Question about General Washing Machines
Indesit washer/dryer IWDC 6125s - no power - power supply ok, module ok but still cannot find out why there is no power
4 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Model #13605, no power.
Welcome to FixYa.
There are indeed 2 fuses on the washer next to the power cord, right side of back as illustrated below...
Further to this, if they both check out as o.k. I'd suggest you remove the top and check the wiring going to and from the fuse hubs/holders as they can and do become burnt and worn due to metal fatigue over time.
The top is easy to remove, just three screws at the back along the top ( # 25 torx heads ) and slide the top back an inch or two and up, it will come off.
You should then see similar to this ( this is an Asko dryer, but the fuse and connectors will be similar )
i.e.
You can also follow this link to my macmarkus "live" account page and there you'll find a "pdf" of your machine's part breakdown including numbers and pictures. Refer to page 15 & 16, parts identified by #3 #4 and #5 of said pdf for the fuses and holders and hub assembly.
https://cid-674627ce75316bb3.office.live.com/self.aspx/Asko%20Stuff/u220.pdf#resId/674627CE75316BB3!564
The fuse assembly subs to a complete kit now, like shown below.
This hopefully will move you forward. Thanks for choosing FixYa and good luck.
Let me know if you require further assistance or if indeed this solved your problem. Please keep me informed either way
Regards,
Macmarkus :)
Posted on Oct 25, 2010
SOURCE: I am looking for an online manual for an Indesit
Right. Go to the Indesit website. Find the model. There is an option on this screen to download the manual.
Posted on Mar 01, 2011
  • 6277 Answers
SOURCE: Hi I have a indesit
It's possibly a problem with either the door solenoid/lock or the 'door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jul 14, 2011
How can I just use the 'express wash' part of the 'express wash & dry' programme without it going onto the dryer part on my IWDC 1605 ?
Surely the machine programming must have a wash and spin "only", without dry program setting or selection? OR check through the programming where to deselect the drying process.
Jul 25, 2014 | Indesit Washing Machines
Should the Indesit IWDC 6105 washer dryer give off a burning type odour when running the drying cycle. (it is brand new and condenser)
I have seen some new dryers give off a smell for the first few seconds that they are run for the first time.
If it's any longer then that is not normal.
Aug 02, 2011 | Dryers
Hi I have a indesit IWDC 6105 washer dryer. problem with door lock light. as soon a wash starts light goes off and wash stops and the door unlocks
John C
Jul 14, 2011 | Washing Machines
F-08 code
Indesit 'f08' decodes as ' heater relay stuck' and the advice is 'check PS (power supply)connections for the heater, wiring and module'. Unfortunately this means an engineer call-out ;-0(
Sorry.
Good luck,
John C
Mar 25, 2011 | Indesit W 123 Front Load Washer
A few weeks ago the machine (IWDC 6125 S) started to flash against all the options at the top. I had turned it on an off and it was working OK. Just yesterday the door was shut, but the machine would not...
The only quick suggestion I have is to unplug it for several minutes and see if it resets. If not, without any other indicator, the only thing I can think of is the door switch, which should be a fairly easy fix.
Jul 04, 2017 | Indesit W 123 Front Load Washer
WIDL102 indesit washer dryer not working properly
check heater element/ should read about 32ohmns on multimeter if not reading replace,if ok replace stat
Apr 03, 2010 | Indesit W 123 Front Load Washer
Door will not open on my washer dryer wd12 model
Unplug machine take lid off and release the door interlock with fingers from inside by forcing catch open,you need new interlock can be supplied.
Oct 07, 2008 | Indesit W 123 Front Load Washer
My indesit washer/dryer model w10 ,is not working.the programme dial keeps cliking round wont start a programme or take in water.
probably a main module fault but worth while checking for continuity thro the heater and that the pump and filter are ok. the idea is that when a fault is detected, the dial will click round indicating a fault but usually it is the module itself. expensive part. not worth repair
Jul 04, 2008 | Indesit Washing Machines
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
