Question about Sony Cyber-shot DSC-W55 Digital Camera
Kodak C763 - fully charged battery - blue lights go and blink for a few seconds - camera will not turn on, lens does not open.
  • Anonymous Nov 08, 2008
    I'm having the same problem, and it is the original battery, it just worked before I charged it and now it isn't working anymore.
    Scholar:
  • 75 Answers
Hi-
When you say 'fully charged', is it the original battery from the camera, or another type of battery?
The description you give indicates one of three possible issues:
1. Your old battery can no longer hold a sufficient charge and though it can give enough to show activity (blue light), it may not hold enough to run the device. You may need to replace it > should be available at most retailers that sell Kodak cameras.
2. Wrong type of battery used. Check to see what type of battery the camera requires: NiCad, Lithium, etc. are all different, and not all can be used in these cameras. It's not just about the battery size.
3. Did you drop it? If so, the threads for the lense may have been damaged, not allwing it to eject from the body.
Since you bought a Kodak, you are lucky. If options 1 or 2 do not fix the problem, contact Kodak and they will usually take care of you.
DigiChick
Posted on May 29, 2008
Kodak easyshare digital camera MD41, lens extends and closes when start button is pressed with fully charged battery light blinks red and turns off camera
hi open the battary comparment, remove the battery and check to see if there is a small button like thing (looks something like a small horn) there if yes then, press and hold it for roughly 20 secs and release reinsert battery and try powering on this would reset the camera to original factory settings at a hardware level
(i got my other Kodak c340 to work this way)
hope this helps
cheers
May 05, 2011 | Kodak EasyShare MD41 Digital Camera
No flashing blue light when charging. Lens will not return into
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or possible alternative a new cable.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 28, 2009 | Kodak EasyShare M1033 Digital Camera
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
My Kodak EasyShare M340 turns on, but then shuts off immediately.
omg! thank you so much Stephan you are th best i just bought the camera for Christmas. Went to the beach yesterday and it sttopped working the method with holding the lens and moving it around i saw some sand come out now it works!!!!!! :-D
Oct 07, 2009 | Kodak EASYSHARE M340 Digital Camera
When battery is put in red led in front turns on but lens will not extend or turn on it is an kodak easy share c763
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Aug 24, 2009 | Kodak EasyShare C763 Digital Camera
Kodak M1093
It requires service or repair
Sep 05, 2017 | Kodak EasyShare M1093 IS Digital Camera
Won't turn on after charging; lens just sticks out
Charge it again with a new batery and the 5 volt charger.
3 hours.
Vitally
Apr 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak East Share C763 Lens Error 22
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 15, 2008 | Kodak EasyShare C763 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
I have the exact same problem. Can anyone help?
Apr 03, 2008 | Kodak EasyShare CX7530 Digital Camera
Kodak c763
I have had problems with mine for quite some time. My last 2 vacations involved me taking the batteries out everytime between pictures and rubbing their ends, sometimes that would help.
Feb 14, 2008 | Kodak EasyShare CX7530 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
77 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
