Question about Dell E173FPb 17" TFT LCD Monitor
I just purchased a used Dell Flat screen E173FPb manufactured in 2005 and when I connected it to my PC the screen reads, "cannot display this video mode". Is there anything I can do to fix this?
  • 11,361 Answers
I have a E152FP monitor will this work with a graphics card that has a DMS-59 connection
The monitor will work with that video card but the resolution needs to be set to 1024 X 768 or less. Your video card is trying to display the picture at a resolution that the monitor can not handle correctly so you get the video mode error. You will need to use the windows video settings screen to change the settings for that display than you will be good to go.
Sep 27, 2012 | Dell E152FP 15" Flat Panel LCD Monitor
MY DELL E173FPb FLAT MONITOR WILL NOT COMPLETELY POWER UP IN GOES
Most common failure in this model is shorted transistors in the inverter circuits caused by poor solder connections, see pictures here for guide: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Mar 27, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Black screen after insalling video card
Hello sir
Try installing a older version of driver..
Or downlaod Driver sweeper through google and clean your ATI drivers and then try again..
Mar 20, 2010 | Computers & Internet
Error: Cannot Display This Video Mode
You may have to boot into safe mode and reset the video settings to a safe setting like 1024x768.
  1. To get into safe mode, continuously press F8 while the computer is booting up.
  2. Eventually you will get a Windows XP Boot Menu.
  3. Choose the option for Safe Mode.
  4. Go to Start, Control Panel and double-click Display.
  5. On the Settings tab, drag the slider bar to 1024x768.
  6. Click OK
  7. Shut down and reboot.
If the problem goes away, then you are good. Otherwise, you'll have to boot menu again (F8) and choose Enable VGA Mode.
Aug 29, 2009 | Dell OptiPlex GX620 PC Desktop
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
I need help
make sure you have the correct drivers installed by going to device manager in control panel..... if you have then you'll need a better graphics card as yours is prob onboard using system memory with a limited output in resolution
May 23, 2008 | Dell E173FPb 17" TFT LCD Monitor
Dell flat screen
REPLACE 2SC5707 IN POWER INVERTER BOARD.
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503. If you can't get this item to work let me know, I can help I have fixed a lot of these monitor with no problem.
May 01, 2008 | Dell E173FPb 17" TFT LCD Monitor
E173FP monitor - blank with blinking power LED
Remove the stand by removing the screws at the center back.
pry the front and back plastic apart with a large flat blade screwdriver. The front and back snap together so you need to "pop" them apart.
Mike
Apr 13, 2008 | Dell E173FPb 17" TFT LCD Monitor
Monitor no display
hi, check out the connector pins if any is damaged or bent, if not try it on a different system just to confirm that its not the display card problem, let me know??
Oct 20, 2007 | Dell E173FP 17" LCD Monitor
Flat Screen trouble
you need to replace switching transistor 2SC5707 in the Power Inverter Board.
Oct 03, 2006 | Dell E173FPb 17" TFT LCD Monitor
Dell E173FPb 17" TFT LCD Monitor Logo
Alun Cox
