Question about LG Computers & Internet
Hello I have LG 2,5" external HDD HxD2 500 GB when i plug to my computer I get " USB device not recognised " message 1) I test the external HDD in other 3 computers I get the same message 2) I tested the cable with another external HDD it work OK Please advise how to fix the external HDD or recover the stored files Kind Regards Bechir
  • 1 more comment
  • bechir375 Oct 05, 2010
    Led Light in the external HDD is ON
  • bechir375 Oct 07, 2010
    ikkenom Many thanks for your replay and help could you please advise : connecting the small 2,5" HDD as slave Disk drive to another PC, Does that require special connector ?or adapter ?or the connectors are standards connections ?
    any idea for LG 2,5" external HDD HxD2 500 GB disk drive type is it connected successefully as slave disk in other PC does it require special adapter connector so i need to find out before opening the HDD enclosure box (without fixing screws)
    Kind regards
  • Anonymous Mar 19, 2014
    model hdx5 320gb
    Brigadier General:
  • 10,406 Answers
> how to recover the stored files There's a chance that the USB-to-disk-drive interface inside the casing is the problem. So, open the case, and disconnect the disk-drive from that interface, remove the disk-drive, and then connect the disk-drive into a desktop computer as a "slave" disk-drive, to see if the disk-drive itself is working, and to see if you can access the stored files. > how to fix the external HDD First, you need to spend about $1 million to create a "clean-room" (as was used when the disk-drive was assembled). Or, search online for a professional "data recovery service", who already have a "clean-room". They can separate the "integrated electronics circuit-board" from the "spinning" part of the disk-drive, and then connect another circuit-board, to see if the original circuit-board is the problem. Or, they can disassemble the "spinning" parts, and try to repair it, just long-enough to copy all the files from the disk-drive. Obviously, not "inexpensive", but it could be your "last-chance" to recover those files.
Posted on Oct 05, 2010
  • 2 more comments
  • ikkenom Oct 05, 2010
    > LED light in the external HDD is ON
    That either means that the unit is getting AC power,
    or that data-transfer to/from the disk-drive is 'active',
    i.e., it's not a significant 'clue' as to what is going on 'inside' the casing.
  • bechir375 Oct 06, 2010
    Thankyou IKKenom for your replay , Any software which can be used to recover the data .
    Kind
    regards
  • ikkenom Oct 07, 2010
    Yes, there is free software for 'data recovery' from a disk-drive.
    First, open the enclosure, and remove the disk-drive, and connect the disk-drive as a 'slave' disk-drive in some desktop computer -- preferably one with lots of 'free' disk-space.
    Then, do an online search for 'data recovery' software.
    Such software reads the entire disk-drive, start-to-end, and tries to 'stitch' together blocks of data into files that can be copied to that 'free' disk-space.
  • ikkenom Oct 11, 2010
    There are two "standards" for 2.5-inch disk-drives:
    * the older ('EIDE') standard, which will require a special adapter,
    * the newer ('SATA') standard, which uses the same power
Computer wont recognise external hdd
Follow these steps:
1. right click on My Computer
2.Click on manage
3.Click Disc Management
There you can see External hd (you can chose to activate or change drive letters and that will do the job)
Mar 29, 2013 | Buffalo Technology DriveStation HD-HC500U2...
Hello, Ive bought a LG RH387H DVD Recorder, works like a charm, only 1 issue, I've bought this beause it's said it supports USB HDD through usb on the front, it DOES recognise my 2 GB MP4 player, but it...
The manual does not specify the usb size max.
I would expect not more than 8 GB to 32 GB max
Also remember fat 32 cannot support large file sizes more than 8gb
Feb 06, 2011 | Televison & Video
Windows 7 64bit with support for USB 2: when I plug my pendrive in a USB port, there's an advice saying that if I plug it into a USB 2 port, it will perform faster. But how do I know which port is USB 1...
I hate this message.
You can use a program like PC Wizard from CPUID that will tell you what all of you pc specs are.
From your specs you may not have usb 2 ports.
Device manager should also say what usb ports you have.
The best ports to use are the ports on the rear of the computer, front usb ports sometimes dont have as much power to drive external hard drives or high drain devices
Jul 10, 2010 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Two rear USB ports are working fine and have the keyboard and mouse attached to them. Two to ports are mostly working though they give a "Not recognized" error message when I connect an Iomega 320 GB...
Hello there!
there could be problem with your HDD aswell, somethimes usb dont want to recognise some external devices and it shows that error also known as "yellow message".
On your place i would backup all files there and do one format of that for cleaning, who knows what might be in it aswell, some viruses, trojans, ...
If that havent solved your problem, then open up your pc and check look of your motheboard (if you have some eltronic experience you could check joins on it as well with voltmeter) . Thats it.
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Gigabyte GA-8I915P Duo Pro Motherboard
My external hard drive is not recognised by my computer, although it was recognised in the past.
Hi
Please can you try your external HDD in another PC, to rule out issues with the drive itslef
Please also try plugging the drive into a different USB port on the back of the PC
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | Iomega HDD External Desktop (32660) 80 GB...
Simpletech External Drive now failing to connect with USB 2.0
Hello sir, let me give you some tips, you can dismantle it and get the HDD unit, buy a cheap external SATA usb hdd enclosure with USB 2.0 . Well all of them are 2.0 compatible (the unit without the HDD) and put it there. you can always keep the old one for posterity. hope this helps.
Aug 06, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
WD320 GB 2.0 USB external hard drive is not working.
bad driver chip... call the manufacturer.. have the HDD changed...
Jul 09, 2009 | Western Digital Passport 320GB External...
Ihave purchased a SeagateFreeagent 500 gb USB external HDD.It was working very well till I tried to create partitions by using Paragan Disk Management software. In the middle of formatting the partition...
After plugging ur HDD, verify the device is detected or not in Device manager and Try Partitioning Again GUI mode (means in XP).. or follow the steps..
1- Go to Computer Management, Click Disk Management
2 - You will find you External HDD in the Right side
3 - Just Right Click the Drive, if it asks Initialize HDD, just Initialize and Create Partition as u like.
Have Fun
- Rajkumar
Mar 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Iomega USB 2 Desktop Hard drive not recognised by xp sp2
did you set any jumppers to slave? Is it pluged in the right spot?
Nov 24, 2007 | Iomega HDD External Desktop (32660) 80 GB...
Computers & Internet Logo
1,125 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
