How to format usb by using command prompt - Computers & Internet
  • 7,733 Answers
Just right click on it and select format.
Posted on Oct 06, 2010
Pendrive install ridata
Bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt.
To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter.
Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive.
In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter.
As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB.
You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
Oct 03, 2013 | Computers & Internet
Tip
How to format your USB through Command Prompt Formatting a USB Universal Storage...
Formatting a USB Universal Storage Bus is common for those "USV's" or we commonly call it: Universal Storage of Viruses. An example of a USB virus is the problem that we can't access it. We can't see or at least recover our files, and it cause sometimes an error in formatting it. So I will teach you how to format a USB in other way than the GUI one -- the one that uses a right-clicking and Format--
OK let's start!
A. Opening a Command Prompt :
1. Click Start 2. Then click All Programs 3. Point to Accessories 4. And click Command Prompt
OR
1. Open RUN ways of opening it:
Hold the Windows (it is in between the left CTRL and ALT ) picture on your keyboard then press R ,Type cmd ,Press OK, or Click Start then RUN, Type cmd Press OK ,Command Prompt in its default location .B. Type the location of the USB. It is commonly D:, E:,G:, or H:, depend on the number of disk inserted. C. Press Enter on your keyboard. It will go to the location typed. D. Type Format location of the USB: then press Enter on your keyboard.E. Then the format process will begin . I didn't press enter thought my USB have has no problem with it ;D
F. The command prompt will say that the format is done. And that's it! You're done! Congratulations!
Hope that helps :) Well if you liked my post you can view more Tips and Tricks on Fixya . Thank You!
on Feb 12, 2011 | Computers & Internet
Tip
How to create a bootable USB using Vista or Windows 7
Having a bootable USB is very essential, especially if you are a Netbook user. Using bootable USB to install an operating system (OS) not only makes the installation faster, but also saves a DVD.Creating or using an USB drive to install Windows operating systems is very easy if you follow the below mentioned steps.
Here we assume that you are using either Vista or Windows 7 to create a bootable USB.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:DISKPART and hit enter.LIST DISK and hit enter.Once you enter the LIST DISK command, it will show the disk number of your USB drive.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number), CLEAN, CREATE PARTITION PRIMARY,SELECT PARTITION 1ACTIVE,FORMAT FS=NTFS(Format process may take few seconds),ASSIGN,EXIT.
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.CD BOOT and hit enter to see the below message.BOOTSECT.EXE/NT60 H:(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
on Dec 18, 2010 | Computers & Internet
Erc410m usb boot support
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drive
hope this helps
Nov 17, 2012 | Computers & Internet
Cannot format my 2 gigabyte usb
Start ->Run -> Cmd .Hit enter button.
Then command prompt will appears on the screen.By using format command you can format your flash drive. Then type format D: /FS:FAT32 Here D is a drive letter.More information about format command in command prompt type help format.
Aug 03, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Tip
How To Create Bootable USB To Install Windows Vista
his tutorial will help you in creating a bootable USB drive ofWindows Vista which you can use to install Vista in any system. Itmight become very useful when you don't have access to DVD drive.
Use the tutorial available Here .
or
Do it using COMMAND PROMPT
1. First format your USB drive in NTFS file system. You can do it byattaching your USB drive to your system and then format it from MyComputer window.
2. Now open Command Prompt window from Start menu. Right-click onCommand Prompt entry in start menu and select "Run as administrator"option.
3. Now type diskpart in Command Prompt window and press Enter. It'll launch DiskPart program
4. Now provide following command:
list volume
It'll show a list of all drives in your system. Look for your USB driveentry. As in the below screenshot, the USB drive is "G" which you candetermine from its "Type" entry.
Now you have to select the USB drive volume by providing select volumeno. command. Since in our case volume no. of USB drive is "Volume 4",the command would be:
select volume 4
Now we have to make this drive active. So provide active command:
active
Now exit from DiskPart using exit command.
5. Now we need to create Boot sector on USB drive. We'll use"bootsect.exe" utility for this task. You can find this utility inWindows Vista setup disk. It'll be present in "Boot" directory.
Now provide following command in Command Prompt:
bootsect /nt60 G:
Here G is drive letter of USB drive. Replace it with the correct driveletter if your system has some other letter for USB drive.
6. At last, copy all files/folders from Vista Setup DVD to your USB drive and you have done.
Now you can boot using your USB drive and can install Windows Vista in any system.
on Dec 16, 2009 | Microsoft Windows Vista Ultimate Edition
Pen drve is write protected how to format it
check if it has a swicth or latch that youc an adjust to unlock or open it so you can proceed to format it and save data to it
Feb 21, 2011 | Computers & Internet
How to format usb?
OK let's start!
OR
Feb 14, 2011 | Lamaqq Super Blue (USB56KMODEM)
Mt usb is not formating error is windows was enable to format
you can also format your drive in cmd..follow these steps: OK let's start! A. Opening a Command Prompt :1. Click Start 2. Then click All Programs 3. Point to Accessories 4. And click Command Prompt
remote_image20100413-3568-1u9q1a6-0.jpg Command Prompt in its default location
remote_image20100413-3568-1isanwk-0.jpg It is commonly D:, E:,G:, or H:, depend on the number of disk inserted
remote_image20100413-3568-1u9gy68-0.jpg It will go to the location typed.
remote_image20100413-3568-16457ho-0.jpg It should look like this
Feb 12, 2011 | SanDisk 1GB Cruzer Titanium USB Flash...
My problem is that USB not format
Try formatting it using command prompt .
Open command prompt window by
start ---> all programs---> accessories------> command prompt
and type format your drives designated name followed by :
example format g:
May 24, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
