Question about Intel Motherboard
Connecting pc speaker
I have hcl infinity system in which there is a speaker also which is connecte but no out put is comming can u help me in getting the sound ---venkat
    Problem Solver:
  • 6 Answers
U just check audio driver is installed or not...if not installed u just install the audio driver from u r mother board cd..
Posted on Jul 27, 2009
  • 55 Answers
Install the sound driver it will work
Posted on May 30, 2008
2 Suggested Answers
ghouliass
  • 105 Answers
SOURCE: sound card driver
This driver can ba accessed by this page.
http://59.90.146.12:8080/examples/jsp/download/pon_index.jsp
You need to choose the nearest product then in the list, near the end you have the access to the audio drivers
Posted on Nov 24, 2008
Dodge infinity
The Infinity system includes a CD/cassette receiver or a CD receiver in the dash, and a complement of 7 speakers: 3-1/2" speakers in the dash (left, right), a 2-1/2" center dash speaker, two 6"x9" woofers in the front doors, and two 5-1/4" speakers in the rear doors. You'll have to remove a section of the dash to install a new stereo, as you do with the non-Infinity system. You'll need a special adapter to connect a new car stereo to the Infinity factory amp http://www.crutchfield.com/p_120CHTO02/Axxess-CHTO-02-Factory-Integration-Adapter.html?tp=3486
Dec 25, 2013 | Cars & Trucks
How do I hook up banana plugs to a infinity PC 350 speaker
The illustration in the manual I found at retrevo.com isn't detailed enough to show the axial connection option, which would normally accept a banana plug inserted straight in if the opening is conductive and about 4mm wide. I suspect it is as they mention a "variety of wire connectors".
Their only illustrated example show bares wire ends inserted into a small hole drilled through the termial post and the red or black plastic piece tightened down to secure it.
WIRING THE SYSTEM
IMPORTANT: Make sure all equipment is turned off before making any connections.
For speaker connections, use a minimum #16-gauge speaker wire with polarity coding.The side of the wire with a ridge or other coding is usually considered positive polarity (i.e., +).
NOTE: If desired, consult your local Infinity dealer about speaker wire and connection options.
The speakers have coded terminals that accept a variety of wire connectors. The most common connection is shown in Figure 5.
To ensure proper polarity, connect each + terminal on the back of the amplifier or receiver to the respective + (red) terminal on each speaker, as shown in Figure 6. Connect the – (black) terminals in a similar way.
See the owner’s guides that were included with your amplifier, receiver and television to confirm connection procedures.
IMPORTANT: Do not reverse polarities (i.e., + to – or – to +) when making connections. Doing so will cause poor imaging and diminished bass response.
Feb 20, 2010 | Infinity PC350 Center Speaker
Infinity ERS640 speakers impedance
Your speakers are acutally rated at 4 ohms. Your connection will be just fine. No need to worry.
Here is the manual for your reference.
Jan 19, 2009 | Infinity Audio Players & Recorders
It is possible to connect 4.1 Speaker to Laptop
maybe the type of the sound card on the laptop is not compatible with with the creative speaker system.try to play other speaker systems
Nov 09, 2008 | Creative Labs SoundBlaster Live Dolby...
Component speaker not working
The easiest thing to test is to try swapping the connections of the front component speakers at the amp connections. If the problem follows the speakers, the issue is probably with the speakers. I would triple check (again) the speaker wire connections. It's also possible the crossover for the driver side component speakers has an issue (thus why the tweeter worked for a while).
If the problem stays on the drivers side, the issue is probably with that channel on the amp. Triple check the RCA connections for that channel.
It's much easier to test other speakers on an amp channel versus trying to check it with a meter.
If the driver's door is "abused" often, my initial thought is the wiring at the speaker or the wiring in the speaker (to voice coil, within the crossover, etc) is the most likely culprit.
Apr 10, 2008 | Infinity 475A Car Audio Amplifier
Can i use 4.1 speakers for my hcl p2102 laptop?
U can use 4.1 speakers with HCL P2102 by connecting stereo pin splitter in Line out and then connecting front and rear spkers.
But U will not get 4.1 surround sound effect as sound card supports 2.1 spkers only, so it is advisable to connect good 2.1 spkers.
Mar 15, 2008 | Creative Labs SoundBlaster Live Dolby...
Intel Motherboard Logo
153 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
