Canon pixma mp 272 I am getting a 03 error ie paper jammed however there is no paper in the machine and nothing jammed
SOURCE: Canon MP 510 paper jam
I had the same problem and found a small coin in the back feeder. Remove the back coverplate and tip the machine onto its back and give it a good shake. You might be surprised at what falls out.
Posted on Jun 18, 2009
pineworks
  • 4041 Answers
SOURCE: paper won't feed through canon printer. no paper jam apparent -
Hello there gave it a go this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
thumu
  • 69 Answers
SOURCE: False Paper Jam
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to Paper Jam error messages even though there is no paper jam in printer . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
This issue could happen if there is an issue with any small paper jam in the Printer, or due to the communicational issue .
To isolate the issue, I recommend you to perform below steps.
Steps are:
1. Power OFF printer and then please Disconnect the Printer from Computer and then disconnect the Power cable of Printer from wall outlet.
2. Check thoroughly in Printer that there is no small piece of paper in the Printer.
3. Let the Printer be disconnected and idle for 5 minutes.
Meanwhile please perform further steps on Computer.
  Note: The below steps are applicable if you are using WINDOWS 2000/XP/VIsta Operating system in  your PC
  Steps are:
 Perform the below steps to restart the print spooler :
1. Click Start>Run
2. Type services.msc
3. Click OK
4. A Window will pop up with so many services listed.
5. Scroll down to locate "print spooler" in the list, right click on it and click "Restart"
6. Restart the Computer.
Once if you are done with steps, please connect the Printer and then Power ON Printer and check the issue.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Posted on Oct 20, 2007
svenby
  • 66 Answers
SOURCE: canon pixma mp☺50 error 3
  • try this...........
  • Turn off the printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset eeprom). To disable the printer “Power” button to click again.
  • Posted on May 29, 2008
    SOURCE: paper jam problem in pixma mp145. E3 error.
    I have trying resseting and the error message does not clear. I have checked the printer througly and there is no paper jam.
    Posted on Nov 29, 2008
    My printer (mp 160 pixma) shows error code 5,3,2 what is the problem
    E2 = Reload the paper correctly and press [Black] or [Color]
    E3 = If paper has jammed in the machine, clear the jam, reload the paper in the
    machine correctly and then press [Black] or [Color].
    E5 = The FINE Cartridge may not be installed properly, or the Cartridge may notbe the compatible with this machine. Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment.
    Nov 02, 2013 | Canon Pixma Mp160 Mp 160 Photo All-in-one...
    Canon printer error p10
    when i print document,the paper jam message always displayed,but no paper is jam at printer
    Jul 23, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    My all in one has an error message
    E3 is a paper jam they may be small bit paper jam in side
    Jan 17, 2010 | Canon PIXMA MP160 All-In-One InkJet...
    MP 160 flashing error E then 3. doesn;t respond to anything I try to reset it
    hi,
    CANON PIXMA MP160 All-In-One InkJet Printer
    has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.canon.com/printer/prob676ijt65/solution
    mbhd13
    Jun 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    I have a Canon MP 520 Pixma printer and getting error code 6000
    There is got to be a paper Jam inside the printer OR
    Look for something that might have stuck up the roller ..
    Thanks
    Fame !
    May 02, 2009 | Office Equipment & Supplies
    I have canon PIXMA MP
    E3 error on the MP150 is a paper jam error. Make sure that there is nothing obstructing the paper going into the printer and that the feed mechanism doesn't have anyhting in it. Also run a roller cleaning from the printer software.
    Nov 23, 2008 | Canon Office Equipment & Supplies
    Error e 3 with mp150 but no papper jam
    this is a paper jam,
    As the machine is a old model you might as well strip the machine down and inspect it for any lose paper, it could be the reg sensor has bent causing it to always say the same error.
    by the time you have tried all this i would maybe look to buy a new machine with a years warrenty from Canon
    Hope this helps
    Oct 09, 2008 | Canon PIXMA MP150 All-In-One InkJet...
    730 people viewed this question
    jasbo
    jasbo
