Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP OfficeJet 6210 printer
When the printer is plugged in the outlet, it doesn't come on. The power light just "flickers" and makes a clicking noise.
  • Giovani1059 Nov 21, 2008
    When I pull the power It will initialize and reboot and works fine for about 5 min then it would start flickering and the buttons would cease to work. Power light goes out and auto answer would go out. When I try to print it prints fine. Tried the reset and semi-reset with no changes.
I just solve the problem on my HP 2610 making the clicking noise and the power light flickering by unplugging the power cord at the power supply and re-plugging it. The problem went away. Even though I had a green light at the power supply it is obvious I didn't have a good electrical connection. Thanks for the advice.
Posted on Sep 20, 2013
Check whether the power adapter is connected to the walloulet. place your palm on the power adapter and check whether it is warming or not. cool to hand(good) warm (Bad). Remove all cables to printer, Wait 30 seconds, Plug in the power cable and USB / Ethernet cable to All-in-One and also to wall outlet.
Posted on Nov 21, 2008
  • 27 Answers
Unplug all the cables ang plug them back in
also try reseating the cartridges
Posted on May 31, 2008
My printer stopped working. all the lights are flushing
Hi
1. Please check the power cord etc are plugged in properly.
2. You may try another power outlet.
3. Please check for any wires / components burnt etc.
Thanks
Aug 13, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My HP 6210 all in one printer reports a paper jam but I can't find it or stop the loud noise it makes when it tries to reset. What should I do?
please perform the steps provided below.
1. unplug the power cord
2. reinsert the ink cartridge
3 if the issue persist click on # & 6 and click on okay
Dec 01, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 6210 will print but with terrible clicking noise
Ok this Sounds Crazy but it worked for me and its easy to try. Unplug the unit and pick it up and turn it side ways and gently shake it. Sometimes a small piece of plastic has broken loose and is interfering with the works and if you can dislodge it from its current location it will stop. Be careful not to hurt youself doing it. Also, I have one printer with a missing tooth on one of the gears and has been growling at me for a long time.
Best of Luck,
RSMITH972278
Oct 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
6210 Stuck in self test mode
Perform the steps provided below.
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
  5. The HP All-in-One will now be reset to factory defaults.
AFTER PERFORMING THE STEPS IF THE ISSUE PERSIST FOLLOW THE STEPS PROVIDED BELOW.
  1. Press the Power button, and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord into the wall outlet.
  6. Press and hold # and 6 while plugging the power cord back into the HP All-in-One.
  7. Turn on the All-in-One by pressing the Power button (c01150476.jpg ).
Aug 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I have a hp officejet 6210 all-in-one printer. When I copy from the glass vs. the feed, I see thin, vertical, black lines running down the page.
clean the glass or try following steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to
printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and
then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Jan 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My HP 6210 prints blurry BUT not all the time?
Please follow the follwoing steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Jan 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 6210 all-in-one printer won't turn on
One of the outlets in the power strip was dead. So tried another outlet and it worked! Thanks for the follow up.
Nov 30, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet 6210 won't print
Perform the following steps:
a) Turn the printer on.
b) Open the printer’s top cover.
c) After the print cartridges have moved to the center/home position of the printer, unplug the printer’s power cord from the electrical outlet.
d) Remove the print cartridges.
e) Using a dry, lint-free, clean cloth, wipe the print cartridge contacts, from the top to the bottom
f) The contacts inside the printer may also require cleaning. Using a dry, lint-free, clean cloth, gently wipe the contacts, from the top to the bottom
g) Plug the printer's power cord into the electrical outlet.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Now, perform the following:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Mar 30, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Officejet 6210 all in one
Remove and check color cartridge message
Nov 15, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
120 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
