Question about Magic Chef 11.8 cu. ft. / 334 liter Upright Freezer CFU1236GRW
Bought new 8.8 stand up magic c freezer can't get dr open
Bought the same freezer from Home Depot, door would not open did find with a bit of detective work that if you place your fingers between the door gasket and the shell of the freezer you can break the glue type seal then door works fine. You must go across top and down both sides.
Posted on Oct 25, 2010
    Problem Solver:
  • 7 Answers
If You run Your finger in between the rubber seal that is resting on the freezer and the frame of the door , the rubber seal will break lose. When you open the door the seal is attache to the door. Just had the same problem after unboxing. Simple, just be sure to do the entire door.
Posted on Jan 30, 2011
Call service department. Looks like the door was put on wet paint or heated up somehow then slammed shut. Definetly poor quality control.Our store has 5 of them in stock like that with no help from the manufacturer yet after 2 moths of repeated calls.
Posted on Dec 27, 2010
  • denebuff Jan 29, 2011
  • denebuff Jan 30, 2011
    Not A Big Deal!!
I have a Magic Chef freezer built older than 20 years. 15.2 cu. ft. pt. no. 101403-1
Hello Darrell;
My name is Peter. I am a retired field service technician.
Why do you think your Magic Chef is still working after 20 years? Your unit was manufactured with reliable cast steel components.
Do you want to purchase a new unit with more efficiency with components manufactured with plastic and cast ceramic. If you do decide to purchase a more efficient unit, do not discard your well build Magic Chef. When the new unit fails after 5 years, you will always have the older well built unit.
Nov 13, 2014 | Magic Chef Freezers
Stand up magic cheef freezer unthawing and hot to touch
A freezer can't "unthaw". It can freeze or thaw. I assume your freezer is not cooling properly and is hot to the touch. First try defrosting the interior. Ice buildup will cause the problems you described. Also check the rear of the freezer and clean the cooling coils so they transfer heat to the outside air.
If neither of these things helps, have a professional check your Freon coolant level. You may have a leak.
Oct 15, 2013 | Kenmore 20.3 cu. ft. / 575 liter Upright...
My chefmate freezer stopped freezing
have you looked as for a hole or opening and if there is none then this has happened to me you could take to the the store you got it at or get a new one but if there is a hole you could use a "freezer glue"
Jun 25, 2012 | Magic Chef Freezers
MAGIC CHEF FREEZER THE DOOR IS NOT OPENING FOR 8.8 CU FT UPRIGHT FREEZER MCUF88W -- BRAND NEW JUST BOUGHT?? HELP
Sep 27, 2010 | Magic Chef 11.8 cu. ft. / 334 liter...
Age of appliance
At some point, you just have to decide if you want it or not. I can't tell you anything about it. If your friend bought it used, ask how long she's had it and estimate at least 5-10 years older than that. If it looks good, and it works good, and the price is right...... I have one similar to the one that you are considering out in my garage. Bought it at a yard sale...$40.00. Not too pretty, maybe from too many moves....Works fine, but if it died tomorrow, I have had my money's worth.
Sage advice from W/D
Aug 10, 2009 | Magic Chef Freezers
I bought a used Kenmore upright freezer, it's been on for over 24 hrs, and it freezeswell, BUT won't turn off. Runs alllll the time. Any suggestions??
Did you transport it STANDING or LYING down?
If Standing 4 possibilities:
1. The thermostat is hosed (replace)I had one like this and just put it on a $6.00 24hr time to turn on for 1hr every 5 hrs. (New Thermostat was $40.00)
2. The heat exchange fins on the back are dirty(clean with broom and air/vacuum cleaner)
3. The Door seals arent sealing and cold air is falling out the bottom, pulling hot air in the top (rehang door or replace seal) Note: a piece of paper 2" by 8" should be hard to pull out all the way around when closed. Like a cash register reciept. Cleaning with armor-All and then thinly coating with Vaseline may help
4. The Freon is shot and needs a recharge. (Costs $40-100.00)
If transported Lying down, there is now air in the lines and it needs to stand OFF for 24hrs. You may have hosed the pump with the air/freon mix, but let it stand so the air can surface and retry
Mar 26, 2009 | Freezers
Upright freezer stopped working
That clicking sound is your compressor tightening up(clixon switching on and off.). Pull the freezer out and feel the compressor. If very hot and not running, there is your problem.
Jan 29, 2009 | Freezers
Defrost problem
If a defrost system is not working you will get, either no cool or frost build up.
Aug 07, 2017 | Magic Chef 19.6 cu. ft. / 555 liter...
New chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Jul 13, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Magic Chef 11.8 cu. ft. / 334 liter Upright Freezer CFU1236GRW Logo
601 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
Offbelay
Level 1 Expert
AJMAL KHAN
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
