Question about Brother CS6000i Computerized Sewing Machine
Can not figure out how to thread machine with the SA142 presser foot?
    Genius:
  • 1,788 Answers
It is the same as with any foot, just pull your threads to the rear of machine, go to Amazon.com and you wil see a great picture of that foot being used.
Posted on Oct 11, 2010
My Singer XL 6000 upper thread is too tight and keeps breaking, when the presser foot is up the upper thread is loose, but when the presser foot is lowered the threah gets too tight, what I notice is that...
You need to loosen the tension on the machine. There is a dial that has numbers on it. The higher the dial is set, the tighter the tension is. Turn the dial to the left one number. Then try it. Do it over and over. Do not turn the dial all the way down or you will mess up your machine. Do it slowly, one number at a time and try the machine between dials.
Dec 22, 2014 | Singer Sewing Machines
Tip
Sewing Machine & Serger Problems
If you are experiencing stitching problems with your sewing machine and serger, try raising the presser foot BEFORE threading the upper thread. This releases the thread tensioner while threading, but when you lower the presser foot, the tensioner is activated to control the thread's tension.
Never remove the upper thread by grabbing the spool and pulling the thread tail backwards through the needle eye, thread guides, and tensioner. To remove the upper thread, clip the thread below the spool, raise the presser foot, then gently grab the thread tail by the needle's eye and pull the remaining thread through.
on Jun 05, 2015 | Bernina Sewing Machines
Why does the needle keeps getting stuck in the bobbin
Sounds like you've got a thread jam going on. Take the bobbin and bobbin case out, take the needle plate (=throat plate) off the machine, and clean all the lint and bits of thread and other gunge out of there. Reassemble. Rethread with the presser foot up. Fetch up the bobbin thread and pull bobbin and top thread ends under and behind the presser foot. Then start each seam like this:
1. Fabric under the presser foot; lower needle with handwheel or needle up/down key into the beginning of the seam.
2. Drop the presser foot.
3. Hold the ends of the bobbin and top thread behind the presser foot while you take the first 2-3 stitches
4. Drop the thread ends and sew normally.
See also the last pair of photos here: http://www.picturetrail.com/sfx/album/view/22521551
Feb 10, 2014 | Janome Hello Kitty 11706 Mechanical Sewing...
Vintage Tough and Sew Model # 628 PRESSER FOOT QUESTION!
You should be able to figure out which shank your machine has here:
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
If you have the manual, it should show you how to change the presser feet.
SINGER Instruction Manual pdf model 628
If your machine and presser foot look like the one in the video, the screw on the left side of the presser foot should be what holds the presser foot in place.
Singer Touch and Sew Threading and Bobbin Winding
There may be other videos here that would be helpful.
Jun 06, 2017 | Singer Sewing Machines
Hyundai 8 stitch sewing machine confused beginner!?????
Not familiar with your machine, but an important suggestion for all sewing machines:
ALWAYS RAISE the presser foot when threading the top thread. If you did not do this, remove the top thread completely from the machine and start over by RAISING the presser foot and following the thread path. (Do NOT miss any thread guides or thread any out of order!)
Lower the presser foot and thread the needle. (The top thread will pull through the needle ONLY if the presser foot is raised!) RAISE the presser foot and pull at least 5 inches of thread through the needle. Insert your fabric. Lower the presser foot. Hold the thread tail gently in your left hand and with the right hand manually turn the handwheel one rotation. The needle should pull the bobbin thread up through the fabric.
While still holding the top thread tail, "sweep" under the presser foot with a stiletto, scissors, a nail file (anything that will fit under the presser foot) to pull the remaining bobbin thread tail above the fabric. Grab both thread tails and pull them under the presser foot toward the back of the machine. Now, you are ready to take your first stitch.
You can gently hold those thread tails while you slowly power the machine to take the first couple of stitches on your fabric.
Jun 27, 2017 | Sewing Machines
There are loops of thread under the bobbing when i sew
Lift the presser foot and pull about 8" of thread through the needle.
When threading a sewing machine, make sure the presser foot is up as this opens the tension control so the thread can be properly seated and controlled once the presser foot is down.
Apr 23, 2010 | Necchi 4595 Mechanical Sewing Machine
Needle thread looping underneath, threads not interlocking at all
If the machine is now threaded, lift the presser foot.
Now, pull about 10" of thread through the needle.
The next time you thread the machine, lift the presser foot first.
When the presser foot is up, the tension control opens and allows the thread to "seat" into the control, then when the foot is down the control closes to the indicated setting.
When threading the machine with the foot is down, thread does not enter the tension control and when you start to sew, there is no tension on the thread.
No tension = loosey, goosey, loopy stitches underneath.
Because the lack of tension on the top thread, the bobbin thread cannot lock a proper stitch.
Mar 10, 2010 | PfaFF Quilt & Craft Pro 7530
The bobbin thread keeps bunching up - I have cleaned it and changed needles - what else do I do?
When you are threading the machine make sure that the presser foot is up, The tension disks are open when the presser foot is up, If you thread the machine when the presser foot is down the tension disks are closed, and the thread will not go through properly causing a nest of thread of bobbin thread to bunch.
Jul 29, 2009 | Bernina Virtuosa 150
Persistent E1 message
some machines have a presser foot sensor or switch which prevents the machine sewing if the foot is not down.
if your presser foot is down and you still cannot sew the switch or switch actuator is most likely damaged. you will require a tech to repair this.
scott
Jul 26, 2009 | Brother CS6000i Computerized Sewing...
Top thread will not move when presser foot is down
This machine has a tension roller system that meters out thread when the machine is running. When stopped it is locked up so you won't be able to pull thread thru with the foot down.
Hope this helps.
Nov 14, 2008 | Baby Lock Esante
Brother CS6000i Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
