Question about Maytag Dishwashers
I have a Maytag dishwasher, model MDBTT60AWB, that sounds like the motor is bad. It makes a very loud noise when starting up. I've had the motor replaced and it still makes the noise????
SOURCE: Dishwasher noise
see the fix at the following link:http://www.fixya.com/support/t204050-ge_adorda_dishwasher Simply zip tie the water tube for the middle spray to the upper basket.......it works!
Posted on Sep 05, 2008
aborcass
  • 2651 Answers
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Posted on Jan 25, 2009
  • 423 Answers
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Posted on Mar 30, 2009
SOURCE: Frigidaire dishwasher model GLD2445RFCO is making noise
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
Posted on Feb 05, 2010
SOURCE: Kitchenaid Whisper Quiet + dishwasher making loud humming noise
Same here. What gives?
Posted on Apr 30, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
After my dishwasher fills with water, and starts to run, the motor is making alot of noise. Its loud and I'm afarid to run it. Could the motor be bad?
Hello & Welcome to FixYa
If you hear a loud hum/buzz sound from the bottom of the unit then it is the motor that is bad and if the hum comes from the control then it is the timer/electronic control that is bad and needs replacement. However, after reading your question I believe it is the motor that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 13, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Maytag MDBtt60awb will not start. Power definitely at dishwasher as panel lights are on, however "start" button does nothing. Dishwasher is less than 2 years old. The panel buttons eventually turn off. ...
most likely you have a bad motor when replacing the motor ihave found it is cheaper to get the pump with the motor attached where as they charge you more money for just the motor or the pump seprately try allbrands appliance parts they seem to be cheaper
Apr 30, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Kitchenaid Dishwasher has starting making a real loud noise
Hi Andy and welcome to FixYa. I am Kelly. That loud noise your hearing is the motor bearings. If you were to remove the lower kick panel you will prbably find signs of a slow leak of water has been trickling through the motor and you will see a water spot under the motor pump assembly.
You were correct in your assumption that it was bearings. What happens is the motor shaft ceramic seal starts leaking long before the home owner even notices it. Then the water gets into the motor and corrosion starts to build up. As the motor turns the bearing starts to spal as a result of the corrosion and you hear the loud noises.
The only fix for this sadly to say is a complete motor impeller assembly replacement. If your model number is the one associated with this post / question: KUDI01FLSS then there is one more digit after the last "S" that being one of the following numbers 0, 1, 2, 3, 4, 5 or 6.
The motor and impeller for your dishwasher Item 10 or 18 can be found here and is listed at $138.44:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164895&diagram_id=907556#d907556
The seal that has failed is item 23 of the same link. Changing the seal at this point will not stop the noise.
Thanks for using FixYa.
Kelly
Apr 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Loud noise during cycle MDB6600AWB Maytag Quiet Series II
look for odjects in the pump cutter ie glass plastic or the cutter is bent or a rushing sound could be motor bearings
Dec 24, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Whirlpool Dishwasher suddenly making a grinding noise...
Motors for tall tub whorlpools are over two hundred dollars. If its less than a year then its under warranty. You did not indicate model. If you can get back to me I'll look more in to seeing if it is feasable to repair or replace.
Jul 24, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag dishwasher mdb56000aww
It seems that your motor on the dishwasher is going out, like mine has just done. My explanation is that it sounds like something is grinding on glass or as if a bunch of mice are making noise. Eventually, the motor will not run any more. What will happen is that the dishwasher will fill up, then make a loud humming noise, while the heating element is making the water near the heating element sizzle. Now what you have is a possible fire hazard which compounds the problem with the dishwasher. Get rid of it, take the loss and live like my grandmother used to, without having a dishwasher. That is the best advice I can give you.
May 08, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwashers Logo
65 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
