Question about Matsonic MS8137C Motherboard
When I turn all it does is beep have a steady red light on. Tryed unpluging everything and pluging back in no difference.
    President:
  • 1,768 Answers
Your issue sounds as though it is the power supply that is in need of replacement.
If there is a steady red light on then the PC unit is not getting it -12/+12/-5/+5 voltage at the connectors also you may have inadvertently switched the cable connections that is pin 1 of the cables is not getting the voltage it needs to the device.
The red line on the cable or the (+) is the supply pin to that device.
1. check the power supply and all the connectors.
2. clean all dust from the inside of the the connector and around the CPU
3.check the CMOS battery (looks like a new quarter) should show 3.7 volts with a volt meter. If readings are below this you need replacement.
I hope this helps. Have a great day!
Posted on Oct 05, 2010
Green light flashing won't turn on
Likely has bad 1000UF capacitors on DM module. this will prevent rebooting.
Apr 08, 2014 | Mitsubishi WS-65611 65" Rear Projection...
Brought a second hand ps3 slim 160gb.when everything is on tv says no signal i hold button down but no beeps light goes from green to red anybody help please
Try this Make sure no game in ps3 turn ps3 off and by the switch at the back unplug it wait a couple of sec then plug it back in turn on buy the switch at the back then hold down power and eject hear a beep keep both preseec till 2nd beep let go should be able set it to ya tv
Dec 28, 2013 | Sony Playstation 3 (PS3) Console
Power went out i tryed to turn the xbox360 back on it didnt work
Take the Hard drive off, unplug the power wire from the wall, and plug it in to a different outlet, make sure the RCA (red,white,yellow)cables are still connected from Xbox to TV(or this will give red lights when turned on) and with that done, turn the unit on. Are the lights gone?
Jul 15, 2010 | Microsoft Xbox 360 Console
Prolems with the power.
Try leaving it off and unplugged for a while then hold power button while pluging back in to reset. Most brands of tv's flash to display trouble code.
Mar 15, 2010 | Jwin JV-DTV3212 32 in. HD-Ready LCD...
When ps2 is pluged in it shows red light but wont come on
try this:
unplug the AC from the PS2 and the wall.
wait a couple minutes before plugging back in and playing.
hope this helps :p
Nov 15, 2009 | Sony PlayStation 2 (PS2) Console
Turn the computer on, steady red light and beeping.
Have check for the pins connections who makes it to be master or slave? Have check how you plugged yours cables at HDD? Know that , the cables are plugged as following:
After to put in the power cable, the data cable must be put in in the way that the Red line must be in the direction of power cable. Check all this , if your HDD was good before , i believe that it will work.
Thanks , good luck!!
Sep 19, 2009 | Dell PowerEdge 1800 Server
Turns off straight away
system hard drive is corupt needs to get repaired. $$$$$
Aug 09, 2009 | Sony Playstation 3 (PS3) Console
Shut down, no pic/no sound just the red timer light
You need to replace the lamp. you can do this yourself.
May 26, 2009 | Televison & Video
Pluged in power cord but the ps2 is not reciving
Seems like a bad power supply on your unit. You can contact your local servicer for that so they can replace or fix that part.
Jun 13, 2008 | Sony PlayStation 2 (PS2) Console
Matsonic MS8137C Motherboard Logo
59 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Alan Hohenbrink
Alan Hohenbrink
Robert Karst
Robert Karst
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
