Question about IBM Wheelwriter 6 Typewriter
Keys won't strike the wheel - IBM Wheelwriter 6 Typewriter
  • IBM Master
  • 3,594 Answers
The plastic print solenoid cap is probably broken. We sell them with shipping and instructions for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Posted on Oct 05, 2010
Swintec 2500 printhead won't strike the cartridge ribbon.
there is a rubber seperator that is bad this will not let it hit hard enough to strike the print wheel. your local typewriter shop should take care of it.
Feb 01, 2017 | Swintec Office Equipment & Supplies
Stuck eldorado key in DTS ignition now car won't start
Make sure your steering wheel isn't locked. Sometimes a key won't turn until you jiggle the wheel while trying to turn the key.
Aug 21, 2012 | 2004 Cadillac DeVille DTS
Smith corona electra 110 Strike the key, won't work.
If it does nothing at all the pawls that engage the drive shaft may be gummy a little WD40 if it makes sounds like something is happening the connecting wire to the type bar is probably unhooked. You can swap it with a rarly used key and sometimes get away with it.
DickyO
Jun 04, 2012 | Smith Corona Office Equipment & Supplies
Model 917-372832 Eager-1 5.5 HP . Stopped running . Won't restart. I believe the timing may of moved. How to remove the fly wheel to check key position? The key may have stripped. Hit a rock which may...
Hi, you are correct, the key will be sheered. Remove the top shroud and flywheel nut, then while pulling upwards on the flywheel have someone strike downwards on the crankshaft with a hammer and brass drift. Do not use a steel drift as it will damage the crankshaft. Hope this helps, regards Phil.
Jul 18, 2011 | Craftsman Garden
When I put the key in and hold the steering wheel it won't unlock and my key won't turn
the steering wheel has a locking devise released by the key when starting, at times the wheel is turned in a way that keeps pressure on the lock that makes turning the key harder, this is the same in most cars, so a little jiggle of the wheel will make turning the key much easier, please take a moment to rate my reply Good Luck
May 19, 2011 | Volkswagen Jetta Cars & Trucks
Wheelwriter 6 typewriter hammer no longer strikes
It is pretty common for the pad on the solenoid to strike the keys wears out, and for the batteries to be dead for the memory. Your machine probably needs a good cleaning, oiling, and a new pad for the striker. about $100.00 in the shop.
Jun 30, 2009 | Office Equipment & Supplies
Cannot get daisy wheel to type correct letters
Turn oFF the typewriter, take the ribbon out.....use the lever on top to release and remove the print wheel cartridge. Lightly rotate it to see if it will move and reinsert the cartridge. snap it back into place.
Turn on the machine, the typewriter should move the carrier to the left and reset the printwheel....if it is snapped back properly.
Jan 14, 2008 | Brother GX-6750 Typewriter
IBM Wheelwriter 6 Typewriter Logo
111 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
