Users manual for indesit widl 1265 - Washing Machines
jaylex
  • 417 Answers
SOURCE: Indesit widl 102 extra rinse button always on!
Check that the button isn't stuck it if not remove top lid and check the PCB and see if the switch hasn't collapsed causing it to be on all the time. Also if you hold in the go button for about 5 seconds this resets the program try this.
Thanks J
Posted on Feb 10, 2008
SOURCE: indesit widl 126-problem with the
It would seem that the bearings go on this model, which causes the inner drum to knock and bang against the outer during spin. If you continue to use the machine without replacing both sets of bearings, it will cause irreparable damage and the machine will need to be replaced.
Posted on Sep 15, 2008
SOURCE: my indesit widl 126 is not drying
my indesit widl 126 is not drying.
Posted on Jun 07, 2009
localwonder
  • 6784 Answers
SOURCE: My indesit widl 126 is not drying
If electric, check the following areas.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
If gas, check the following areas.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective
Posted on Jul 09, 2009
SOURCE: Indesit Model WIDL 126 UK Problem: Shortly after
The model is a not a WA 125 - I couldn't fix the problem and have scrapped the machine.
Posted on Oct 26, 2009
I'm looking for a user's manual for the Indesit washer/dryer combo WIDL 106 model. Can you help? Thanks.
Unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Oct 08, 2011 | Indesit W 123 Front Load Washer
Indesit WIDL 1265 All LED's are flashing regardless of switching power on and off. Managed on last wash to power on and off and have a wash sucessfully. Now it's just constant flashing. ??? Anyone ??
Unplug for 40 minutes to attempt a reset of the ECU - otherwise you must replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Indesit W 123 Front Load Washer
I do i stop the indesit widl 126 mid cycle?
Open the door - or press stop/cancel.
Jun 28, 2009 | Washing Machines
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Wiring for Indesit Widl 126
Tell me, is the machine compleatly dead or what is it doing?
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Indesit WIDL 126 washer/dryer
look at http://www.indesit.co.uk/indesit/productsheet.do?productId=30538UK
Jul 06, 2008 | Computers & Internet
Thanks J
Feb 07, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
555 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
