Question about Kenmore Dehumidifiers
Have 2 one month old Kenmore Elite 251.90701 dehumidifiers with the same problem. When the buckets fill, the machines go to E3 while displaying the bucket full light. After the machine is turned off and back on, the pump tries to engage and then shuts off without discharging water. If the drain hose is removed, the pump ejects water from the drain hose connector. If instead of removing the drain hose, I just give it a ****, the pump will empty the bucket one time, then go back to the above mentioned problem, instead of emptying when the bucket next fills. There are no kinks in the hose and the ends are sitting in the air above a floor drain. I think this is a design problem and not, as such , fixable. Could the supplied hoses be too long or too small a designed diameter for this pump? If it goes on and doesnt work tillit is sucked could there be any other answer? I like the features of these machines, but may return them instead of giving a Sears service guy a chance to come to the same conclusion. Many thanks!
  • 417 Answers
SOURCE: Bucket fills up instead of water flowing out hose
There must be a blockage in the hose causing the water to back up and flow into the bucket. Try pushing a flexble peice of wire through the hose to unblock it.
Posted on Oct 17, 2008
  • 184 Answers
SOURCE: Connector hose inside dehumidifier leaks
let me know if you still have this
Posted on Dec 19, 2007
  • 121 Answers
SOURCE: GE dehumidifier light says bucket is full but it isn't
Try feeling both sides of the outside of the bucket and make sure the bucket is flush with the dehumidifier. If one side is sticking out more than the other it may notbe engaged correctly which will cause a full bucket notification. If everything checks out ok there try takng the bucket out and push in on the button that the lever from the bucket engages on at the dehumidifier. If the light turns off after you push on the red button that means the bucket is not engaging correctly. If the red light stays on and it doesnt make a difference he button sensor may be defective. If you found this solution helpful please rate it.
Thanks - Tech101
Posted on Jun 24, 2008
SOURCE: Dehumidifier Error?
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
SOURCE: Problem with draining water through hose
I bought one of the FDL70S1 Frigidaire dehumidifiers today for my shop, and found that the $5 hose I bought to drain it through the floor wouldn't tighten down completely, allowing the hose to twist and wobble, a sure indication that it was not water tight. Simply adding a second washer, as described in another answer here, allowed me to tighten the hose sufficiently to produce a tight fit with no play between the hose and the dehumidifier. It hasn't leaked. I know it is a threads-per-inch issue, and I am stumped as to why Frigidaire would supply these units with a different thread pitch than the standard GHT (garden hose thread) 3/4" - 11.5 tpi. The threads on the unit appear to be 3/4 NPS - 14 tpi. Go figure!
Posted on Aug 06, 2009
I have a Kenmore Elite Dehumidifier. Yesterday it just stopped working. When I plug it in, the panel does not light up at all, nothing, no power! Warranty ran out last month. It is 13 months old. Thanks....
Debi, before we assume there is something drastically wrong with the unit itself. Let's look at some other things that may be causing the problem.
1. Is the outlet that unit is plugged into still have power? Has a circuit breaker in you home's
Circuit Breaker Panel been tripped? If so, unplug the unit, before resetting the circuit breaker.
2. Was the water collection bucket recently removed to empty it? If so, was it reinstalled
properly? In other words, was it installed "squarely" into the holder and making contact with
the bucket safety removal switch, on the rear wall of the bucket holder? If not, this would cause
the unit not to activate.
3. Does your model have a float valve in the top of the bucket? If so, the float may be stuck in the
UP position. Which indicates to the unit, that bucket is full. If you have a float valve, jiggle the
arm of float to make sure it moves freely. And reinstall the bucket properly.
I hope all of the above helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 24, 2011 | Kenmore Dehumidifiers
I have a AD50USR1 Dehumidifier. I filled the bucket with wayer, but when i slide it back ito place, the bucket is not pushing that button on machine to operate it. It says to fix or adjust bucket. How do...
Why would you be putting water INTO a Dehumidifier??
The idea of a dehumidifier is to EMPTY the bucket, then the machine takes moisture out of the air, fills the bucket and you empty it again.
Are you sure you need a dehumidifier and understand how they work?
Aug 02, 2017 | Whirlpool Dehumidifier Dehumidifier
Kenmore Elite 70 pint unit. Compressor appears to be frozen. Fan runs and compressor attempts to engage but immediately shuts down. Any suggestions. Unit is only about 2 years old.
Hi, I think you got it figured out...
There can be many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 15, 2010 | Kenmore 54501 Dehumidifier
Elite model worked great,,,now displayed temp and rh seem way off, and hardly ever turns ons
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 25, 2010 | Kenmore Dehumidifiers
Hose not draining, bucket only fills
The easiest way to unstop the hose is to blow air through the end enough to clear the clumped up dust at the other end using air compressor or air pump.
Jul 12, 2010 | Frigidaire FDF70S Dehumidifier
My kenmore dehumidifier won't pull the moisture out of the air, the motor is runing when turned on but the bucket never fills up. What is the problem?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Jun 10, 2009 | Kenmore 53509 Dehumidifier
I have a Kenmore 54501 dehumidifier
hi,
somewhere there is a "knockout" or "plug" or something similar you have to remove or replace it to get it to drain through the hose, there should be some documentation in the owners manual about it, try troubleshooting in the back of the manual. If not look directly into the hose outlet and see if theres a plastic plug there, if there is use a screwdriver or something similar to GENTLY remove the plug, you may have to just study the machine when its running to get a better idea of how the water drains, maybe the machine came with something like it in one of the plastic bags the accessories came in.
good luck
J
Jul 23, 2008 | Kenmore 54501 Dehumidifier
Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
Aug 02, 2006 | Danby DDR583R Dehumidifier
Dehumidifiers Logo
166 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
