Question about Sony Audio Players & Recorders
Sony STR-DE515 goes to protect mode with in a few seconds of powering the unit up with or without source and speaker connections
SOURCE: Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Posted on Mar 13, 2008
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
ginko
  • 19396 Answers
SOURCE: stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
SOURCE: Sony STR DE 485 is locked on Protect mode
Change the audio amplifier IC damaged
Posted on Jul 09, 2009
  • 40 Answers
SOURCE: Sony STR K840P, protect mode is flashing,no
This is a classic problem. One of your speakers is miss wired and or your speaker wires positive and negitive leads are touching. Check all connections from the back of the reciever to the back of the speakers to make sure your positive and negatives are correct and that none of the wiring is crossed or touching one another.
Posted on Jul 25, 2009
When I turn the unit on it will stay on for a few seconds then goes to protect mode. any ideas?
http://www.retrevo.com/support/Sony-STR-DE325-Receivers-manual/id/387bh941/t/2/
See page 17.
Disconnect all speakers and see if that helps. Shorted speakers or wiring will cause this. If it still does it a trip to a hands-on tech is called for.
Dec 23, 2010 | Sony STR-DE325 Receiver
My sony str db790 is in protect mode, i have disconnected all the speakers and when i turn it on it goes in to protect mode again. i have connected back 2 speakers that i know have no faults and still it...
Hi Kevin, This may not be a solution but you`ve most likely burnt out the amplifiers, I have the same model and its just burnt out the amplifiers for the second time. I was`nt cranking the volume and it was running my Bose AM 5`s which are very good speakers.Its expensive to repair and not many tech heads will take on anything "Sony". If you do have any luck fixing it please get in touch. *n.crookgto@bigpond.com* Regards, Neil.
Dec 11, 2010 | Sony STR-DB790 Receiver
When iturn on my Sony STR-DE325 it goes into protect mode
Try disconnecting all of your speakers, and then turn on you unit. If you have a defective speaker, or a short in your wires, your unit will go into protect mode. If your unit seems ok with the speakers disconnected, then turn unit off, hook up one of the speaker leads and try it. This way you can isolate the problem.......
Good Luck,
Eric
Jul 09, 2009 | Sony STR-DE325 Receiver
Stuck in protect mode
May 04, 2009 | Sony STR-D1015
Sony str-d715 flasses protector
May 03, 2009 | Sony STR-D700SS Shelf System
Protect is on
Hi...
Is it LOUD when you first turn it on?
Are the speakers firmly connected at BOTH ends?
If that's all OK then one or both of the output modules in the power amp have failed.
Parts are available
Jan 22, 2009 | Sony STR-DE715 Receiver
Regards
Darryl.
Mar 07, 2008 | Sony STR-DB930 Receiver
Need help
'Protected' usually appears on amps or combined cd/amp units when the main processor detects a short circuit in the speaker connections and the unit goes into 'protect' mode to stop further damage.Check the speaker connections. You may then need to reset the unit by holding the power switch in for a few seconds while powering on the mains cord for example. Sony A/V amps are notorious for this issue.
Jan 06, 2008 | Audio Players & Recorders
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
831 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
