Question about Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter
My droid 2 sees a blue tooth device but NOT ns-bthdp, and can't pair with it.
  • 652 Answers
Yes sir
Posted on Oct 08, 2010
How do i make my backbeat 903 discoverable
Most manufactures of blue tooth devices use the power button to turn the discovery mode on,by holding the power button down for 6 to 10 seconds when turning on your blue tooth device a solid light should come on,that means your blue tooth is in discovery mode,then what ever device you are connecting it to has to have the blue tooth power turned on,then there should be a add new or search for devices,after thatyou will need a pin pairing code,Most manufactures use a factory 4 digit pin pairing code they are as follow,0000.1234,1111 or 9999 i hope this helps
Feb 22, 2011 | Plantronics Backbeat 903 Bluetooth...
I have a droid x and a friend gave me an plantronics explorer 240 cause she had gotten another one. I thanked her not thinking to ask how it worked like what buttons was what and how to connect it to my...
First of all, go into Settings and then Wireless & Network settings on your Droid X, then push Turn on Bluetooth. The check mark in the box should be green once its on. Then click Bluetooth Settings. Meanwhile, turn on your headset by sliding the power switch towards the microphone. The light should flash blue and red. Now go back to your phone and push Scan for Devices, at which point you should see something like "XXXPlantronicsHeadsetXXX". Push that, and it should work. IF it asks you for a passcode, its 0000. Here's the Plantronics help site: http://www.plantronics.com/us/common/easytopair/#/explorer-240
Feb 21, 2011 | Plantronics Explorer 240 Bluetooth Headset
I WOULD LIKE TO SET UP A BLUE TOOTH CONNECTION
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 20, 2010 | LG Shine CU720 Cellular Phone
How to connect a blue tooth with cell phone
HOW TOCONNECT BLUETOOTH
Take care.
Aug 08, 2010 | Cell Phones
How to connect sony ericsion w395 via blue tooth
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Bluetooth not working in sony W580i phone
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Jul 03, 2010 | Sony Ericsson w580i Cellular Phone
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
Insignia NS-BTHDP ok with phone, pairs with PC but can't connect
Make sure the headphones are set as "default" under Control Panel>Hardware and Sound>Sound>Manage Audio Devices - same for microphone if you're using it for online speech.
Jun 04, 2009 | Insignia Bluetooth Wireless Headphones...
How do you pair your Insignia Headphones/ Headset with a PS3? It is called an insignia NS-BTHDP/NS-BTHDST. In the instructions it only talks about pairing it with a computer. Can someone help me?
Go to Accessory Settings on your PS3.Then go to mange bluetooth devices and hit register new device. while doing this take your headset and put it in discovery mode. You do this by holding the power button and the it alternates between blue and red lights.It should work after that.
To test it go to audio device settings and see if it shows up.
Mar 26, 2009 | Insignia Bluetooth Wireless Headphones...
Why does insignia ns-bthdp have a solid blue light?
I had this problem but the red light was on constantly with no response to anything I did. I plugged this into my power adapter and pressed the + and - buttongs at the same time and it reset and started working properly.
Nov 11, 2008 | Cell Phones
Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter Logo
91 people viewed this question
Top Insignia Radio Communications Experts
woodzowl307
ray gallant
Suddenlink Help
Level 1 Expert
Are you an Insignia Radio Communication Expert? Answer questions, earn points and help others
