't bury the little black hose. The purpose of the little black hose is to remove the air from the filter during operation. The hose should ultimately stick up into the inside of the top (cover). I think your filter takes about 300 # of sand. Double check with your professional pool supplier where you purchase your sand. I normally will fill the filter with water before I replace the top. You may want to put on a new "O" ring too ...
This new sand should last you at least 4 to 5 years in non commercial use. After that time, you may want to replace the top 4 inches with new sand.
Thanks for your question @ FixYa.com
Jul 06, 2011 | Hayward SAND FILTER, PRO SERIES
Priming a hayward super pump
IF IT DOES NOT FILL CONSTANT FROM POOL IF IT IS AN INGROUND YOU WILL HAVE TO HELP IT BY PUTING A GARDEN HOSE WATER ON IN SKIMMER PUT A RAG AROUND HOSE FILL CUP TURN OFF RETURNS OPEN BLEEDER VALVE ON FILTER LET WATER FILL START PUMP AND OPEN RETURN VALVE SLOWLY YOU MAY HAVE TO DO THIS SEVERAL TIMES MAKE SURE AFTER YOU GET WATER FROM BLEEDER YOU CLOSE MAKE SURE ALL CONNECTIONS ARE TIGHT INCLUDING CLEAR CAP ON PUMP THESE ARE AIR BLOCKS IF ABOVE GROUND CHECK ALL HOSES AND CAP
Jun 30, 2009 | Hayward SAND FILTER, PRO SERIES
My name is bob michalski,and i have just replaced a heater core in my buddy's 1991 buick century,we have heat,i just can't find what's wrong with the defroster's there's very little heat coming from the...
a kink in the hose will cause poor water flow so it will be slow to heat and may cause the heat not to be as hot, as for the defrost, check the operation of all diverter doors, should be vacuum controlled, you may have a vacuum leak under dash or missing hose
Apr 07, 2009 | 1991 Buick Century
How do you open the gas cap for a harley fat bob 2008
Obviously it's not the stock gas cap. If it's a flush mount. You push it in then turn it to the left while it's pushed down. it will pop up, then you can unscrew it normally.
Apr 04, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Century "Bob" Body Opponent Bag Logo
61 people viewed this question
Top Century Sport & Outdoor - Others Experts
Are you a Century Sport and Outdoor - Other Expert? Answer questions, earn points and help others
