I have to run my pc in save mode to get on line
  • 2,841 Answers
Then you have a virus or spyware blocking you from getting online in normal mode. Open the computer in normal mode and go to System Restore and restore it back to a time when this was not happening. If that does not work then open in normal mode, go to system restore and turn it off. This will clean out all restore points which may be hiding the culprit. Now restart the computer in Safe Mode and run all your security software scans and remove all they find.
Posted on Oct 05, 2010
Power save mode on the Lenovo IdeaPad
if you right click on desktop and go to properties or personalize depending on what o/s you're using then choose screensaver and adjust the time.
if you want to change power options it's control panel then performance and maintenance then power options.
Oct 09, 2012 | Lenovo IdeaPad S10e Netbook
My laptop takes ages to boot up and also is running slow how can i fix this
Your pc already affected by virus ,you will need another pc to put the pen drive.then you will format the usb drive.Actually an autorun programe is running in your pc you can manuallly remove the virus .follow the instruction.
http://amiworks.co.in/talk/how-to-remove-new-folderexe-or-regsvrexr-or-autoruninf-virus/
Or you can another do it another way.
You should better to install quick hill and install for scan your HDD .
Here is the link =http://www.quickheal.co.in/downloads.asp
You can use combo fix from save mode
http://combofix.net/
Follow the step.restart the pc >press F8> select save mode use the down arrow key .copy and paste the combo fix and dubble click on it and wait for few minutes. If you can not entry in save mode do the following steep bellow
If your pc run in same do next
download
Scan through this quick hill
Hope this helps
Feb 19, 2011 | IBM ThinkPad R50e Notebook
When I turn on computer, the monitor say going to dpm mode. any help?
DPMS (Display Power Management Signaling) is a standard developed to save energy and maximize the useful life of computer displays. By switching the horizontal and vertical sync lines on or off, a DPMS compliant video card provides the capability to place the monitor into one of four modes (Normal, Standby, Suspend, Off).
Each mode puts the display into a different powered state from fully powered up, to the Off mode. In the Off mode, only a small auxilliary circuit is running which monitors the horizontal and vertical signals to wake up the monitor.
Dec 21, 2010 | Computers & Internet
Power Save mode on, can not use computer
If your computer is indeed running, simply unplug your monitor from the wall, and then plug it back in. This will bring your monitor out of power save mode instantly.
Apr 22, 2010 | Dell Dimension 8400 PC Desktop
I bought a acer aspire 5542g with window 7 on it
You will have to boot of the XP install disk and reformat a FULL NTFS format, first, that will enable you to wipe the drive and install XP. To save an email, or any file to a flash drive, simply copy/paste or drag and drop onto the drive, the drive must be Formatted first, format FAT32. OR when asked for location to save, point it to the flash drive as normally done.
Mar 08, 2010 | Computers & Internet
Problem in Visual Basic 6.0 application
You need to run your program in debug mode and step through the code one line at a time. Have a look at the values in your variables and see if they mach what you expect.
This is one of the skills of a programmer. When things don't go as expected you need to be able to figure out what went wrong.
If you don't have or can't use a debugger you can create a debug mode in your program perhaps with a command line variable or a value in a config file. When debug mode is turned on your program will output lots of information to a log file with details of module names and variable values. This is also useful if later on a user is having problems you can instruct them to turn on debug mode and send you the output.
Hope this helps.
Aug 24, 2009 | Microsoft Visual Basic 6.0 for PC
Horizontal lines appear in newly saved images
the only thing i can think of is the sensor being misconnected or kaput. are you viewing them on the camera screen or a pc? it could also be camara screen...
Jul 05, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Monitor goes into Power Save mode unexpectedly
What are your settings in Control Panel, Performance and Maintenance, Power Options? Do you leave your pc on all of the time or do you turn it on just when you need it? If you are getting lines on your monitor, it is possible that it's starting to give out on you. Please don't try to fix a monitor unless you know EXACTLY what you are doing. It can be very dangerous.
Jun 18, 2008 | Computers & Internet
Keyboard wont work
Hi
You need not remove the batteries to turn off the system if its stuck. Just press and hold the power button for few min and the system will shut down.
It seems that its not a dreamweaver issue. The processor is heating because of some other reason.
check doing the same in the windows advance options i.e safe mode
When you start the computer start pressing the F8 key and select the windows advance option - Safe mode with networking
Check running the dreamweaver in the safe mode. If its running fine. There is a problem with the system.
If you still feel the problem is with the dreamweaver then you can also download the trial Ver for Dremweaver on line from - http://www.adobe.com/products/
Apr 03, 2008 | Acer Ferrari 5000 Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
