I have to agree with Funoldman.there is likely some kind of buildup blocking the flow
Testimonial: "correct!!!"
Take the hot water faucet apart (with water off) and look for scale or even white plastic.Even if it's a single lever, you might have plugging in the hot water side. If you find white plastic, expect the dip tube in your water heater is falling apart.(Dip tubes direct incoming cold water to bottom of heater) Drain some water from your water heater at least annually to reduce solids in your heater.
Is there a hot water restrictor somewhere that's plugged? try replacing that.
If your electric hot water heater is not working...check out this tip about electric hot water heater problems
Electric Water Heater not Working
heatman101
do you have pressure on your other fuacets in the house
It is all faucets..cold water is fine,hot water a dribble.
Reliance cannot send a technician until oct 15..there is a small baby in the home.
